Old 8th September 2016, 21:57   #61  |  Link
IgorC
HE-AAC v2 is better than v1 up to ~36 kbps (valid for any encoder like Nero, Fraunhofer, Coding Techonologies).
v2 makes more harm than benefit at 48 kbps. http://www.mp3-tech.org/tests/aac_48/results.html While this test is pretty old the v2 and v1 encoders were already mature at that point. Nowadays the situation hasn't changed a little bit.
IgorC is offline   Reply With Quote
Old 9th September 2016, 15:30   #62  |  Link
hajj_3
those tests are from 2006. This test from 2013 is better: http://www.iis.fraunhofer.de/content...er_xHE-AAC.pdf
another report: http://nprlabs.org/sites/nprlabs/fil...y%20Report.pdf
I can't find some diagrams with opus as a comparison, i saw some last year but cannot find the links.
Old 9th September 2016, 21:28   #63  |  Link
IgorC
Originally Posted by hajj_3 View Post
those tests are from 2006. This test from 2013 is better:http://www.iis.fraunhofer.de/content...er_xHE-AAC.pdf
Let's put it straight. This information from the same organizations who push xHE-AAC and HE-AAC v2/v1. v2 is more expensive than v1 so it's convenient
Anyway Fraunhofer HE-AAC encoder (Winamp) uses
v2 - 32 kbps
v1 - 48 kbps.
It's possible to force v2 at 48 kbps but it's not recommended by the same AAC developers.
It's always possible to encode a few samples and listen for yourself.
Old 11th September 2016, 14:02   #64  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Originally Posted by CoRoNe View Post
LoRd_MuldeR, could you compile a set of fresh post v1.1.3 binaries?
Here is set of fresh Opus v1.1.3 binaries:
opus-tools.2016-09-11.zip
Old 14th September 2016, 07:51   #65  |  Link
bilditup1
bilditup1's Avatar
Thanks for taking the time to make these binaries LoRd_Mulder. However with this latest one, every time I try to encode from FLAC - any FLAC - I get the message "Error parsing input file", and the thing quits. This happens on each of the i686, sse2, and avx builds. Converting a WAV made from FLAC fixes this. The FLACs in question play without issue and were encoded using libflac 1.2.1 through 1.3.1. The FLACs have no issue being parsed by the two-year-old 0.1.9 release at the opus site and otherwise playback/decode just fine.
ED1: I have tried all of your builds going back to 20140413, and they all have the same issue. This lead me to believe I am doing something wrong, or that there is something about the way I generally encode that is causing problems. But I just made a few new FLACs from WAVs using libflac 1.3.1, no metadata or anything, and still your builds quit with the parsing error. It does not seem plausible to me that your builds have had this issue for 2+ years, so what am I missing? Some dependency or other?
ED2: I just tried the 1.1.3 build from videohelp and it failed with the same error. More googling revealed that FLAC support is only in the official build? That's the only thing that makes sense (it should not have taken me this long to figure out, anyway). You don't think you can bake in FLAC input support in your next build, do you LoRd_Mulder?
bilditup1 is offline   Reply With Quote
Old 14th September 2016, 12:31   #66  |  Link
Brazil2
Last time I have tried Opus 1.1 at 64 kbps it was superior to best HE-AAC encoders 64 kbps and on par with xHE-AAC.
Also xHE-AAC is a great format its main scope is 12-32 kbps.
You can easily confuse xHE-AAC and highestly optimized HE-AAC (such as Fraunhofer Winamp's encoder) at 64 kbps.
Where do find xHE-AAC binaries (encoder and decoder) for Windows desktop (no app) ?
Thanks!
Brazil2 is offline   Reply With Quote
Old 14th September 2016, 12:59   #67  |  Link
filler56789
SuperVirus
filler56789's Avatar
The binaries that I compiled do not support FLAC input, sorry.
I am not a big fan of the "dependency hell" around several FOSS libraries, such as FLAC, Ogg, Vorbis, and etc., so my "releases" are as simple as possible.
filler56789 is offline   Reply With Quote
Old 14th September 2016, 13:09   #68  |  Link
Brazil2
The Opusenc from the foobar2000 Free Encoder Pack has FLAC support
You can open it with 7-Zip.
Old 14th September 2016, 19:35   #69  |  Link
LoRd_MuldeR
Software Developer
I did not build opus-tools with libFLAC, because build these binaries primarily for use in LameXP, where built-in FLAC support is not needed. LameXP uses separate FLAC decoder
(I may consider building with libFLAC next time)
Old 16th September 2016, 23:23   #70  |  Link
bilditup1
bilditup1's Avatar
Thanks for the heads-up - I'll stick with that for now.
Cool beans
Old 22nd September 2016, 12:19   #71  |  Link
Brazil2
Where to find xHE-AAC binaries (encoder and decoder) for Windows desktop (no app) ?
Binaries anyone ?
Old 11th October 2016, 01:21   #72  |  Link
IgorC
No codec available no binaries but there is some information https://hydrogenaud.io/index.php/top...html#msg929358
Old 16th October 2016, 14:30   #73  |  Link
LoRd_MuldeR
Software Developer
Here is a set of fresh Opus v1.1.3 binaries:
opus-tools.2016-10-16.zip
There have been some fixes in the Opus Git "master" since the last build. Also, this time, all 'opusenc' binaries have libFLAC enabled.
Old 4th November 2016, 09:16   #74  |  Link
hajj_3
opus 1.2 alpha changelog: https://www.opus-codec.org/release/d...1_2_alpha.html
Old 4th November 2016, 11:26   #75  |  Link
Brazil2
How do you encode your xHE-AAC/USAC samples for your listening tests then ?
Old 4th November 2016, 12:40   #76  |  Link
Brazil2
Here is a set of fresh Opus v1.2-alpha binaries:
opus-tools.2016-11-02.zip
Thanks!
Old 4th November 2016, 18:59   #77  |  Link
LoRd_MuldeR
Software Developer
opus-tools.2016-11-04.zip
Old 6th November 2016, 22:11   #78  |  Link
IgorC
Opus 1.2 alpha outperforms HE-AACv2 at ~32 kbps VBR for the first time.
Scores of blind listening test at 32 kbps VBR:
1. Opus 1.2 alpha (exp-df24252) - 3.22
2. CELT (music) Mode - 3.28
3. HEAACv2 (FhG Winamp, VBR 1) - 2.92
https://hydrogenaud.io/index.php/top...html#msg930611
Old 7th November 2016, 11:48   #79  |  Link
hajj_3
It would be good if they compared opus 1.2 alpha with xhe-aac.
Old 7th November 2016, 14:12   #80  |  Link
IgorC
It also would be good if there will be any available xhe-aac encoder at all, now wouldn't it?
