Old 2nd February 2009, 20:12   #1  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Source MPEG PS plays fine, demuxed result goes out of sync.
Hi folks,
I have a couple of sources that are giving me a hard time.
The sources are MPEG Program Streams, with MPEG-2 video, and Dolby Digital audio. They play fine in Media Player Classic and VLC, with no sync issues whatsoever.
However, when I try to demux the audio track, I get something that goes out of sync after a certain point. DGIndex and eac3to are my standard tools, but both produce the same result. I even tried transcoding the audio from the source using Avisynth and DirectShow + SoundOut, and got the same result!
I tried cutting a piece of this program stream using MPEG2Cut2, but this also goes out of sync!
Am I going insane? Any suggestions are welcome!!
Thanks in advance,
~MiSfit
Old 2nd February 2009, 20:16   #2  |  Link
Are they live captures with commercials? Sometimes the audio parameters change at commercials.
Old 2nd February 2009, 20:25   #3  |  Link
Blue_MiSfit
Hi neuron2,
No, these are 50mbps CBR captures from some sort of HD tape (comes from one of our partner encoding houses).
~MiSfit
Old 2nd February 2009, 20:48   #4  |  Link
Post a sample that includes a point at which sync changes.
Old 2nd February 2009, 20:58   #5  |  Link
Blue_MiSfit
Okay, uploading now. It's big... 320MB. Sorry about that, the point where it seems to go out of sync doesn't have much in the way of audio, so I included a large range to be safe. I'll update this post when it's completed.
http://www.megaupload.com/?d=XBCIHON0
Thanks!!
~MiSfit
Old 2nd February 2009, 22:36   #6  |  Link
madshi
You say you demux the audio. But what do you do with the video? Do you remux the audio to some other container? Along with the video? Or do you play the video inside of the original MPEG container while playing the audio externally? I'm asking because this could be a problem related to the source filters you're using for playback...
Old 2nd February 2009, 23:58   #7  |  Link
Blue_MiSfit
Madshi:
I've done it one of a few ways. The standard procedure is to process audio directly to a new AC3, then encode video (to H.264), then mux to a TS, which then goes through QA. This is where the problem was detected.
To diagnose the problem, I've completely demuxed the program stream, and remuxed with the original MPEG-2 video. I've also used the little trick in Media Player Classic where it loads audio tracks based on file names.
So for example, if meat.m2v and meat.ac3 are in the same directory, opening meat.m2v will also play audio from meat.ac3.
~MiSfit
Old 3rd February 2009, 02:07   #8  |  Link
Regarding your sample...
The video has jerks in it. Are you aware of that?
I don't see a sync discontinuity. To get the screeching of the train's stop at the beginning and the talking at the end in sync, I apply:
vid=MPEG2Source("MidnightMeatTrain_178_6ch_2008.d2v")
aud=nicac3source("MidnightMeatTrain_178_6ch_2008 T80 3_2ch 640Kbps DELAY 50ms.ac3",2).DelayAudio(-.700)
audiodub(vid,aud)
So I don't think the sync changes in the clip. But it does mismatch the delay declared by DGIndex. I'll have to study that in more detail.
Have you a sample where there is a discernible sync discontinuity? If not, then you can solve this with an appropriate audio offset.
Old 3rd February 2009, 02:47   #9  |  Link
Blue_MiSfit
neuron2,
Thanks for looking!
When you say "jerks", what exactly do you mean?
I'm uploading another (larger) sample that should be helpful, and seems to contain the sync change. When played normally this sample will be in sync.
When demuxed to M2V+AC3 with DGIndex, and played back, it will be out of sync by the end. The opening fight scene will be in sync, but the ending piece of dialogue - "please" will be clearly out of sync.
Apologies ahead of time for the excessive gore It's Lionsgate...
I'll make another post when I get in tomorrow morning and the sample is finished uploading.
Thanks for your time!
~MiSfit
Old 3rd February 2009, 03:05   #10  |  Link
I mean there are visible jerks. Single step and you can see missing frames -- discontinuous motion.
I like gore. Even if he was wrong about global warming. Bring it on.
Old 3rd February 2009, 03:48   #11  |  Link
Blue_MiSfit
Interesting find! I think it might be part of production... this whole scene is pretty disconcerting, what with the flickering lights and fast action.
~MiSfit
Old 3rd February 2009, 04:01   #12  |  Link
Waiting for your new upload...watching Family Guy while I wait.
Old 3rd February 2009, 05:22   #13  |  Link
Blue_MiSfit
I hope you have lots of episodes stocked up, because it's going to be tomorrow morning
Thanks again for your kind help!
~MiSfit
Old 3rd February 2009, 09:39   #14  |  Link
madshi
neuron2 is quite right with saying that video frames are missing. Here's the eac3to log when remuxing to MKV:
eac3to v3.06
command line: eac3to MidnightMeatTrain_178_6ch_2008.MPG test.mkv
MPG, 1 video track, 1 audio track
1: MPEG2, 1080p24 /1.001 (16:9)
2: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB, 51ms
[v01] Extracting video track number 1...
[v01] Muxing video to Matroska...
[a02] Extracting audio track number 2...
[a02] Removing AC3 dialog normalization...
[a02] Applying (E-)AC3 delay...
[a02] A remaining delay of -13ms could not be fixed.
[a02] Creating file "test - 2 - AC3, 5.1 channels, 640kbps, 48khz.ac3"...
[v01] Video has a gap of 2 frames at playtime 0:00:18.  <WARNING>
[v01] Video has a gap of 2 frames at playtime 0:00:19.  <WARNING>
[v01] Video has a gap of 2 frames at playtime 0:00:20.  <WARNING>
[v01] Video has a gap of 2 frames at playtime 0:00:21.  <WARNING>
[v01] Video has a gap of 2 frames at playtime 0:00:22.  <WARNING>
[v01] Video has a gap of 2 frames at playtime 0:00:24.  <WARNING>
[v01] Video has a gap of 2 frames at playtime 0:00:27.  <WARNING>
[v01] Video has a gap of 2 frames at playtime 0:00:30.  <WARNING>
[v01] Video has a gap of 2 frames at playtime 0:00:31.  <WARNING>
[v01] The MKV file was created without making use of the gap/overlap information.  <WARNING>
[v01] Please check whether audio is in sync. If it is in sync everything is fine.  <WARNING>
[v01] Otherwise ask eac3to to repeat the muxing. It will then automatically make  <WARNING>
[v01] use of the detailed gap/overlap information.  <WARNING>
Added fps value to MKV header.
Video track 1 contains 1272 frames.
eac3to processing took 9 seconds.
Done.
When I play the resulting MKV + AC3 file, audio gets clearly out of sync. However, if I let eac3to redo the MKV file timestamps to honor the gaps in the video stream, video and audio are in sync again when playing the MKV + AC3 combination.
So the problem is that the video stream is missing frames. If you simply demux the video, these missing frames mean that the video is too short compared to the audio. When playing the video in its original container, although some frames are missing, the timestamps in the container take care of that audio and video stay in sync. By demuxing the video track you're losing the timestamp information.
Make sure you get a proper stream from your encoding house and the problem should disappear automatically...
P.S: Damn, I should have waited with posting this, because now we might not get that bigger upload. Let me retract my statement. Hmmmmm... I think in order to analyze this problem, you need to upload the whole movie for us to look at...
Old 3rd February 2009, 14:48   #15  |  Link
Yes, madshi sounds spot on. But if Blue remuxed it, those timestamp discontinuities shouldn't be there (muxer rewrites timestamps) unless his muxer hosed up. Blue, what muxer did you use? Can you give us a cut of the original, unprocessed source, so we can see if the problem is in the source or you introduced it with your process.
Old 3rd February 2009, 14:57   #16  |  Link
madshi
As far as I understand the MPEG fragment we got is the original container coming from the encoding house?
Old 3rd February 2009, 14:59   #17  |  Link
If so, then case closed. I understood it the other way, but we'll soon find out.
"To diagnose the problem, I've completely demuxed the program stream, and remuxed with the original MPEG-2 video."
Old 3rd February 2009, 20:59   #18  |  Link
Blue_MiSfit
Hi all,
Yes, both fragments I posted were from the original, albeit cut with MPEG2Cut2, which I'm no expert in. I know it can alter streams quite a bit.
Here's the latest sample I uploaded last night:
http://www.megaupload.com/?d=KFRIRGUW
madshi, I'm still groking your findings.
So, you're saying that because there are missing video frames, the demuxed (or re-encoded) video will go out of sync after the point where the missing frames should have been, because this mux doesn't have the timestamps (pts, right?).
I'd be happy to provide it... but unfortunately our licensing agreement with the studio doesn't allow me to do this I'm sorry...
neuron2:
Right. I demuxed the program stream and remuxed it to a TS using TSMuxeR, and got a file that goes out of sync at the same place. This was just a sanity check to make sure nothing in my encoding chain was throwing a wrench into things.
I know it's an ugly workaround, but is there any way to extract these timestamps from the program stream, and include them in the mux of a transport stream containing H.264 and re-encoded AC3? Our in-house muxer has support for something like this.
The real question now becomes how 3 files on the same disk were corrupted like this. I've already ordered redeliveries, but WTH?
Thanks again for your help, gents!
~MiSfit
Old 3rd February 2009, 21:41   #19  |  Link
Don't use MPEG2CUT!!!!!
Use DGSplit to get an unaltered cut. Then upload that. It's not worth bothering with anything other than the original untouched stream. Really.
Old 3rd February 2009, 22:12   #20  |  Link
Blue_MiSfit
Ouch. I had no idea MPEG2Cut2 was such a bad idea
I'll do another upload with DGSplit.
Here's my guess on how to do it:
Cut ~900MB starting at ~81.1% of the total filesize - 81.1% being roughly where I started the previous sample with MPEG2Cut2 based on timecode, and hope for the best?
Sorry, I'm new to this app.
~MiSfit
