12th January 2016, 00:24 | #35161 | Link | |
a telecine source is still technically an interlaced source. interlacing is very confusing. madVR film mode is a detelecine filter/reserve telecine filter alias IVTC. it only works on telecine sources. madVR video mode is an deinterlance filter it should work on all sources but quality may vary a lot. telecine is just a way to create a interlaced source by using telecine. the telecine can be reversed. this type of interlacing is used to create 50/60i from 24/25p. IVTC can reverse this type of source back to 24/25p a source that is interlaced but doesn't use telecine can't be handle by Film mode and can't be reversed. there are no information to recreate the original progressive frames so new progressive frames are created. this type of interlacing is used to create 50/60i from 50/60p. all deinterlacer or IVTC algorithm create progressive frames. an modern deinterlacer may try to use IVTC for better results too but they can't match a normal IVTC algorithm for multiply complicated reasons. this may help or just confuse you even more: https://en.wikipedia.org/wiki/Interlaced_video https://en.wikipedia.org/wiki/Telecine https://trac.handbrake.fr/wiki/Telecine there are still special types of interlacing making it even more complicated. |
12th January 2016, 00:29 | #35162 | Link | |
12th January 2016, 00:31 | #35163 | Link |
I've found an issue with madvr 90.1 . With potplayer if you minimize the window and open it, the video freeze but the sound continues . to start the video again you need to enter FSE.
89.xx works fine . tested in both windows 8.1 and windows 10 . different drivers , 970GTX and 970M laptop , Madvr +FSE D3D11 + 10bit |
12th January 2016, 00:33 | #35164 | Link |
I managed to crash madvr v 0.90.1. Pastebin of the error dump is here:
http://pastebin.com/fqKG6L3a I was just doing some regression tests with nvidias stereoscopic 3d mode enabled in trying to get the situation down pat for my nvidia bug report. Most of the time I dont get madvr crash reports where MPC-BE crashes instead, but this time it did happen. |
12th January 2016, 00:57 | #35165 | Link |
The strange freeze bug happened again. Some more info. MPC-HC froze up almost completely, with a slice of audio being played every 4 or 5 seconds. Ctrl-J did not do anything. Pause-Resume fixed the audio only. Audio started playing again but video continues to be frozen.
The log is here: http://pastebin.com/LAUrQ3Eg |
12th January 2016, 01:30 | #35166 | Link |
nevcairiel, madshi - I found the reason that 3D is not working, LAV Video can't load libmfxsw32.dll/libmfxsw64.dll from installed path (C:\Program Files (x86)\LAV Filters). CDecMSDKMVC::Init() output CDevMSDKMVC::Init(): MSDK not available and out with error.
When i copy this .dll to C:\Windows - all working, thanks
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
12th January 2016, 02:03 | #35167 | Link |
are you using windows 10?
in my experience the "C:\Program Files (x86)" folder has special needs on win10 different from windows 7/8 but i don't have a system to test this. if yes. is possible for you to install lav to something like "d:\lavfilter" and test it without the DLL in the windows folder? |
12th January 2016, 02:42 | #35168 | Link | |
12th January 2016, 03:03 | #35169 | Link |
Well, I'm not having a lot of success so far. I originally tried to get this to work in MC21 and when I enable 3D in the nVidia control panel or in Windows Display settings and try to play a 3D MKV, it crashes the player. So I figured I'd simplify my life while testing and get MPC-HC set up and I'm having the exact same problem. Crashing culprit is c:\windows\system32\nvwgf2um.dll which presumes it's dying in nVidia land somewhere. I also copied the intel DLL to my Windows dir (thanks for that tip) so it's finding the DLL ok, but, something is not very happy on my machine. Windows 10, nVidia 680, nVidia 361.43 driver installed. Any magic tricks I can try to get this to work? I'm VERY excited by this 3D development. I know a lot of people couldn't care less about 3D, but, I have a good setup for it and quite the collection of 3D blu-rays I'd love to convert to MKV. Thanks for the help!
12th January 2016, 03:18 | #35170 | Link |
I've not got 3D working in JRiver MC either yet.
On the crash, when I "reset" the MadVR settings it sovled the crash, I then started re-enabling stuff and for me it is the D3D11 mode that seems to cause the crash. I'm also nVidia (660Ti) Windows 10 64-Bit |
12th January 2016, 04:11 | #35171 | Link | |
thanks |
12th January 2016, 04:28 | #35172 | Link | |
12th January 2016, 04:50 | #35173 | Link |
Copying the DLL into the Windows folder "almost" works for me.
Now I can see my TV do the Black Screen with change of Refresh rate thing but oddly it seem to happen a couple of time (and the TV complains about losing the HDMI connection in the middle). When the image comes up madVR is using D3D9 not D3D11 and I get a Side By Side image. |
12th January 2016, 05:47 | #35176 | Link |
Huhn I can see that test result too. I believe mate it happens when you have correctly installed the Intel media sdk DLL, but a user has not correctly enabled stereoscopic mode in their nvidia control panel. I see the exact thing, side by side, by doing so and Ive done my own remux from one of my 3D blurays using MakeMKV
12th January 2016, 06:04 | #35177 | Link |
Does anyone have smooth 3D playback on a Haswell or later NUC? My 2D content works great on it, but 3D is very jerky. The processor is showing minimum utilization so I am wondering if the GPU is maxed out with 3D content.
12th January 2016, 06:22 | #35178 | Link | |
I am the one who knocks
btw, I can confirm that the interlaced ProRes is fixed, thanks. Film mode doesn't support such files yet, right? |
12th January 2016, 06:23 | #35179 | Link |
problem sovled!, I just set madvr disable 3d when playback 3d,then the picture become SBS, I just need to choose SBS 3D in my monitor, works perfect!
----edit---- After copy libmfxsw32.dll/libmfxsw64.dll to c:\windows,3d playback works,still get some crashes,and only left eye image ----edit---- 3d playback doesnt work on my pc same as before. If I enabled 3dvision in nv contorl panel,when madvr goes fullscreen crashes every time,windowed no stereo effect. madvr cant enable/disable 3d, everytime I have to change settings in nv control panel. Here's my debug log http://www.mediafire.com/download/dy...madVR_-_log.7z Last edited by 4h4h270; 12th January 2016 at 06:50. Reason: problem solved~ |
