Old 3rd August 2020, 20:19   #1  |  Link
desktop_ready
FFmpeg and h264_vaapi
Hello,
Not sure if this is the right forum.
I have an Intel CPU and I wanted to use hardware acceleration to encode videos in H.264.
Without the hardware acceleration, I am currently having good results with the veryslow preset (which is using CRF 23 I believe):
ffmpeg -i <input>  -acodec aac -vcodec libx264 -preset veryslow  -y <output>
With the hardware acceleration, I can use:
ffmpeg -hwaccel vaapi -hwaccel_device /dev/dri/renderD128 -hwaccel_output_format vaapi -i <input> -acodec aac -vcodec h264_vaapi  -b:v 6M -y <output>
As you can see, I manually specified the bitrate (6M) which does not result in the same quality as using CRF.
Is there any way I can improve the quality of the results without messing too much with the parameters depending on the video ?
Thanks
desktop_ready is offline   Reply With Quote
Old 3rd August 2020, 22:00   #2  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Hardware accelerated H.264 encoding will generally need many more bits per frame to match x264 quality, especially if veryslow is your reference.
Old 4th August 2020, 06:38   #3  |  Link
stax76
stax76's Avatar
It would be interesting to know how many percent more bits hw encoding needs in general to match quality of software encoding.
Old 4th August 2020, 20:02   #4  |  Link
desktop_ready
Basically I am just looking for a general purpose command-line which can be applicable for all kind of videos.
The preset veryslow is working very well for that purpose.
I am a bit lost with h264_vaapi.
crf, ffmpeg, h264_vaapi
