10th August 2016, 16:24 | #4124 | Link |
@brumsky:
Yesterday I've decided to put --ctu 32 back to use again, at least for SD. Quantizers did increase slightly (when comparing stats files), but I started having issues with 64x64 blocks containing letters or anything sharp - they leave big areas, often geometrically shaped (square), filled with mosquito noise. Apart from that, areas with less details (like human skin) get encoded with rather obvious alternating smooth (big) and sharp (smaller) blocks - though that difference in sharpness could be AQ-related as well. CTUs of 32 helped me a lot with parallelism and saturated all my 8 cores, so 2hrs long 480p video gets encoded with 3.5-4 fps instead of 2 fps. I'll follow your advice and test --early-skip again in some time. I did most of my image quality tests "the fast and dirty way" - i.e. setting bitrate in 2-pass mode, doing full fast first pass on both videos, and encoding just a hundred or so frames in second passes, so I get some material for comparison as soon as possible. I expect more "final" and "trusty" results by comparing in CRF mode. |
10th August 2016, 18:01 | #4125 | Link | |
@x265_project:
Can you go into more detail regarding --early-skip and how it interacts with rect and amp, if at all? I'd like to know if my logic below is applicable or not... Quote:
10th August 2016, 18:35 | #4126 | Link |
In general, features in the presets are turned on based on whether their quality/performance is right for a given speed/quality tradeoff, based on a whole lot of automated testing. In general it probably makes sense to follow those ladders when tuning in speed/quality. For example, some of the skip modes are turned off at pretty fast presets (quality hit is big relative to speed increase) and others only at the slowest presets (smaller quality gain relative to larger performance hit).
10th August 2016, 18:39 | #4127 | Link | |
With the new improved --rskip, the performance isn't as bad when doing my tu depth, and the results are a lot better. |
10th August 2016, 19:31 | #4128 | Link | |
Hey Ben,
Thanks for the quick reply. Since I am running an old sandy bridge CPU I'm just trying to find the best balance between speed and quality. I guess I'm hoping that early skip is only used when no motion or very little motion is detected vs the majority of the time. If so areas that aren't in motion wouldn't be worth the encoding time. Quote:
10th August 2016, 19:35 | #4129 | Link |
On a different note.
How does everyone else handle video with intentional noise, for example BSG or The Walking Dead? I've found those to have very high bitrates even with the below settings. I've seen it spike to 22000 Kbps! I'd like to target between 2000 - 4000 on average but I don't want to force it across the board by using 2 pass. If a scene needs a little extra that's fine but 10,000 to 20,000 Kbps is to high for my likes... Code:
--crf 20 --profile main10 --output-depth 10 --ctu 32 --bframes 6 --rc-lookahead 40 --scenecut 40 --ref 5 --limit-refs 3 --me 3 --merange 26 --subme 3 --rect --no-amp --limit-modes --max-merge 3 --early-skip --b-intra --no-sao --signhide --weightp --weightb --aq-mode 2 --aq-strength 1 --cutree --rd 4 --tu-intra-depth 3 --tu-inter-depth 1 --psy-rd 1 --psy-rdoq 1.28 --rdoq-level 2 --qcomp 0.65 --no-strong-intra-smoothing --deblock -1:-1 --qg-size 16 |
11th August 2016, 00:02 | #4130 | Link |
@benwaggoner
I encode using "Simple x264 Launcher" by Mulder. 64-bit 8-bit encoder, slower preset, and this commandline (some switches are redundant): --rd 6 --no-weightb --ref 6 --me star --subme 7 --merange 24 --b-intra --keyint 300 --min-keyint 50 --bframes 9 --aq-mode 2 --psy-rd 2.0 --psy-rdoq 1.0 --deblock=-2 --no-cutree --limit-refs 3 --limit-modes --rect --no-amp --aq-strength 2 --no-sao --no-strong-intra-smoothing --max-merge 2 --no-rskip --no-slow-firstpass --tu-inter-depth 3 --tu-intra-depth 3 I eliminated qg-size switch, as I wanted the encoder to alter quantizers in all types of blocks. Areas with background scenery are not that important in this case - in a typical Hollywood movie, or a documentary, background/static blocks would matter and I would use --cutree, and probably --qg-size 16 too. My previous encodes (if I remember well) were at tu-intra/inter-depth 2, enforced by preset. |
11th August 2016, 06:28 | #4132 | Link |
Batman v Superman: Dawn of Justice 3D
x265 log:
x265 [info]: HEVC encoder version 2.0+10-5a0e139e2938 x265 [info]: build info [Windows][GCC 5.3.0][64 bit] 10bit x265 [info]: Main 10 profile, Level-5 (High tier) x265 [info]: Thread pool created using 8 threads x265 [info]: frame threads / pool features : 3 / wpp(68 rows) x265 [info]: Coding QT: max CU size, min CU size : 32 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : umh / 25 / 7 / 2 x265 [info]: Keyframe min / max / scenecut : 23 / 250 / 40 x265 [info]: Lookahead / bframes / badapt : 40 / 6 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 0 / 0 x265 [info]: References / ref-limit cu / depth : 1 / off / off x265 [info]: AQ: mode / str / qg-size / cu-tree : 3 / 0.5 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-23.0 / 0.80 x265 [info]: VBV/HRD buffer / max-rate / init : 100000 / 100000 / 0.900 x265 [info]: tools: rd=3 psy-rd=1.50 rdoq=1 psy-rdoq=2.50 early-skip tmvp x265 [info]: tools: fast-intra lslices=6 x265 [info]: frame I: 2296, Avg QP:22.68 kb/s: 36715.43 x265 [info]: frame P: 45621, Avg QP:23.68 kb/s: 26433.02 x265 [info]: frame B: 170292, Avg QP:24.34 kb/s: 17242.93 x265 [info]: consecutive B-frames: 13.7% 5.6% 5.6% 23.9% 9.6% 21.4% 20.2% encoded 218209 frames in 111542.06s (1.96 fps), 19369.20 kb/s, Avg QP:24.19 Encoding finished 10.08.2016 21:08:00,73 Code:
--crf 23 --preset ultrafast --level-idc 5 --high-tier --me umh --subme 7 --scenecut 40 --aq-mode 3 --aq-strength 0.5 --no-sao --no-deblock --rd 3 --psy-rd 1.5 --b-adapt 2 --ctu 32 --min-cu-size 8 --rc-lookahead 40 --bframes 6 --merange 25 --ipratio 1.1 --pbratio 1.0 --qcomp 0.8 --rdoq-level 1 --psy-rdoq 2.5 --lookahead-slices 6 --qpstep 1 --no-strong-intra-smoothing --no-rskip Source BD3D (left view) and x265 OverUnder: |
11th August 2016, 08:39 | #4133 | Link | |
But note that --psy-rdoq doesn't work with --rd 3. You need RD level 4 and above for psy rdoq to kick in. |
11th August 2016, 08:59 | #4134 | Link |
I believe changing the ipratio and bpratio too much isn't really beneficial when using CRF mode. That's why I recommended 1.28 and 1.38 respectively as the results were seemingly 'better' (cautiiously using that word on here!), however choosing anything much lower than that actually made things worse. Because it does affect everything in the encode, the small changes of 0.02 do make a difference.
11th August 2016, 09:39 | #4135 | Link | |
I'm not afraid to go up to CRF 25 or even 26 for extremely grainy content, though this is with qcomp 0.8 so in your case probably 23 or 24 at default qcomp. But even then you'll still end up with overall bitrates of 6-7mbps on occasions unless you do some pre denoising. Though personally I've always found the results of denoising undesirable whenever I've tried it, be it externally or just using x264/5's built in --nr commands. What I do is test a couple of 5 min segments from each film first to find the suitable CRF value. Which can be anywhere from CRF 20-22 for bitrates of 2-3mbps or CRF 25-26 for bitrates of up to 6-7mbps. The average target I'm happy with is CRF 23 with qcomp 0.8 at about 4mbps so that's where I always start. If tests come in around that then away we go with the full encode. But if CRF 23 is giving me too low (say 1-1.5mbps or less) or too high (7mbps+) a bitrate then I'll adjust along the CRF scale from there. Is obviously more effort and time but worth it for me. I also quite enjoy doing it too so... |
11th August 2016, 13:51 | #4136 | Link | |
--rd 3 and above need for work --psy-rd (http://x265.readthedocs.io/en/defaul...option--psy-rd) and --rdoq-level is 1 or 2 need for work --psy-rdoq (http://x265.readthedocs.io/en/defaul...tion--psy-rdoq) I think rd and rdoq are independent methods. Or not? |
11th August 2016, 15:48 | #4137 | Link |
The Final Destination 4
Settings: same as my sample above, just --psy-rdoq up from 2.5 to 3.0. x265 log: Code:
x265 [info]: HEVC encoder version 2.0+10-5a0e139e2938 x265 [info]: build info [Windows][GCC 5.3.0][64 bit] 10bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x265 [warning]: Specifying a decoder level with constant rate factor rate-contro l requires x265 [warning]: enabling VBV with vbv-bufsize=100000kb vbv-maxrate=100000kbps. V BV outputs are non-deterministic! x265 [info]: Main 10 profile, Level-5 (High tier) x265 [info]: Thread pool created using 8 threads x265 [info]: frame threads / pool features : 3 / wpp(68 rows) x265 [info]: Coding QT: max CU size, min CU size : 32 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : umh / 25 / 7 / 2 x265 [info]: Keyframe min / max / scenecut : 23 / 250 / 40 x265 [info]: Lookahead / bframes / badapt : 40 / 6 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 0 / 0 x265 [info]: References / ref-limit cu / depth : 1 / off / off x265 [info]: AQ: mode / str / qg-size / cu-tree : 3 / 0.5 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-23.0 / 0.80 x265 [info]: VBV/HRD buffer / max-rate / init : 100000 / 100000 / 0.900 x265 [info]: tools: rd=3 psy-rd=1.50 rdoq=1 psy-rdoq=3.00 early-skip tmvp x265 [info]: tools: fast-intra lslices=6 x265 [info]: frame I: 1478, Avg QP:22.63 kb/s: 46945.52 x265 [info]: frame P: 26825, Avg QP:23.66 kb/s: 23953.38 x265 [info]: frame B: 89359, Avg QP:24.56 kb/s: 11553.90 x265 [info]: consecutive B-frames: 13.5% 4.1% 8.4% 35.4% 11.0% 20.4% 7.0% encoded 117662 frames in 47406.91s (2.48 fps), 14825.35 kb/s, Avg QP:24.33 Encoding finished 11.08.2016 11:29:31,81 |
11th August 2016, 18:18 | #4138 | Link | |
What's the point of using VBV with such high values? With a value of 100000 Kbps it'll almost never kick in. Plus when it does it using an extreme denoise to bring the bitrate down and blurs the shit out of it. I tried this with several test clips, it looks like shit when it kicks in. My VBV value was significantly less then yours on purpose, 4096 - 4608. My test clips are intentional noisy. Your encodes are not even coming close to the limit you have set. They do look great by the way! Also, do you think subme 7 is necessary? the Placebo preset only goes up to 5. I've also read that me-range star is optimized more than umh... |
11th August 2016, 18:21 | #4139 | Link | |
I did mess with VBV and the results look like shit. Seriously, blurry and very ugly! I'd much rather let the bitrate spike then enable VBV haha! |
11th August 2016, 19:08 | #4140 | Link | |
