10th June 2007, 14:19 | #101 | Link |
Professional Edition Version 1.26.0
Below is a summary of the changes/updates associated with this version (Pro release): Code:
June 10th, 2007 (v1.26.0) CHANGES MADE TO PRO VERSION - Added a new MODE called "Enable Bitrate Redistribution." It should be considered to be in Beta status (meaning it's there for testing -- bugs are possible). This feature is especially useful on sources that were not optimally encoded (such as CBR or on-the-fly broadcast encoding). It will perform an initial first pass using the OPV feature of CCE SP, HC, QuEnc, or AutoQMatEnc to redistribute bits across all segments using a constant base Q value, before doing the standard encode. This mode may also improve picture quality on sources that use a less than perfect bitrate distribution on the original source. Results of the redistribution can be reviewed by reading "REDISTRIBUTION.TXT" in the D2VAVS directory after PREPARE. - Added a hidden value for adjusting the size of the redistribution pass by setting the option "Redist_Percent=" in the "[Options]" section of the REBUILDER.INI file. The default value is 10. - Corrected a bug related to the implementation of matrices when using OPV and CCE SP2. - Updated several routines to better handle error conditions. - Enhanced the OPV routines to better select Q values under certain specific conditions. - Updated the multiplexing engine to better integrate audio when certain anomalies are encountered. - Fixed a rarely occurring bug related to closed captioning. - Other minor and cosmetic changes. Last edited by jdobbs; 10th June 2007 at 14:25. |
24th June 2007, 21:42 | #102 | Link |
Professional Edition Version 1.26.1
June 24th, 2007 (v1.26.1) CHANGES MADE TO PRO VERSION - Added a hidden setting in which you can instruct DVD-RB to redistribute bits across the entire DVD (including any parts considered to be extras and/or the feature). This can be useful for applying redistribution to episodic or series discs. You can enable the setting by adding "redist_all=1" to the "[Options]" area of REBUILDER.INI. - Updated the redistribution module so it follows the proper rules associated with PEAK_BITRATE - Added direct Luminance Gain adjustment to the HC Settings menu. - Added new code to the OPV prediction routines that should improve further improve Q selection and sizing. - Corrected a bug in which performing redistribution on ILVU sections could result in an error message. - Other minor and cosmetic changes. |
7th July 2007, 19:42 | #103 | Link |
Professional Edition Version 1.26.2
July 7th, 2007 (v1.26.2) CHANGES MADE TO PRO VERSION - Added additional routines to the REDISTRIBUTION code that corrects possible undersizing. Now, when a segment has been redistributed too many sectors(making it larger than the original) the size is adjusted and recovered sectors are reallocated to other segments. - Turned off HC VBV and scene detection (except for a 100% setting) during REDISTRIBUTION. This appears to have been slowing down the speed of HC redist on some systems. Also set HC to fast mode during the REDISTRIBUTION pass as it gives the same results. - Updated the REDISTRIBUTION menu options. You can now turn "Redist_All" on or off from the mode menu (formerly hidden). - Added code to perform REDISTRIBUTION for ProCoder and CCE Basic. HC (if installed) will be used for determining the bitrate redistribution pass. - Corrected an bug in which CCE SP2 could encode with the incorrect field order on BFF sources. - Other minor and cosmetic changes. |
4th September 2007, 20:40 | #104 | Link |
Professional Edition Version 1.26.3
September 4th, 2007 (v1.26.3) CHANGES MADE TO PRO VERSION - Fixed an error in which the REDIST_ALL parameter was not being set correctly when selected. In the previous version any change to the setting was not recognized until the next program load. - Added Beta support for command line oriented encodes (e.g. Mencoder or FFMPEG). DVD-RB will call a preconfigured .BAT file that can be setup for the calls. An example .BAT file (for mencoder) is included as an example. In order to use it, you must edit it (it is normally found in the "c:\Program Files\DVD-RB Pro\Encoders" directory) and ensure the path properly points to MENCODER.EXE. You must also add the line "cmdline=" to the "[Paths]" area of the REBUILDER.INI file. This new option should be considered in Beta test until it has been used more. My encodes (using Mencoder) so far tend to be undersized -- but very good quality. Try the "Good (fast)" mode, it gives very good quality and is exceptionally fast. Be careful with "Highest Quality" mode -- it can be slow. - Added an option to the MODE menu in which you can choose to always use HC as the encoder for REDISTRIBUTION. This prevents a rare CCE problem that can happen when high bitrate matrices are in use. - Updated REDISTRIBUTION so that any cell with 500 or fewer frames would redistribute using 100% sample. This prevents lower-than-required bitrates on small segments that have blackness or fade-ins that might undervalue the need. - Moved "Shutdown at REBUILD Completion" and "Close DVD-RB at REBUILD" completion from the MODE menu to the FILE menu. This makes it possible to change the state of these options while DVD-RB is executing. - Corrected a bug in which, under certain circumstances, it is possible to receive a "Runtime Error 53" message during REDISTRIBUTION. - Corrected an minor bug in which bitrates for single frame segments were incorrectly REDISTRIBUTED. - Corrected an error in which attempting to use the "No Compression" encoder option with REDISTRIBUTION enabled could cause DVD-RB to abort with errors (87/13) - Updated the response to errors resulting from a corrupt source (VOBID/CELLID not found errors) so you have the option to continue as opposed to a forced exit. Note however that it is not usually a good idea -- as this is an indicator of a pretty serious corruption in the source IFO/VOB combination. - Other minor and cosmetic changes. Last edited by jdobbs; 5th September 2007 at 18:22. |
8th October 2007, 01:35 | #105 | Link |
Professional Edition Version 1.26.5
October 7th, 2007 (v1.26.5) CHANGES MADE TO PRO VERSION - Added a REDISTRIBUTION threshold test that limits the amount of low-side deviation allowed in the calculation of redistribution. The default value of .5 limits a bitrate reduction (in redistribution) to half what would have been given in a standard DVD-RB encode. This dramatically reduces the likelihood of getting values that are too low in dark scenes. The threshold can be adjusted via a hidden setting in the OPTIONS area of REBUILDER.INI. The value (REDIST_LOW_THRESHOLD=) must fall in the range of 0 to 1. Any other value results in the default of .5 - Added a "hidden" setting called "REDIST_USE_FINAL_Q". If set to 1 (REDIST_USE_FINAL_Q=1) in the "[Options]" area of REBUILDER.INI, a set of prediction passes are run on the main-movie VTS (largest) to determine a Final_Q value that is used for REDISTRIBUTION rather than the standard Base_Q. This will add a little time to the PREPARE phase and some reports have been made of improved quality based upon subjective analysis. - Corrected an error in which pushing the ABORT button could, under certain circumstances, leave an encoder executing in the background until it completes its current task. It might also result in a "Could not clear output..." error if an attempt to restart encoding happens too soon. - Updated "Batch Mode" so that it will, when appropriate, write to blank disc. Note that you must (obviously) change discs between writes in order to write more than one during the batch process. - Added a separator bar to the FILE menu to distinguish the "Shutdown on REBUILD" functions from those related to Batch. - Added code to limit the sample size to 1% when performing REDISTRIBUTE_FINAL_Q analysis. Any more is simply a waste of time. Note this does NOT affect the percentage used for determining REDISTRIBUTION -- only determining FINAL_Q. - Corrected two bugs that were introduced in v1.26.4 (which was released as a beta only). - Other minor and cosmetic changes. |
5th January 2008, 17:47 | #106 | Link |
Professional Edition Version 1.26.6
January 5th, 2008 (v1.26.6) CHANGES MADE TO PRO VERSION - Corrected a bug in which the MPEG2DEC_OPTS parameters were not being applied during Q analysis. This could, in some cases, result in an error. - Added code to MOBILE encoding to prevent identical PGCs from being reencoded redundantly (duplicates). - Added more granularity to the matrix selections. Now you can choose matrices for High (4000Kbs), MedHigh (3500), Med (3000) in addition to those already selectable. - Corrected an error in which having CCE SP2 installed by itself did not activate the "CCE Mode" under the ENCODERS menu. - Fixed an error in which loading a project file would not reset the "HC_FOR_REDIST" flag. - Fixed a bug in which the OPV subroutine could cause a size error caused by an incorrect maximum bitrate. This could also cause anomalies in REDISTRIBUTION passes. - Added code to adjust for an issue in which audio sync could be off for MOBILE encoding for some oddly formatted discs. - Changed the MOBILE settings so that any specified bitrate less than 50 is considered a Q value rather than 31 (for compatibility with H264 Q values). Illegal values on codecs that accept no more than 31 are automatically limited. - Added NicMP4Box.exe to the full (MOBILE) installer package. This allows DVD-RB to create H264 files (using FFMPEG) in the MOBILE encoding mode that are compatible with the IPOD. NicMP4Box is called automatically when the IPOD_H264 codec is selected. - Added two new profiles to the MOBILE.INI file. These allow you to take advantage of the H264 (high quality) format when creating output for the IPOD. Say "yes" to overwriting your MOBILE.INI file in order to see the new profiles. - Updated the installation package to include HC Encoder v0.22 which includes several improvements over previous versions. - Updated the installer to include ECLPRO v1.11. - Other minor and cosmetic changes. Last edited by jdobbs; 5th January 2008 at 18:33. |
14th February 2008, 23:50 | #107 | Link |
Professional Edition Version 1.27.1
(v1.27.1) - Corrected an error introduced in version 1.27 that would cause serious audio muxing problems. - Fixed a source of a possible "Runtime Error 6" (v1.27.0) - Fixed an error in which the path for NicMp4Box.exe was not being automatically detected. - Updated routines so that when DVD-RB is running multiple instances of HC Encoder the "*NOSMP" setting is used. This has been tested to show faster processing on DVD-RB -- as it already takes advantage of multiple processors. - Update the HC interface so it specifically indicates whether a file should be encoded as "*PROGRESSIVE or "*INTERLACED". - Modified the REDISTRIBUTION and OPV prediction code for HC Encoder. It should now take fewer passes for prediction in most cases. - Added a check for illegal characters in VOLUME_ID. This condition could cause a failure to create an ISO image. - Updated the "Close DVD-RB at batch completion" function so it "sticks" between runs. Now the setting remains in effect until reset. - Wrote code to circumvent a source of "Runtime Error 52" errors during the file copy section or "Buffer Overflow 0003" in the REBUILD phase on certain types of corrupt sources. - Made handling of certain sources that fall outside standards more robust. - Updated D2V creation routines to assume BT.601 colorimetry where no SEQUENCE_DISPLAY_EXTENSION is present. Added a "hidden" option called "BT601_DEFAULT=0" to the "[Options]" area of REBUILDER.INI. This option can make DVD-RB assume all unspecified streams to be BT.709 instead. This is mainly for non-DVD sources. The default value is "1" (BT.601 is the assumption). - Added an additional filter prefix. When prefixed by "b:" a filter is added only when the source colorimetry is BT.709 (including SMPTE 240M). This enables cases where you wish the output to be converted, for example to BT.601. This option is similar to "c:" but has an opposite effect. - Corrected an error in which One Pass Encoding could, under certain rare circumstances, select an incorrect Q/CQ value and as a result over or undersize. - Corrected an issue that could slow processing considerably when a combination of encoding and extracting is occurring. - Cleaned up a cosmetic glitch in which sometimes the "Overall Progress" bar didn't correctly show status during ENCODE. - Fixed an error in which Final_Q could not be calculated with QuEnc or a command line encoder (that supports CQ). - Improved the interface for CMDLINE encoding -- now the CQ is passed as a floating point variable for more accurate sizing during one-pass and REDISTRIBUTION. - Modified the default values for PFactor and BFactor when running HC Encoder in One Pass CQ mode. - Improved the CMDLINE encoder interface so that it now also passes "Closed GOP" (for ILVU) and "Bottom Field First" (for interlaced encoding) information to the encoder. - Made some small changes to the QuEnc interface to restore FreeEnc compatibility. - Added multiple threading capability to the MOBILE encoding command line. This will speed up processing substantially for those with multiple processors (e.g. dual/quad cores). - Added additional checks to for encoders. Prevents encoders from being enabled when they don't really exist. - Other minor and cosmetic changes. Last edited by jdobbs; 15th February 2008 at 17:47. |
24th February 2008, 18:53 | #108 | Link |
Professional Edition Version 1.27.2
February 24th, 2008 (v1.27.2) CHANGES MADE TO PRO VERSION - Added a new hidden setting called "HC_NOSMP" to the REBUILDER.INI file. Setting "HC_NOSMP=1" (the default setting) disables the use of SMP when multiple instances are used. "HC_NOSMP=0" will allow SMP to run. Generally the default (No SMP) is faster when run with multiple processes, the parameter is provided to let the user make the ultimate choice. - Added a "Use *AVSRELOAD Parameter" option to the "HC OPTIONS" menu which will add that value (useful for certain scripts) to the INI files passed to HC encoder. - Reversed the v1.27.0 implementation that waits for an encode to complete before extracting. It appears to slow down encodes on some systems. Go figure. You can still enable this feature, however, by adding the hidden option "WAIT_FOR_EXTRACT=1". - Corrected an error in which the new matrix types were not being saved in template files. - Made adjustments to the sizing mechanism for Movie Only encodes to prevent certain circumstances from resulting in undersizing on seamless branching sources. - Updated the SCR insertion routine to handle exceptionally high SCR values. - Updated code to make it more compatible with emulation such as running under Linux/WINE. - Adjusted build options to correct for a "crash" that was reported by some users on the previous release. - Other minor and cosmetic changes. |
27th March 2008, 21:57 | #109 | Link |
Professional Edition Version 1.27.3
CHANGES MADE TO PRO VERSION - Added a "Use *LOSSLESS Parameter" option to the "HC OPTIONS" menu which will add that value (useful for speeding up certain scripts) to the INI files passed to HC encoder. Note: Only works with HC v0.22.1 or greater. - Updated the ISO creation module so that now the ISO will be created by ImgBurn rather than MKISOFS if ImgBurn is installed and is of a high enough version to support it. - Modified the HC calling module so that encoder priority is set explicitly (based upon the option) in the HC.INI file (HC v0.22 and higher). - Corrected so that REDISTRIBUTION doesn't take effect when "MOBILE Only" encoding is selected (it is not used in that situation). - Changed the "CORRUPT SOURCE" error message to a warning and removed the annoying popup message. Some rippers remove CELLs as needed from the VOB (usually junk cells related to protection) without removing the reference to the CELLS in the IFO(s). - Built a workaround for movie-only PGC selection in discs that have incorrect information in PGC tables. - Corrected an error in which the batch shutdown had stopped working since v1.27.0. Note also, that the setting for batch shutdown is also now saved in the INI and will "stick" between runs. Older version required setting it before all batch runs. - Corrected an issue related to Vista in which running in "Multiple Encoder Processes" mode could cause HC and other encoders to fail with "Failed to find and run encoder..." This was caused by Vista's "improved" security. - Modified loop checks during ILVU extraction in MOBILE encoding so the extraction stops more quickly if "Abort" is selected. - Changed the actions for unload queries to make DVD-RB a bit more robust in the event of problems. - Added additional checks to ensure CCE paths are correctly configured. - Updated the codes so that NICAUDIO.DLL doesn't have to be explicitly called out in the REBUILDER.INI file for use in MOBILE encoding. - Other minor and cosmetic changes. |
12th July 2008, 19:08 | #110 | Link |
Professional Edition Version 1.28.2
CHANGES MADE TO PRO VERSION - Made numerous changes to make DVD-RB more sensitive to the security environment of Vista. - Made changes to make DVD-RB more compatible with some windows emulators. - Added support for the HC adaptive quantization (*AQ) function. This setting can improve picture in flat parts. A default value of "2" is used, but can be changed by setting "HC_AQ=n" in the "[Options]" area of REBUILDER.INI. "n" can be any integer value between 0 and 4. "0" disables AQ and "4" results in lower quants. Note: Keep in mind that due to virtualization associated with VISTA, your most current INI may be located in the VISTA VirtualStore. One easy way to get to it (if you are using VISTA), is to create a shortcut on your desktop that points to it. - Added a parameter to the HC SETTINGS menu that enables and disables LOGGING when encoding with HC encoder. The log will be written to a file named "HCLOG.TXT" in the working directory. - Included HC Encoder v0.23 in the installation packages. This version includes extended features and bug fixes. - Added ability to have different 1st and 2nd passes when using MOBILE encoding (see the MOBILE.INI template under the AVCHD beta for an example. - Added a "hidden" option called "ImgBurnDest" that, when added to REBUILDER.INI will force the write to a specific drive. This is expecially useful when working on a computer that has more than one writable drive. As an example, to force output to the "F:" drive you would add "ImgBurnDest=F:" to REBUILDER.INI. - Modified the TEMPLATE commands so they automatically look in the VirtualStore for templates. - Corrected "35601" error that could happen (very rarely) on sources with no audio. - Added a parameter to the REBUILDER.INI file so that an alternate AVISYNTH resizing algorithm can be used for certain functions (e.g. converting from 4:3 widescreen to 16:9 anamorphic). The default is "LanczosResize". Example usage: "RESIZE=Spline36Resize" Note: Adding an incorrectly spelled resize parameter will cause your encoding to fail. - Other minor and cosmetic changes. |
