Old 23rd September 2018, 14:15   #621  |  Link
shekh
Originally Posted by davidhorman View Post
3. Centered, borderless. custom background colour
Tell me you don't find #3 just a little bit sexy...
Mock looks good, I will think
VirtualDub2
Old 25th September 2018, 19:49   #622  |  Link
imhh11
which one is better ?
MagicYUV or Cineform?
cineform compress a lot more but how is the quality compared to magicYUV and uncompressed ?
imhh11 is offline   Reply With Quote
Old 25th September 2018, 20:17   #623  |  Link
shekh
It seems there better places to compare codecs but at least what do you need it for in VD2?
VirtualDub2
Old 25th September 2018, 20:24   #624  |  Link
imhh11
V210 capture
Old 25th September 2018, 20:59   #625  |  Link
LigH
LigH's Avatar
If any codec compresses "a lot better than" a lossless codec, then it is probably lossy. All lossless codecs will have a similar strength, and compared to uncompressed video with the same color space and depth, the ratio is hardly better than 1:5 in optimal cases, rather around 1:2.5 to 1:3.
The Ut Video Codec Suite is also very efficient and very versatile, supports many sample formats.
New German Gleitz board
Old 25th September 2018, 21:06   #626  |  Link
shekh
V210 capture
humble suggestions:
If you don't need lossless for some sensitive restoration, you can use near-lossless (cineform)
Also if you have enough cpu power, maybe you can get even better storage-quality ratio using x264-10bit (enable zerolatency)
VirtualDub2
Old 28th September 2018, 14:11   #627  |  Link
WorBry
I've never used VDub(2) for capture per se, but based on my experience transcoding uncompressed 10-bit 422 sources I'm confident that Cineform at 'Film Scan 2' quality would be way, way beyond 'visually lossless' and very close to arithmetically lossless.
What are you planning to do with your captures btw? IMHO, far more important is the compatibility of the capture format with the video systems you use, or are intending to use for subsequent processing. Does the import interface preserve high-bit depth transfer, assuming said system does support high bit depth processing? How does the system handle luminance ranges on import with that particular format - very important to determine the behavior, especially if the system does not have native (SDK implementation) Cineform support ? Process performance in/through said system ? And can you export in the same format, if that is desirable - in which case similar considerations apply with respect to bit-depth transfer and luminance handling at export?
My two cents.
Nostalgia's not what it used to be
WorBry is offline   Reply With Quote
Old 29th September 2018, 19:05   #628  |  Link
imhh11
thank you guys!!!
I don't think I see a difference in quality between the 2 codecs. Maybe when I zoom in, I can see that magicyuv is slightly better. So Cineform compression should be enough for me.
MagicYUV(766mbps) Vs Cineform(332mbps)
http://screenshotcomparison.com/comp....php?id=116034
MagicYUV(766mbps) Vs Cineform(183mbps)
http://screenshotcomparison.com/comp....php?id=116035
once encoded to hevc 25mbps:
http://screenshotcomparison.com/comp....php?id=116040
Old 29th September 2018, 19:49   #629  |  Link
shekh
There is small color difference, probably different matrix at some step (709 vs 601). Something to be aware of.
VirtualDub2
Old 29th September 2018, 20:28   #630  |  Link
WorBry
Out of interest, what Cineform quality settings did you use in the two shots ?
Old 30th September 2018, 01:03   #631  |  Link
imhh11
strange both were encoded x265 with the same setting in HDR BT2020 (DCI-P3).
after comparing with the source (untouched), the colors match magicyuv and cineform is slightly different. I wonder why, both are 422 10bit v210 capture of the same file.
film scan 1 & 3 but I'm not sure, I did the comparison a couple months ago and wanted the opinion of the doom9 experts :P
Old 30th September 2018, 02:54   #632  |  Link
imhh11
Also, sorry if its a stupid question but could it be possible to add NVenc to Vdub ? my cpu can handle x264 encoding while capturing but at very fast or worse preset only and im mostly interested in HEVC for HDR.
of course my cpu cannot handle x265 in vdub but encoding h265 with nvidia should be fast enough ? or is it already possible and i dont know about it ?
Old 30th September 2018, 09:52   #633  |  Link
sneaker_ger
You can use the "External Encoders" (see VirtualDub help) feature of VirtualDub (both vanilla as well as VirtualDub2) to use NVEnc while doing "normal" encodes. For capturing I think there is no solution for VirtualDub, currently.
Old 30th September 2018, 11:48   #634  |  Link
shekh
NVenc: there is no way for capture now, and not coming soon.
VirtualDub2
Old 30th September 2018, 17:26   #635  |  Link
WorBry
...both were encoded x265 with the same setting in HDR BT2020 (DCI-P3).
Ah, OK, so these are HDR captures ? I was hesitant about mentioning your shots looked rather underexposed
film scan 1 & 3 but I'm not sure.
Filmscan 3 is way overkill. It's a 'special' mode that is not available with the (GoPro) Cineform VFW codec and, to my knowledge, in other native implementations of the Cineform SDK:
https://forum.doom9.org/showpost.php...4&postcount=45
Old 30th September 2018, 17:58   #636  |  Link
imhh11
yes HDR capture colors are triggered at x265 encoding. I captured a UHD-BD just to make sure I get proper colors/hdr etc.. now that I know that magicyuv works (at least when I compare 2 frames tone mapped with madvr), i can now capture my games in high-quality 4K HDR properly. Too bad cineform slightly change the colors, it would have saved tons of space(only have 1tb of capture space).
thanks for the filmscan 3 explanation, I didn't know that.
*sorry for my english
Old 30th September 2018, 19:31   #637  |  Link
WorBry
yes HDR capture colors are triggered at x265 encoding..... Too bad cineform slightly change the colors, it would have saved tons of space(only have 1tb of capture space)
I've no experience in that domain. Maybe others can help. It's surely color matrix related.
Old 30th September 2018, 19:56   #638  |  Link
shekh
I doubt it is cineform that is guilty in this case. What software was used to do the encode to x265? Because you said it is encoded with DCI-P3 I assume there was (different) color conversion. How it is possible:
1) magicyuv+avi has no metadata at all -> everything default.
2) cineform+avi has some metadata -> replaces defaults (not same).
Just guessing.
VirtualDub2
Old 30th September 2018, 23:18   #639  |  Link
imhh11
ok, I did another comparison because the other one was 3 months old so maybe I did something wrong. This time, I don't see a difference in the colors, can you?
MagicYUV RAW VS Cineform RAW filmscan 2
http://screenshotcomparison.com/comparison/121674
once encoded with exactly the same setting/ software: x265 Staxrip the GUI (source is dci-p3, encode is dci-p3) :
MagicYUV VS Cineform
http://screenshotcomparison.com/comparison/121673
MagicYUV VS Source
http://screenshotcomparison.com/comparison/121672
Cineform Vs Source
http://screenshotcomparison.com/comparison/121671
x265 2.8+19-bcdc610cf5f0:[Windows][MSVC 1914][64 bit] 10bit
/ wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=723 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / radl=0 / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=3:3 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=22000 / qcomp=0.70 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1) / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-mv-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei
here's the files:
https://uptobox.com/vs384dq3ssci
Format : CineForm
Codec ID : CFHD
Codec ID/Info : CineForm 10-bit Visually Perfect HD (Wavelet)
Duration : 30 s 989 ms
Bit rate : 426 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Scan type : Progressive
Bits/(Pixel*Frame) : 2.144
Stream size : 1.54 GiB (100%)
Format : M0Y2
Codec ID : M0Y2
Duration : 31 s 490 ms
Bit rate : 870 Mb/s
Bits/(Pixel*Frame) : 4.373
Stream size : 3.19 GiB (100%)
Old 30th September 2018, 23:37   #640  |  Link
shekh
ok
ps. I don't get it, you ask which codec, and then show test which is 3 months old. Why
Out of curiosity, what hw you use for capture? From which source?
