13th June 2011, 16:17 | #3821 | Link | |
I installed v0.29 splitter/audio by clicking on the .bat files in the folder and then reset the media type lists for the audio decoder in Mpc-Hc. I noticed MEDIATYPE_DVD_ENCRYPTED_PACK does not appear in the allowed types, so I can only get DVD audio to work by manaully adding it. Have I missed something ?
4gb DDR3/AMD Fx6300 Windows 8.1, GT750ti, Auzentech Meridian 7.1, LG 42LN5400 4:4:4 1080P LCD TV |
13th June 2011, 16:19 | #3822 | Link |
Oh yeah, i noticed that before. Sorry, thought you meant that with "reset".
13th June 2011, 19:07 | #3824 | Link |
LAVAudio does not decode Vorbis in MKV with Haali as splitter. Is it just a missing mediatype?
Can you let LAVAudio store the format settings in a similar way as LAVSplitter? That is easier to use by external config apps.
MPC-HC 2.1.7.2 |
13th June 2011, 20:34 | #3826 | Link | |
13th June 2011, 21:14 | #3828 | Link | |
Thats a planned feature, but not yet supported.
13th June 2011, 21:29 | #3831 | Link | |
I can run a comparison myself and see if i can tweak the conversion algorithm a bit.
14th June 2011, 09:37 | #3832 | Link |
Hi Nevcairiel,
What do you think about talking : http://forum.team-mediaportal.com/756617-post607.html ? Thank you.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
14th June 2011, 14:00 | #3833 | Link |
FYI.
I asked shark007 to include LAV CUVID and LAV Filters in his codec pack and he says he will in his next release. And also Win7DSFilterTweaker v4.2 now supports LAV CUVID (thanks to clsid) and Codec Tweak Tool v4.9.5 supports LAV Filters. These utilities are useful to those who used WMP12/WMC as their main player. Last edited by ney2x; 14th June 2011 at 16:34. |
14th June 2011, 17:23 | #3834 | Link |
Found a small bug with TTA, the last buffer seems to be dropped at the end of playback. Don't know if this is a avformat problem or even avcodec problem. This problem is reproduceable with ANY .tta file I have. They were encoded with official ttaenc.exe, latest version.
14th June 2011, 19:09 | #3835 | Link |
Off-topic:
Is there a way to show subtitles like ffdshow subtitle placement/letterbox/vertical position 98% (bottom) And not like this DirectVobSub Note: Sorry, I don't know the right word for what I'm trying to achieve in DirectVobSub, is it video overlay??? Already tried to asked support in other thread but no one answering me. I decided to ask here cause people here are accommodating Last edited by ney2x; 14th June 2011 at 19:13. |
14th June 2011, 21:44 | #3838 | Link |
I have been starting to test the LAVF filters recently but have an odd problem with the audio.
All decoded audio gets distorted. I can hear the actual audio but with heavy distortion ontop. Bitstreaming SPDIF for AC3 and DTS works perfectly but not if I turn off bitstreaming and decode. I have so far only tested AC3 and AAC format. I have an old mainbord with Nforce 220 chipset and onboard Nforce MGP audio. FFDshow audio and other codecs have always been working so something seems to be up with my system and LAV Audio. LAVF splitter and FFDshow audio works so it must be the audio part where something strange occurs. What do you need from me to be possible to check this out? I have no clue even where to start looking. |
14th June 2011, 22:01 | #3839 | Link |
Both AC3 and AAC get decoded to floating point, some older audio drivers don't handle that properly. In a future version, you may be able to configure the desired output format.
You can confirm that this is the problem by simply going into the ffdshow audio config, and on the Output tab, unselect every format except 32-bit float. If you get the same distortions, thats the problem.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 14th June 2011 at 22:09. |
15th June 2011, 02:37 | #3840 | Link |
nevcairiel,
i have some blu-rays with multi-channel lpcm audio that my receiver (denon avr-1909) interprets as stereo ... mpchc + lavsplliter + lavaudio i had this working with reclock before (receiver showing multi channel something) in the status tab for lavaudio, i can see it sending 6 channels as output any idea what might be wrong ? |
