13th November 2012, 00:57 | #12881 | Link |
watches the world burn
Not sure if this is the right place to ask, but is there any way to make Sony Vegas and/or Adobe Premiere use these for decoding mp4 files? I'm trying to archive some UTCodec YUV422 (ULY2) files as H264 High 4:2:2 using x264, but Vegas refuses to read the video ( Instead showing a green frame ), while Premiere Pro seems to offset color channels or something ( See : http://imgur.com/a/su1EJ ).
As expect, 10bit support is even worse, so I'm not even considering it. |
13th November 2012, 00:59 | #12882 | Link |
Firefox User
@nev:
is git.1f0.de git protocol closed? $ git pull fatal: unable to connect to git.1f0.de: git.1f0.de[0: 178.63.14.197]: errno=No such file or directory $ telnet git.1f0.de 9418 Trying 178.63.14.197... telnet: connect to address 178.63.14.197: Connection refused |
13th November 2012, 01:53 | #12883 | Link |
I don’t know if it is a problem specific to LAV or the disc, but the menus for Vanilla Sky are very slow and unresponsive. Most other DVD menus now react immediately when you mouse over them.
I have a few others that have a slightly delayed response, but nothing so bad as this. How can I extract the menus to send them to you? (I am running AnyDVD if that helps) I'm currently going through my whole DVD collection to see if there are any other titles like this. |
13th November 2012, 02:08 | #12884 | Link | |
Nev tells you exactly how to extract the menus...
13th November 2012, 03:36 | #12885 | Link |
Sorry, I do try to stay current on this topic, but must have missed that.
http://www.datafilehost.com/download-3deb86b9.html |
14th November 2012, 21:05 | #12889 | Link | |
Because of queueing in the renderer, this can result in higher reaction times, especially if you use madVR - it queues a lot more (also depends on your queue settings in madVR) A movie with an actual still-frame menu will simply repaint this frame on demand, and because there are no other frames to queue, it shows faster.
15th November 2012, 00:53 | #12891 | Link |
Nev, maybe LAV Video could set madVR to use half (or even less) the buffers when showing the menu? and then revert to the original values when the main title starts...
STDMETHOD_(BOOL, SettingsGetInteger)(LPCWSTR path, int* value) = 0; STDMETHOD_(BOOL, SettingsSetInteger)(LPCWSTR path, int value) = 0; (set the following to lower numbers) // gpuQueueSize, GPU queue size, integer, 4..24 // backbufferCount, no of backbuffers, integer, 1..8 // preRenderFrames, no of pre-presented frames, integer, 1..16 // backbufferCountExcl, no of backbuffers, integer, 1..8 STDMETHOD_(BOOL, SettingsGetBoolean)(LPCWSTR path, BOOL* value) = 0; STDMETHOD_(BOOL, SettingsSetBoolean)(LPCWSTR path, BOOL value) = 0; (set the following to false) // delayPlaybackStart2, delay playback start until render queue is full, boolean // delaySeek, delay playback start after seeking, too, boolean |
15th November 2012, 10:26 | #12892 | Link | |
Right now madVR cannot detect when LAV changes the DVD menu, if the menu is a video file (and not a still frame). This problem would be solved if LAV used the new subtitle interface. Then madVR would know when the menu changed and could internally flush the queue to make the menu react quicker. |
15th November 2012, 12:59 | #12895 | Link | |
Doesn't the renderer poll for subtitle frames, or did i miss an API to push changes? Doesn't seem like it really allows better low-delay handling then my current way of doing things. There is also the problem of still-frame redraws, i'm not sure how the interface really solves that. Your OSD interface on the other hand could manage all that.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 15th November 2012 at 13:09. |
15th November 2012, 14:02 | #12896 | Link |
Seem to be having a problem with LAV Filter reading subtitle flags inside an MKV file. It seems to load them regardless if I set. No Subtitles, Default or Only Forced.
I am using MPC-BE so that could be to blame? LAVFilters-0.53.2 & MPC-BE.1.0.3.1.1239.x86 |
15th November 2012, 14:03 | #12897 | Link |
MPC-BE has some "features" that override LAVs stream decision.
15th November 2012, 14:06 | #12899 | Link |
Nothing that can be fixed by me. If the player chooses a stream after LAV has already done its choice, its out of my hands.
