10th August 2006, 16:30 | #42 | Link |
Life's clearer in 4K UHD
From what I can see, the AVCHD files max-pain has linked to are "interlaced" with a resolution of 1440x1080/88.
Media Player Classic (MPC) will be able to play them, provided you have the correct MPEG-4 AVC direct-show decoder and .TS parser/splitter installed and configured. Cheers
12th August 2006, 23:57 | #44 | Link |
With PowerDVD7 installed you will have codecs installed to be able to play this format. It is just a regular transportstream container like also used for DVB-S2 satellite transmission from ASTRA in europe containing an AVC/H.264 video and AC3 5.1 audio stream.
13th August 2006, 09:40 | #45 | Link | |
15th August 2006, 19:30 | #46 | Link | |
the files are .ts with avc video and ac3 audio the video streams cause problems for libavcodec as they use a paff/mbaff combination they also use cabac, loop and 2 reference frames (b-frames?) also the streams seem to somehow not work with mpeg4ip's h264_parse tool which might indicate a wrong bitstream?
25th August 2006, 14:58 | #47 | Link | ||
Hello,
28th August 2006, 22:26 | #48 | Link |
Just 2 questions:
- it is possible to convert this format AVCHD (.m2ts) to AVI ? - Does exist softwares able to deal with this file or to convert it in another format (DivX, Wmv, DVD, AVC....etc). Thanks. |
29th August 2006, 18:26 | #49 | Link |
.m2ts is yet again a new pseudo format from sony. it seems to be very similar to .ts, but something is wrong with the headers
29th August 2006, 18:42 | #50 | Link | |
29th August 2006, 18:45 | #51 | Link |
making people think they invented a new format? and then charge for that new format?
29th August 2006, 22:29 | #54 | Link |
I don't think so..... MPEG-2 will be a popular format for many years to come, especially as it's roots are firmly embedded in the business/professional sector
In many respects the use of "DV Tape" in high-def MPEG-2 and MPEG-4 AVC camcorders could be considered as an intermediate solution....
30th August 2006, 01:52 | #55 | Link |
The .m2ts files appear to be captured over 1394 incorrectly, as the 1394 timestamp is present before each 188 byte packet. If the tool or demuxer can't handle 192 byte packets, it will have problems.
Otherwise, the stream is just a normal Transport Stream with H.264 video. The first stream "ezhqp1.m2ts" contains H.264 video that is field only, no MBAFF. Ron
HD MPEG-2 Test Patterns http://www.w6rz.net |
30th August 2006, 08:19 | #56 | Link |
Here's the properly demuxed elementary streams:
http://www.w6rz.net/ezhqp1.264 http://www.w6rz.net/ezhqp2.264 http://www.w6rz.net/ezsm02.264 http://www.w6rz.net/ezsm03.264 Ron
30th August 2006, 09:03 | #57 | Link |
Hi Ron,
I've got to ask.... How did you manage to de-mux the AVC streams? Cheers
30th August 2006, 09:13 | #58 | Link | |
I just modified my xport demuxer tool. The normal 188 byte version is here:
http://www.w6rz.net/xport.zip It will demux 188 byte Transport Streams with H.264 video. For H.264 video, it does not perform bitstream cutting to the first I-frame and first audio frame associated with that I-frame like it does with MPEG-2 video. I'd like to add the feature, but not enough time these days. BTW, I was wrong on my previous post. The 192 byte packets are not 1394 packets, they are Blu-ray HDMV packets. This became obvious when I tried to demux the audio. Instead of the AC-3 stream being on stream_id 0xbd, it's on 0xfd. Also, there are specific Blu-ray HDMV descriptors in the stream. In fact, one of them spells out "HDMV" in ASCII. The PID's also follow the HDMV specification: 0x0 = PAT 0x100 = PMT 0x1001 = PCR 0x1011 = video 0x1100 = audio 0x1200 = Presentation Graphics There is a "Presentation Graphics" stream in these clips. UPDATE: the modified version for HDMV streams is here: http://www.w6rz.net/xporthdmv.zip Ron Quote:
HD MPEG-2 Test Patterns http://www.w6rz.net Last edited by drmpeg; 30th August 2006 at 09:34. |
30th August 2006, 19:06 | #59 | Link | |
try to run h264_parse from mpeg4ip over them
30th August 2006, 22:33 | #60 | Link |
They work fine with my in-house (LSI Logic/VideoLocus) bitstream analyzer. However, I'll try h264_parse.
Ron
