7th July 2015, 20:12 | #22 | Link |
Retried Guesser
See also, VCMohan's HistogramAdjust
http://www.avisynth.nl/users/vcmohan...ramAdjust.html |
8th July 2015, 01:48 | #23 | Link |
I also tried to find the dll, where'd you get it fvisagie ?
8th July 2015, 08:52 | #24 | Link | ||
So the DLL is gone. I'll enquire from LaTo via PM. |
8th July 2015, 10:22 | #25 | Link | |
9th July 2015, 12:43 | #28 | Link |
fvisagie, is Avisynth v2.6 dll OK for you (MatchHistogram) ?
EDIT: If so I'll try add support for eg YV24 etc.
9th July 2015, 14:34 | #30 | Link |
Here tis, MatchHistogram dll for Avisynth v2.5+ (temp link till attachment cleared):-
LINK REMOVED Code REMOVED ATTACHMENT REMOVED See post #46:- http://forum.doom9.org/showthread.ph...96#post1729796
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 11th July 2015 at 21:21. |
9th July 2015, 15:30 | #31 | Link | ||
So it seems the Quote:
Many thanks also to LaTo for kindly digging up the source. |
9th July 2015, 15:42 | #32 | Link |
The debug curve mentioned is posted before source here:- http://forum.doom9.org/showthread.ph...89#post1381389
and that source is different to later source provided by Lato, so looks like debug was only present early on and then removed. Do you know what the original 'curve' looked like ? that link is also not working.
9th July 2015, 15:59 | #34 | Link |
OK, did not know if you were expecting something exotic.
I'll try to synthesize 256x256 frame BW plot when debug == true. Not gonna spend a lot of time on it.
9th July 2015, 18:30 | #36 | Link | |
LaTo INV.
edit: uploaded latest version! Last edited by LaTo; 9th July 2015 at 21:23. |
9th July 2015, 20:04 | #37 | Link |
Thanx LaTo
and also to fvisagie for being pushy Here update not including LaTo PM source. I'll post what I've done so far: LINK REMOVED CODE REMOVED: See post #46 :- http://forum.doom9.org/showthread.ph...96#post1729796
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 7th August 2015 at 19:01. |
10th July 2015, 03:18 | #39 | Link |
Thanks LaTo & StainlessS!
@LaTo Haven't seen you around in some time, hope everything's going well for you. I have a quick question on your updated source you posted, I see the syntax is "cc[plane]i[raw]b[show]b", what's the purpose of plane and raw? I'm guessing the old debug parameter is now show? Edit: I'm thinking the plane parameter dictates which plane to process? @StainlessS I hate to be the one who nitpicks but there's a small typo in the source in post #37. "Error: Clips dissimiilar dimensions" should be dissimilar. Please don't hate me, I wasn't looking for errors I just happened to see it. Edit: you don't have to do all that, doesn't bother me one bit, I'm just happy than there's a working version of the plugin . Currently I've been doing color experimenting, starting with a YUV source I take the Y channel and save to a Y8 PNG then I load it in an external HDR program, do some subtle enhancements, save it, load it back to into AviSynth and merge it with the original chroma. This technique works surprisingly well on certain things. I want to see how well MatchHistogram performs, I'm also gonna try VCMohan's HistogramAdjust. Last edited by Reel.Deel; 10th July 2015 at 04:00. Reason: reply to StainlessS |
10th July 2015, 03:44 | #40 | Link |
Sum peeple iz neva appy
I'll compile latest when I get around to it. EDIT: And many thanx to Reel.Deel for his attention to detail.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 10th July 2015 at 04:15. Reason: Response to Reel.Deel |
