2nd March 2010, 06:44 | #1601 | Link |
Hi albain,
For me so i don't know if it's the same issue DTS-HR 7 channel, my avr detect it in DTS-MA 5 channel. I'm go to test last version of ffdshow Thanks, Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
2nd March 2010, 13:46 | #1603 | Link |
I thought we had DTS-HR working?? Is that with an ATI or Xonar that you're having problems? My HTPC is dead right now so I can't test it, but, I've got a replacement PSU and case coming later in the week so hopefully that gets me back up and running soon. As soon as I get my machine going again I'll test that out for you.
2nd March 2010, 18:52 | #1604 | Link |
i suppose DTS-HD decoding in software isn't supported yet? I have a few TrueHD videos playing over analog just fine, but DTS-HD films either audio speeds up and it's just unwatchable or i have to change to libdts to properly watch, this is normal? Thanks
2nd March 2010, 19:58 | #1605 | Link | |
I tested the latest build (3292) with MPC Matroska splitter on TrueHD and had no issues. Seeking was instantaneous and I had no drop-outs. This is the best I've seen it on my intel clarkdale system with a Pioneer Elite receiver. Unfortunately, now DTS HD MA is broken, which I have to figure out. I don't think it's the latest build because I installed builds going back (3274, 3254, 3227) and it was still broken (silence, receiver shows "stereo"). I think the DTS issue is on my system, I'm going to try other Intel drivers. For anyone else with an Intel clarkdale, which version of the intel drivers are you using and which FFDSHOW rev? Thanks
HTPC #1 with Xonar HDAV, Pioneer VSX-TX01H HTPC #2 with Clarksdale, Pioneer VSX-TX01H XBMC for the win!! |
2nd March 2010, 20:19 | #1607 | Link | |
It's on ATI and with PDVD it's ok Seb.
2nd March 2010, 20:20 | #1608 | Link | |
I haven't tested on my clarkdale yet but with my HTPCs using the 5670 the one thing that has not been stable for me is bitstreaming HD Audio through WMP12/WMC. Movies either won't play at all unless I uncheck all the passthrough audio formats in FFDShow Audio or I get playback with audio dropouts.
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
2nd March 2010, 20:52 | #1609 | Link |
Ok. I'll test in a couple days. New PSU arrives tomorrow. New case on Thursday, so, once I get my machine back up and running I'll take a look. I'm pretty sure I still have your HR sample. We should see what TMT3 does with it, too.
2nd March 2010, 21:32 | #1611 | Link | |
http://www.xvidvideo.ru/ffdshow-tryo...oject-x86-x64/ I thought that was where Albain was posting them... didn't realize they were also on Sourceforge. I've been downloading the x86 (non ICL11) version. You are downloading from here? http://sourceforge.net/projects/ffdshow-tryout/ What's the difference?
2nd March 2010, 21:38 | #1612 | Link | |
2nd March 2010, 23:32 | #1614 | Link | |
(What case are you getting?) |
2nd March 2010, 23:42 | #1615 | Link | |
With Haali you can directly connect it to ReClock btw. You will not need any decoder between source filter (matroska or haali) and Reclock if the same file inside an mkv container. I'll edit my thread soon i hope. Last edited by rica; 2nd March 2010 at 23:49. |
3rd March 2010, 00:16 | #1617 | Link |
The Antec Nine Hundred Two with an Antec 750 EA PSU. PSU is coming tomorrow, case is coming day after. I may stick the PSU into my old case to make sure it's still working.
3rd March 2010, 08:32 | #1618 | Link | |
Media Control author
There are no differences. The project maintainers post the builds on sourceforge But there are other builders and xvidvideo.ru is a good source |
3rd March 2010, 16:26 | #1620 | Link |
The difference is in the compilers that are used by the builders. Plain MSVC vs. ICL10 vs. ICL11, and different versions of MinGW GCC.
MPC-HC 2.2.1 |
