Old 24th July 2015, 02:20   #1  |  Link
Ninaz
Vapoursynth AddBorders with StaxRip
I’m familiar with the Avisynth function (script?) “AddBorders(0, 86, 0, 86, $000000)”. Using this in Vapoursynth creates a Python error, saying there’s an invalid syntax. Understandably you may say.
Vapoursynth docs indicates the Avisynth equivalent as “std.AddBorders” or “std.AddBorders(clip clip[, int left=0, int right=0, int top=0, int bottom=0, float[] color=<black>])”.
My feeble attempts have not resulted in a positive.
Not understanding how to write this properly, I have to ask if someone would kindly help.
Ninaz is offline   Reply With Quote
Old 24th July 2015, 02:58   #2  |  Link
Reel.Deel
Here's an example on how to use AddBorders:
import vapoursynth as vs
core = vs.get_core()
src = core.std.BlankClip(color=[255, 255, 255])
src = core.std.AddBorders(clip=src, left=0, right=0, top=86, bottom=86, color=[0, 0, 0])
src.set_output()
Unlike AviSynth, the color values are not specified in hex.
Old 24th July 2015, 04:54   #3  |  Link
Ninaz
Thanks for your assistance.
Adjusted top and bottom numbers and loaded your code into StaxRip’s Scripting Editor, and got the following error:
Python exception: name 'core' is not defined
Traceback (most recent call last):
File "vapoursynth.pyx", line 1467, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:24719)
File "N:\Rips\TS00852\TS00852 temp files\TS00852_new.vpy", line 1, in <module>
core.std.LoadPlugin(r'N:\Portable\StaxRip\Apps\Plugins\both\ffms2\ffms2.dll')
NameError: name 'core' is not defined
Any ideas?
Old 24th July 2015, 05:08   #4  |  Link
feisty2
I'm Siri
feisty2's Avatar
feisty2 is offline   Reply With Quote
Old 24th July 2015, 09:57   #5  |  Link
stax76
stax76's Avatar
you have to use clip instead of src, I might be able to remove this restriction, profiles use clip and core as variable names.
clip = core.std.AddBorders(clip = clip, left = 0, right = 0, top = 86, bottom = 86, color = [0, 0, 0])
maybe you are interested in what a AviSynth profile might look like:
[Borders]
AddBorder1080 =
	w = (1920 - width) / 2.0
	h = (1080 - height) / 2.0
	AddBorders(floor(w), floor(h), ceil(w), ceil(h))
Old 24th July 2015, 23:33   #6  |  Link
splinter98
Technically not 100% true, Python supports 0x hex notation and will automatically convert it into decimal, so: [0xFF, 0xFF, 0xFF] is the same as [255, 255, 255] so if you're converting Avisynth scripts you don't have to do the hex conversion.
It's also good to note that the color parameter replaces both color and color_yuv in blank clip in Avisynth. Vapoursynth will use the RGB if the format is an RGB format, YUV if it is a YUV format, and Grey if it is a single channel clip.
The other thing to be aware of is the color number is also related to the bit depth of the clip, so 8bit clips will have 255 as white (or 235 for limited range), 10bit clips white is 1023, 16bit clips is 65535 and 1.0 for float. So if dealing with high bit depth clips using 8 bit colors will not work and will need to be converted to the correct format.
This information is lacking in the documentation, and should be added.
splinter98 is offline   Reply With Quote
Old 25th July 2015, 00:21   #7  |  Link
Reel.Deel
@splinter98
Thanks for that informational post, I did not know that. Yes, some parts of the VapourSynth documentation can be a bit vague, especially for us that are not Python experts.
Old 25th July 2015, 01:24   #8  |  Link
Ninaz
Thanks Stax76, your code worked beautifully and seems more straight forward (in my mind). Is it specific to StaxRip?
I know there seems to be more interest in cropping than adding borders. Have you considered adding a Border Menu alongside Aspect Ratio and Crop within Image Options?
Thank you so much for helping and for everyone’s patience with a non-coder.
Old 25th July 2015, 09:05   #9  |  Link
jackoneill
unsigned int
jackoneill's Avatar
@splinter98
If you point out something specific, I'll be happy to fix it.
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 25th July 2015, 16:52   #10  |  Link
splinter98
A summary of my previous post in BlankClip and AddBorders (and any other filter that uses the color semantics) would be useful to add.
Old 25th July 2015, 17:41   #11  |  Link
Ninaz
Border color is dark green. Everywhere I look [0, 0, 0] is black and black is what I want. I've also entered different numbers and preview is always dark green. I don't understand.
When using the Avisynth code, $000000 is black and I get black.
Old 25th July 2015, 17:51   #12  |  Link
splinter98
You're falling into the pitfall of the clip format is yuv. (you'd get the same issue in AviSynth if you used color_yuv=$000000 instead of color=$000000).
color defaults to black if it isn't set, but for YUV it should be: [0, 128, 128]
Old 25th July 2015, 21:04   #13  |  Link
Ninaz
BANG ON!
Thank you, thank you
Old 26th July 2015, 02:29   #14  |  Link
feisty2
I'm Siri
feisty2's Avatar
that depends, actually, it's still [0, 0, 0] for float YUV clips...
Old 26th July 2015, 19:16   #15  |  Link
splinter98
If the YUV colour space is actually Y'CbCr yes. (as Cb, Cr are in the range -0.5 to 0.5 and not 0 to 1).
EDIT: Actually no my mistake, Integer YUV types are shifted by (2^bitdepth)/2 to make all the numbers positive.
Last edited by splinter98; 26th July 2015 at 19:29. Reason: Correct my previous error
addborders, vapoursynth
