4th December 2015, 13:46 | #1 | Link |
Deinterlacing causing ghosting
Hi, I've captured a pal VHS tape and I'm trying to deinterlace it but whatever I do results in ghosting in different scenes depending on what method I use.
I've checked the field order by seperating the fields and it appears to be TFF. When I deinterlace TFF I get ghosting for about 10-25 frames and then clean frames for the next 10-25 frames. When I deinerlace BFF I get ghosting and clean frames in the opposite places to TFF. I've been using: Code:
AssumeTFF QTGMC( Preset="slower", FPSDivisor=2 ) https://www.dropbox.com/s/nc13lqholc...ample.avi?dl=0 Does anybody know the correct way to deinterlace this video without ghosting? |
4th December 2015, 14:01 | #2 | Link |
AssumeTFF() Bob() |
4th December 2015, 14:58 | #3 | Link |
Thanks. I'm not sure how it works but I was hoping that because I can get clean frames in opposite segments depending on the field order I deinterlace in then it could be deinterlaced without ghosting. I'll try your suggestion, can you recommend any settings or should I just try?:
AssumeTFF QTGMC( Preset="slower") srestore() Last edited by Jonaldinho; 4th December 2015 at 15:06. |
4th December 2015, 23:48 | #4 | Link |
Sorry, I haven't got an immediate solution... it's probably mangled by some kind of standards conversion process. It may be difficult to undo this, but perhaps someone here can chime in. I tried to determine a pattern in the clean and blended frames, but it's hard to say with this sort of animation.
5th December 2015, 09:28 | #5 | Link |
Yeah, the results, while not perfect, are about the best you can hope for, I think. Make sure the field order is the same for the whole thing as for the sample you supplied. Depending on how it was cut, the field order for a sample is sometimes not the same as that of the source.
6th December 2015, 12:48 | #6 | Link |
Thanks, I tested it out on the sample and I was impressed with the results. I'm now encoding the full 22 minute video, it will be finished tonight after 2 days of encoding I started reading about srestore on the forum to understand it better and I noticed that it used to be advised not to use DirectShowSource. Is this still the case? I get an error when I use AVISource.
6th December 2015, 13:42 | #7 | Link | |
Two popular source filters are FFMPegSource and L-SMASH Source, I'm a bit awkward and prefer to convert almost everything with exception of DVD MPEG2 to AVI (a lot less bother than other methods, I find). Batch file to do as I do Code:
setlocal REM Where to Find ffmpeg set FFMPEG="C:\BIN\ffmpeg.exe" REM Where to get input file, No terminating Backslash, "." = current directory (ie same as dir .bat file) set INDIR="." REM Where to place output file, No terminating Backslash. "." would be same as .bat file set OUTDIR="D: FOR %%A IN (*.264 *.vob *.wmv *.mpg *.m2v *.avi *.flv *.mov *.mp4 *.m4v *.RAM *.RM *.mkv *.TS *.y4m *.yuv *.webm) DO ( %FFMPEG% -i "%INDIR%\%%A" -vcodec utvideo -acodec pcm_s16le "%OUTDIR%\%%~nxA.AVI" ) Pause Converts anything with extensions specified in the 'FOR %%' line to AVI in OUTDIR as UT_Video video and PCM audio. EDIT: current version ffmpeg supplied with MeGUI seems to have been greatly improved so far as corrupt video tolerance is concerned. EDIT: MeGUI development version.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 7th December 2015 at 12:59. |
8th December 2015, 16:54 | #10 | Link |
sRestore removed dupes and changed the frame rate to 23.976 film speed, which would be correct despite remaining blended fields that can't be fixed. The video would now be progressive and is invalid for DVD at that frame rate. For PAL you can add 2:2 pulldown and encode at 25fps. Or you can do what many do with film-to-PAL, speed up the video to 25 fps. Whether you add pulldown or not, PAL DVD is usually encoded interlaced. Many modern players can handle it as progressive, some might not do it so well.
8th December 2015, 20:27 | #11 | Link |
Or, alternatively, after removing most of the blends and making it progressive, encode as progressive 23.976 and 720x576 followed by using DGPulldown to apply 23.976->25fps pulldown. It'll be valid for PAL DVD.
avisynth, avisynth deinterlace, deinterlace, field order, ghosting |
