3rd March 2019, 22:45 | #55141 | Link | |
I HAVE NO BANDING ISSUE IN 8BITS OR IN 12BITS! How do you want me to spell it? I'm not elitist, I'm fed up having to answer all your questions. I have no idea why you think I have any banding issue, or why you keep wanting to give me solutions for a problem I don't have. I spend enough time at the moment trying to resolve problems I do have. As I said, provided I set the bit depth correctly in madVR, there is no banding, in 8bits or in 12bits. I do spend a lot of time to look for it, and I see it even when it's minimal. I have clips in Allied and in The Revenant that I use to look for banding. Now please, help me like you did with the colorspace issue, that was useful and appreciated, but please get off my back if you only read half of what I write and force me to repeat, rephrase and lose patience. Sorry, I'm not in a good mood, but the last thing I need at the moment is wasting time answering you not helping on problems I don't have
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 4th March 2019 at 09:08. |
4th March 2019, 03:30 | #55142 | Link |
Hi, I tried going over this thread but I can’t seem the answer to setting different Gamma Presets using a hotkey. My desired power gamma curve value is 2.35 (color & gamma) and my monitor is calibrated to power curve value 2.2 (calibration) using BT. 709.
How do I make a shortcut key that toggles turning on the desired power gamma curve value 2.35 for night time and turning on power curve value of 2.2 for daytime if possible. Please advise, thank you |
4th March 2019, 04:53 | #55144 | Link |
Attachment 16759
Attachment 16760 Attachment 16761 Any setting to remove that slight banding effect? I can only use 8bpc output color depth unfortunately (but still very happy with results). Last edited by manono; 1st May 2019 at 09:15. |
4th March 2019, 05:11 | #55145 | Link |
Warner, as always, spot on! "bitDepth" actually works
Henry | LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2 | NVIDIA SHIELD TV Pro 2019 | Plex |
4th March 2019, 07:47 | #55146 | Link |
I use this to change 3dlut with the TV device, note the lowercase names:
if (HDR) "hdr" else "sdr"
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
4th March 2019, 10:09 | #55147 | Link |
crash when saving thumbnails, but not every time, and I don't know why……
mpc be 4450 + lav 0.73.1-28 + madvr 0.92.17 and save image is good x10 times without madvr is good settings.bin(same file,5 links) http://www.solidfiles.com/d/pWa58q7DBwXDZ https://1fichier.com/?hngi8xezjmvgke18iq68 https://bayfiles.com/G7O7L3v4b8/settings_bin https://anonfile.com/HaO0Lavfbe/settings_bin https://ddl.to/wlbbnvntkboh |
4th March 2019, 13:11 | #55148 | Link |
Guys quick question.. I currently have a Sapphire Nitro + 580 4GB GPU but I have an opportunity to trade this card and pay £50 on top in exchange for a Sapphire Nitro + Vega 56 8GB card .. Would this be a good move, a good improvement for madvr hdr tone mapping or will there be no point in changing my current card? Or will I be better off to pay more and buy a RTX 2060? I only watch 4K HDR and the occasional 1080p upscaled with madvr to 2160p.. Would appreciate your advice.. Thank you
4th March 2019, 15:48 | #55149 | Link |
The Vega 56 is much better than the 580 but a 2060 is better still, it is up to you how high up the price performance curve you want to go. A 2060 is probably better for the future of madVR, but even that is hard to be sure about. Is £50 a lot of money for you? If not I would do that upgrade and see if it does everything you need. Going above NGU high probably isn't worth a lot of money.
If it is, and madshi comes out with something new that wants a 2060 or better, the Vega 56 could disappoint. It is hard to give advice. Get the best you can comfortably afford.
madVR options explained |
4th March 2019, 16:57 | #55150 | Link | |
Why would the RTX 2060 be better just out of curiosity? The Vega 56 has more stream cores or is this not useful for madvr? Thank you. |
4th March 2019, 17:10 | #55151 | Link |
the number of "cores" is only comparable in the same architecture at the same clock. nvidia turing and pascal card reach easily 1800 mhz out of the box a vega 56 or 64 can't do that.
the new turing cards can do a lot of "maths" types a lot faster we talk about stuff like x128 faster here then older generation GPUs. if stuff liek this get's utilized the newer turing cards will run exclusive stuff only they can do and/or do it faster. so there is a simple solution to this problem. if you don't need a new card don't get one and wait when this "stuff" gets used. |
4th March 2019, 18:05 | #55152 | Link | |
I'm wondering why you use (HDR) to swap LUTs, though. You have a non-HDR display, so wouldn't having a separate LUT for each color space do the trick? I use DisplayCAL to create LUTs for each SDR slot in madVR, and madVR picks the appropriate one depending on the source.
4th March 2019, 18:16 | #55153 | Link | |
Not because of that but because HDR pixelshader needs gamma 2.2 3dlut all the time (with current madvr test builds), as I was told , otherwise I use gamma 2.4 during the evening with sdr content.
4th March 2019, 18:54 | #55154 | Link | |
I use the latest available test version of madVR. Same for LAV, MPC-HC, etc.
Henry | LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2 | NVIDIA SHIELD TV Pro 2019 | Plex Last edited by VBB; 4th March 2019 at 18:59. |
4th March 2019, 22:24 | #55155 | Link | |
Currently I don't need a new GPU, however the reason I am making enquiries is because I can return my RX 580 to amazon until the 17th march for a full refund.. After that I'm stuck with it until I want to really upgrade.. I'm happy with it but I was wondering if its would be wise to get a refund and replace with a rtx 2060? That's what I was wondering.. And if so.. Is there a specific 2060 model that is recommended? Asus Strix comes to mind but I may be wrong.. Thanks |
4th March 2019, 22:33 | #55156 | Link |
D3D11 - MadVR support for interlaced media ... any idea when might be available
In my experience, the D3D11 hardware decoder is much more efficient when used correctly. Especially with internal Intel GPU's (like the 7 series and up). It allows 4K, HDR material to be played with no issues where any other setting does not.
madVR has produced the best video and color quality across the board when used with MPC-HC and MPC-BE as tested ... madVR currently does not support interlaced formats with the D3D11 decoder ... deinterlacing with madVR and DXVA2 works very well. Apologize if this has been addressed earlier, but have not had time to search the entire madVR site. Any idea when/if interlaced formats will be supported by madVR with the D3D11 decoder?
MPC-HC and MPC-BE (latest), MadVR 0.92.17, LAV 0.73.1 Intel NUC w_650 internal, Roku Ultra, Nvidia Shield, Apple TV 4K PLEX Server with QUADRO 2000 Windows 10 Pro (all latest updates) Last edited by blackjack12; 4th March 2019 at 22:44. |
4th March 2019, 23:53 | #55157 | Link |
Hello,
Is it possible to use DXVA resizing for chroma when LAV is in software mode ? I explain in MadVR (scaling algo/chroma upscal) I can not select DXVA, it works if LAV is in DXVA/DXVA Copy-Back mode but not in software mode. The problem is that in H265 my card is not able to decode more than 1920x1080 (and not all) so for 1440p or 2160p this is not possible ... no problem the CPU gets there ... But no algo for chroma (in scaling algo/chroma upscal) does work so I can not look at native resolution ! For example a film in 1440p x265 10bit HDR seen on my screen (in 2560x1440) even in Bilinear Chroma resizing, there are lost frames (MPC HC x64) : https://i.goopics.net/djLWO.jpg On the other hand the same film 1440p works perfectly on my screen (in 2944x1656) but resizing chroma and image DXVA (MPC HC x64) : https://i.goopics.net/wEv2y.jpg When there is an upscale or downscale of the image (luma) then DXVA is also used for chroma (LAV in DXVA or Software). On the other hand, when there is no resizing of the image (luma) and LAV is in Software mode the Chroma does not use DXVA ... Even a movie 3840x1606 x265 10bit HDR seen on my screen (in 3104x1756) with DXVA (chroma and image) resizing work well (MPC HC x86 + Reeclock) : https://i.goopics.net/eP7WP.jpg But impossible to put in MPC Video Frame/Normal Size ... Chroma upscaling is texture unit or pixel shader ... Is there a solution ? Last edited by vanden; 10th March 2019 at 12:47. |
5th March 2019, 04:09 | #55160 | Link |
X Cinema Projectionist NZ
Can someone please tell me if I calculated the nits for my screen correctly please for using the target in madvr dynamic tone mapping.
My screen is a Studiotek curved microperf 145" diag with a gain of 1.2 I took a reading at the screen using 100% white, meter facing the JVC NX9 which was on half lamp. The reading was in F.C. result 17.5 average over the scope screen with Isco IIIL lens in place. I then converted FC to FL by multiplying by the screen gain 17.5 FL x 1.2 gain = 21 FL Then converted FL to nits 1FL = 3.4263 nits Result 21FL = 71.95 nits Have I dont this correctly. so I use say 71nits for my target in madvr tone mapping? I dont need to use the size of the screen in the calculations??? |
