2nd November 2012, 12:24 | #12742 | Link |
Its certainly possible something is screwed up in the build, i'll post a fresh test build when i get back to my dev PC in a few hours, the laptop doesn't have all the toys.
2nd November 2012, 13:35 | #12745 | Link | |
Broadband Junkie
If I were to take a guess, the softer luma/chroma either a result of VSFilter not snapping the edges of bitmaps to whole pixels, or possibly vectorizing the VOBSUB bitmap outline. I'll try to find out. That's probably the best solution. |
2nd November 2012, 13:42 | #12746 | Link | |
Not something i have on my plans =p
2nd November 2012, 15:23 | #12747 | Link |
http://www.mediafire.com/?w4b63h295st76np
LAV cant decode the TAK file. |
2nd November 2012, 15:46 | #12748 | Link | |
I suggest to report this as a feature request over at the ffmpeg trac, if you want it to be implemented eventually.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 2nd November 2012 at 15:51. |
2nd November 2012, 18:54 | #12750 | Link |
Here is a new test build, with all recent improvements to DVD menu rendering.
x86: http://files.1f0.de/lavf/LAVFilters-...9-gf0b33ee.zip x64: http://files.1f0.de/lavf/LAVFilters-...0b33ee-x64.zip Important fixes are: - A deadlock when navigating the menu on some discs, causing the player to freeze - Menu Overlays not updating on some discs - Wrongly positioned subs/menu overlays on some discs - Some subtitles staying on the screen for ever (actually fixed quite a while ago, just mentioning it again) I may create a release version after the weekend, still have to figure out what i want to finish for the next version. I appreciate any feedback on DVD behaviour, and if you have some broken menus on some discs, a sample of that would be great. You can extract the menu from a DVD by packing up all the ifo/bup files, and the video_ts.vob as well as any VTS_xx_0.VOB. The VTS files ending with zero are for the menu, 1 and above are content.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 2nd November 2012 at 18:56. Reason: linkified urls |
2nd November 2012, 22:42 | #12751 | Link |
Broadband Junkie
There is a seeking bug with subtitles. Sometimes the old line(s) being displayed before a seek, will still be displayed until the end of their duration after a seek, overlapping any new lines from after the seek. Somewhat hard to reproduce, yet it occurs more often when using the madVR FSE mode seekbar for some reason.
Misaligned chroma on uneven subtitles lines seems to be resolved now: LAV Video 0.52-39 NV12 Last edited by cyberbeing; 2nd November 2012 at 22:52. |
2nd November 2012, 22:58 | #12752 | Link | ||
When i seek using MPC-HCs seek bar, the DVD Navigator sends a proper BeginFlush/EndFlush sequence to the decoder. When i seek with madVRs FSE bar, it just starts sending frames from another point in time, it doesnt flush the decoder. This also causes image corruption for a few frames. I can probably make the old lines disappear if a new one comes up, but it doesn't look like i can make them disappear instantly. This is rather odd behaviour, i'm inclined to blame madVR for weird seeking. Quote:
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 2nd November 2012 at 23:13. |
2nd November 2012, 23:30 | #12753 | Link | |
the 2 files within are still using the old naming convention of ffmpeg avutil-lav-51.dll ---> should be avutil-lav-52.dll? avresample-lav-0.dll ---> should be avresample-lav-1.dll? |
2nd November 2012, 23:32 | #12754 | Link |
You must be seeing things, those zips contain the correct files. Both avutil-lav-52.dll and avresample-lav-1.dll.
3rd November 2012, 00:26 | #12756 | Link | ||
ffplay version N-45279-g1a104bf Copyright (c) 2003-2012 the FFmpeg developers built on Oct 10 2012 19:19:16 with gcc 4.7.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-pthreads --enable-runt ime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass - -enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-l ibfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libopenj peg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheo ra --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-li bvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --ena ble-zlib libavutil 51. 74.100 / 51. 74.100 libavcodec 54. 65.100 / 54. 65.100 libavformat 54. 31.100 / 54. 31.100 libavdevice 54. 3.100 / 54. 3.100 libavfilter 3. 19.102 / 3. 19.102 libswscale 2. 1.101 / 2. 1.101 libswresample 0. 16.100 / 0. 16.100 libpostproc 52. 1.100 / 52. 1.100 [tak @ 0238ece0] max_analyze_duration 5000000 reached at 5000000 Input #0, tak, from 'D:\Storage\Media\Codecs & Filters\TEST files\Audio\Across t he River_sample(2ch).tak': Duration: 00:00:25.50, start: 0.000000, bitrate: 770 kb/s Stream #0:0: Audio: tak, 44100 Hz, 2 channels, s16p
My hobby website |
3rd November 2012, 00:33 | #12757 | Link |
Yes and i have recently added support in LAV however the point was that it cannot play that particular file. It uses a type of encoding not implemented in the FFmpeg (yet)
3rd November 2012, 02:31 | #12759 | Link | |
3rd November 2012, 03:49 | #12760 | Link | |
Broadband Junkie
void CMainFrame::SeekTo(REFERENCE_TIME rtPos, bool fSeekToKeyFrame) ... else if (GetPlaybackMode() == PM_DVD && m_iDVDDomain == DVD_DOMAIN_Title) { if (fs != State_Running) { SendMessage(WM_COMMAND, ID_PLAY_PLAY); } DVD_HMSF_TIMECODE tc = RT2HMSF(rtPos); pDVDC->PlayAtTime(&tc, DVD_CMD_FLAG_Block | DVD_CMD_FLAG_Flush, NULL); PlayAtTime DVD_CMD_FLAGS Last edited by cyberbeing; 3rd November 2012 at 03:53. |
