27th January 2016, 18:06 | #20263 | Link | |
I do notice on some scenes with vertical panning, there is a shimmering that occurs on edges here and there that are not as pronounced with yadif. Be interesting to see what you think.
Win7Ult || RX560/4G || Ryzen 5 |
27th January 2016, 18:39 | #20264 | Link |
How exciting! I can't wait to play around with this. I hope it beats out yadif, and CUVID hardware deinterlacing.
Thank you for the hard work, and innovation. Nevcairiel, you have my eternal respect. Same goes for madshi. Thank you! |
27th January 2016, 18:50 | #20266 | Link |
Software deinterlacing only works with 8-bit, always has. Don't encode such crap like 10-bit interlaced.
27th January 2016, 19:34 | #20268 | Link | |
28th January 2016, 01:12 | #20271 | Link |
Wow, I gotta say, that new deinterlacing is pretty damn sweet. I'm using complex right now. Combined with madvr's reconstruction, my TiVo recordings look incredible. Well done boys! P.S. And DAMN smooth.
28th January 2016, 04:54 | #20272 | Link |
The nightly builds available from https://files.1f0.de/lavf/nightly/ do not work with the latest Windows Insider preview 14251 released today. It fails with regsvr32 error 0x3.
Even when already installed and Windows is updated, the previously registered files no not work. However, build LAVFilters-0.65.0-24.exe and older installs and works perfectly, so the issue must be in LAVFilters-0.65.0-25.exe and later. I tried the .zip archive version of 0.67 as well, the files did not register with that either. Maybe there is a compiler issue/reason for it not working? I'm willing to test different compiles of the latest version to see if the issue is resolved. The issue is probably with the new build of Windows, but at least if the issue is isolated it can be reported correctly through the Windows feedback tool. LAV Filters seems to be the only program affected by it, so simply reporting that LAV Filters doesn't work and the circumstance that the issue not affecting any other program, may mean the issue goes unfixed before Windows 10 Redstone release later this year. That said, the issue may be with a change introduced with LAVFilters-0.65.0-25.exe that has only become apparent with the latest Windows build. Either way, I'm more than willing to test out different builds! Last edited by burfadel; 28th January 2016 at 05:38. |
28th January 2016, 10:38 | #20273 | Link |
0x3 means its missing some dependency (or some function from some dependency), you can use Dependency Walker to check what it may be missing.
That said, I'm not overly concerned with breakage in insider builds, there have been a lot of issues with the recent builds. 0.65.0-25 was a FFmpeg update, so if something changed it would appear to be in there.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 28th January 2016 at 10:46. |
28th January 2016, 13:19 | #20274 | Link |
I recently started testing using MakeMKV to rip DVDs to watch with better upscaling, but was disappointed in that none of the Deinterlacing, whether yadif or cuvid hardware adaptive (GTX 980 here on W7) seemed to be able to match the PS3's De-interlacing quality.
w3fdif doesn't seem to quite get there yet either. HW Adaptive DI from Cuvid still seems to work the best. Images. Same frame yadif http://u.cubeupload.com/MrBonk/mpchc201601280412047.png w3fdif http://u.cubeupload.com/MrBonk/mpchc201601280411032.png HW Adaptive http://u.cubeupload.com/MrBonk/mpchc201601280415355.png (Ignore glitches/repeated/dropped and render times) OSD shows DI is off, but I have it set to Force in LAV. Otherwise it doesn't seem to work. It is Interlaced and MediaInfo shows that it is. |
28th January 2016, 13:21 | #20275 | Link |
Most deinterlacers are designed for real-life video content, not animation, so they will usually not fare very well on that kind of content (too many sharp edges).
Note that DVDs might also be telecined, not interlaced, which a normal deinterlacer would not handle very well at all.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 28th January 2016 at 13:25. |
28th January 2016, 13:45 | #20277 | Link |
I experimented with it by turning off madvr deinterlacer. Image is a lot better. The 32bit really need some optimization though
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
28th January 2016, 14:03 | #20278 | Link |
The content has to be interlaced as using forced film mode(+Film mode deinterlacing) produces even poorer quality and constant judder with any camera movement (Where native 23.976FPS and 29.97 Progressive files and Video mode played back do not)
Screenshot of same frame with forced Film mode and Film yadif http://u.cubeupload.com/MrBonk/mpchc201601280448566.png Screenshot forced film mode and film Cuvid HW Adatpive http://u.cubeupload.com/MrBonk/mpchc201601280452128.png Turning all deinterlacing off, leaving on auto source detection and using only the "Inverse Telecine" option in NVCP while using Cuvid looks like this http://u.cubeupload.com/MrBonk/mpchc201601280454457.png But heavy interlacing and judder are still present in motion http://u.cubeupload.com/MrBonk/mpchc201601280454508.png Is re-encoding my only option to fix it really? I wouldn't mind. Is an encoding solution of higher quality? Last edited by MrBonk; 28th January 2016 at 14:07. |
28th January 2016, 14:19 | #20280 | Link | |
With only that set or video set and DI set to disabled in LAV. Same results. Judder, constant interlacing. OH I have to leave DI set to "Auto" in LAV and leave the other DI in that off and then set force "Film" mode. And shazam. Works perfectly. I'm such a dumb dumb. Thanks a lot! |
