25th September 2008, 10:37 | #461 | Link |
AVStoDVD Dev
AVStoDVD release 2.1.1 Alpha 090825 available to download
Change log: - Some bugs fixed - Added 'Video Minimum Avg BitRate' in 'Settings'/'AudioVideo'. Lower value allowed is 1000 kbps. Default is 2500 kbps. - Added 'Default Subs Language' in 'Settings/Authoring&Burning' - Added frames selection customization to DVD Menu thumbnails (static and motion) - Added frame capturing and saving (bitmap) feature in 'Clip Preview' - Added 'GridSnap' feature (grid visualization and snap objects to grid) in DVD Menu Editor - Added 'DV Source' auto detection in 'Title Edit'/'Video' - Changed 'Default Video Max BitRate' in 'Video Maximum Avg BitRate'. Higher value reduced to 8500 kbps to avoid bitrate spikes. - Changed Video Max BitRate (peak) setpoint: now it is not customizable (9000 kbps) - Improved 'Clip Preview' form capabilities - Improved 'Settings'/'System'/'Hardware Info' section - Improved button shadows in DVD Menu Editor (new AviSynth function 'DropShadow') - MediaInfo updated to 0.7.7.6 - BatchMux updated to 1.3 - Moved from "GNU/GPL" to "Creative Commons - Attribution-Noncommercial 3.0 Unported" license type *Note about license* I would like to thanks PatchWork for his (somehow "inquisitive" but very qualified) advice in choosing the appropriate license for AVStoDVD. Bye |
25th September 2008, 11:30 | #463 | Link | |
AVStoDVD Dev
Let us know Bye |
25th September 2008, 16:17 | #464 | Link |
Thanks!
Tested 'DV Source' auto detection with DV-AVI and DV-Quicktime/.mov Container (PAL/25i). Both were detected correctly as DV Source. Makes my life a lot easier... Greets, Filbert Last edited by Filbert; 25th September 2008 at 16:24. |
25th September 2008, 22:27 | #465 | Link |
The frame selection part has crashed on me twice now - once just scrolling through the video and once trying to OK my selections. Its a shame because I like the idea! Like the menu grid too!
Not tested the Panasonic issue yet but I'll report back soon. |
26th September 2008, 10:43 | #466 | Link | ||
BTW I suggested the BY-NC-SA 3.0 to stay under some open feel (the BY-NC allows others to mod your soft but they're not forced to release the mods and can change the license too)... Quote:
Hybrid Multimedia Production Suite will be a platform-indipendent open source suite for advanced audio/video contents production. Official git: https://www.forart.it/HyMPS/ Last edited by PatchWorKs; 27th September 2008 at 10:34. |
26th September 2008, 11:32 | #467 | Link | |
AVStoDVD Dev
I had some crashes as well when using ffdshow "nightly builds". Everything ok instead with ffdshow stable releases and XviD 1.3. Not tested with DivX 5/6. Bye |
27th September 2008, 18:55 | #468 | Link |
Sometimes when I make a dvd it doesn't rebuild into a dvd structure properly. It happen twice, one time with a whole movie, and then recently with a single titleset. I get the error in imgburn the corresponding ifo file for that particular titleset is missing. But this would most likely be a muxman error? not a avstodvd error...
28th September 2008, 10:35 | #469 | Link | |
AVStoDVD Dev
Maybe Sir Didymus, who's knowledge of Muxman is surely greater than mine, could help us. Bye |
28th September 2008, 16:54 | #470 | Link | |
I don't like to be considered as an "expert" of anything (I am not... really...). This issue, of the missed IFO files, is surely independent from the release of MuxMan (0.15R or 0.16.6). And it is neither depending on BatchMux - which is just a tool helpful in order to build the MuxMan scripts - or on MuxMan itself. It is just a consequence of the fact that the MuxMan session ended with an error. Looking at the MuxMan log, and having some more informative bug report from gizzin would be useful for a better tracing of the problem. My experience is that whenever properly created assets are fed to MuxMan, the authoring session does not fail. Also, please use the search! The issue of the "brute" end of the MuxMan authoring session has been discussed previously many other times, both in this thread and in the one related to FAVC. Cheers, SD |
29th September 2008, 04:25 | #472 | Link |
Um yeah I guess saving the log would probably be useful. heh. I got a new error, well not necessary new, this also has been happening b4. The process aborts before it actually authors the dvd. I mentioned it before, I think I gave you a log of it. But anyways heres another log... I tried it with muxman 15r. I will also get a log of when the vts ifo file is missing. When it happens again I'm sure it will. I also have some files that avstodvd says when inputting them that it can't find the playtime... which are divx 5.0 and mp3 audio.
29th September 2008, 05:56 | #473 | Link |
Fighting spam with a fish
A couple of questions,
1) What do you use to encode to AC3? It doesn't appear to be aften, which I thought was supposed to be one of the highest quality encoders available. 2) Why do you always do a "LanczosResize(720,480,0,36,0,-36)" on all content? It crops away so much of the original content, and it is plain unnecessary. |
29th September 2008, 13:59 | #474 | Link | ||
AVStoDVD Dev
Bye |
29th September 2008, 14:16 | #475 | Link | |
AVStoDVD Dev
1) As it is written in the readme.txt file (and in the website homepage), AVStoDVD uses QuEnc as audio encoder, for both mp2 and ac3. Upgrade to Aften is in my ToDo list. 2) As a matter of fact I do not ALWAYS do that resize. Resizing routine is quite complex and it depends on the input stream frame height and width and on the output aspect ratio. <LanczosResize(720,480,0,36,0,-36> could come from a "almost" 4:3 input stream + a 16:9 selected output. Feel free to play with frame setups and you will see different resizings. Bye |
29th September 2008, 15:36 | #476 | Link |
The error is that the right after encoding, it doesn't get to the authoring part it just aborts on it own. That whats the log for..
<9/28/2008 7:56:30 PM> PROCESS ABORTED DURING DVD AUTHORING OPERATIONS. <-- It doesn't author... I get this error, yet I didn't abort it... u know what i mean? |
29th September 2008, 15:48 | #477 | Link | |
29th September 2008, 18:35 | #478 | Link |
@MrC
Thanks for your answers. I guess I was always seeing the Lanczos line because that is the input that I am working with. I will just have to be careful and edit it by hand. And I look forward to your Aften support!! |
30th September 2008, 09:28 | #479 | Link | ||
AVStoDVD Dev
Bye |
