31st May 2023, 11:20 | #2581 | Link | |
Friend of a friend..
pre=ex_Median(mode="IQMST") SMDegrain(tr=6,thSAD=600,thSADC=300,contrasharp=true,prefilter=pre,refinemotion=true) Might be an idea to also ask the question on the StaxRip thread... |
31st May 2023, 12:20 | #2582 | Link |
@salvo00786: Update ExTools and try again. IQMST was a last addition, even so it's already a few months ago.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
31st May 2023, 13:19 | #2583 | Link | |
Just checked, it's under the "x\Apps\Plugins\AVS\Scripts\ExTools.avsi" At least v10.0, but latest here, is v10.2 Last edited by FTLOY; 31st May 2023 at 13:42. |
31st May 2023, 14:17 | #2584 | Link |
Posts: n/a
Hello,
is there any way to improve details retantion of this call and also remove more background grain? pre=ex_Median(mode="IQMST", UV=3,thres=15) pre=ex_blend(pre,"blend",opacity=0.5).ex_median("IQMV").ex_sbr(1,UV=3) my_TR = 3 # 4/5 depends on the grain my_thSAD = 400 my_thSCD1 = my_thSAD + 100 my_thSADC = my_thSAD - 100 SMDegrain(mode="TemporalSoften", tr=my_TR, thSAD=my_thSAD, thSADC=my_thSADC, thSCD1=my_thSCD1, thSCD2=110, Str=2.0, limits=false, refinemotion=true, prefilter=pre, chroma=true, plane=4, search=5, subpixel=3) |
31st May 2023, 14:26 | #2585 | Link | |
Posts: n/a
import("E:\4k_Encode\Avisynth-Scripts-master\MIX mods\GradFun3plus.avsi") import("E:\4k_Encode\Avisynth-Scripts-master\ExTools.avsi") import("E:\4k_Encode\Avisynth-Scripts-master\SMDegrain\SMDegrain.avsi") Import("E:\4k_Encode\Avisynth-Scripts-master\ResizersPack.avsi") Import("E:\4k_Encode\Avisynth-Scripts-master\MIX mods\LSFplus.avsi") Import("E:\4k_Encode\Avisynth-Scripts-master\MIX mods\SharpenersPack.avsi") Import("E:\4k_Encode\Avisynth-Scripts-master\GradePack.avsi") Import("E:\4k_Encode\Avisynth-Scripts-master\ScenesPack.avsi") Import("E:\4k_Encode\Avisynth-Scripts-master\MasksPack.avsi") Import("E:\4k_Encode\Avisynth-Scripts-master\MIX mods\Spresso.avsi") import("E:\4k_Encode\Avisynth-Scripts-master\EX mods\DeblockPack.avsi") import("E:\4k_Encode\Avisynth-Scripts-master\TransformsPack - Main.avsi") import("E:\4k_Encode\Avisynth-Scripts-master\TransformsPack - Models.avsi") import("E:\4k_Encode\Avisynth-Scripts-master\TransformsPack - Transfers.avsi") loadplugin("E:\4k_encode\BM3DCUDA_AVS-test9\x64\BM3DCPU_AVS.dll") loadplugin("E:\4k_encode\BM3DCUDA_AVS-test9\x64\BM3DCUDA_AVS.dll") loadplugin("E:\4k_encode\BM3DCUDA_AVS-test9\x64\BM3D_VAggregate_AVS.dll") loadplugin("E:\4k_encode\dgdecnv_244\DGDecodeNV.dll") loadplugin("E:\4k_encode\vsTCanny-1.1.8\x64\Release\vsTCanny.dll") loadplugin("E:\4k_Encode\neo_FFT3D_r11\x64\neo-fft3d.dll") loadplugin("E:\4k_Encode\fmtconv-r30\win64\fmtconv.dll") loadplugin("E:\4k_Encode\avs_libplacebo-1.1.4\x64\Release\avs_libplacebo.dll") loadplugin("E:\4k_Encode\ClipClop_x86_x64_dll_v1-26_20181222\Avisynth+_x64\ClipClop_x64.dll") loadplugin("E:\4k_Encode\DGHDRtoSDR_1.15\DGHDRtoSDR.dll") and i do not have any problem with SMDegrain calls |
31st May 2023, 15:30 | #2587 | Link | |
Madey83,
https://www.rationalqm.us/dgdecnv/binaries/ Not sure, I think versions about 244 could produce garbled frame if jumping about within the clip, but if step back a dozen or so frames and then stepping forward frame by frame, did not produce garbled frame on the original bad one. Have not noticed similar behaviour recently, so is maybe fixed in v247. EDIT: Actually, Seems it was updated yesterday, is now v248.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 31st May 2023 at 15:36. |
31st May 2023, 16:18 | #2588 | Link | |
Posts: n/a
31st May 2023, 18:19 | #2589 | Link |
madey83: You are using very strong filters there, for instance IQMST paired with TemporalSoften. Without seeing your source this could be too much. Maybe use a milder prefilter and increase thSAD. Settings vary a lot from source to source.
Also there are updated versions of your plugins: Code:
avs_libplacebo-1.2.0 BM3DCUDA_AVS-test10-cuda118 ClipClop_x86_x64_dll_v1-27_20210727
31st May 2023, 20:57 | #2591 | Link | |
Posts: n/a
Hi Dogway, my main problem is that i have not enough powerfull CPU on my PC, and i always try to get as much as possible clean picture (targeting bitrate between 2-3 Mbps for 1080p) with possible high details remain as possible and of course speed is important for me too. With above settings of SMDegrain + LSFplus + neo_f3kdb i got ~4 fps which is quite low in my opinion. i have tried also below settings: pre=STTWM(sw=50,tw=50,aw=100,sthres= 5,tthres=5) # Balanced my_TR = 3 # 4/5 depends on the grain my_thSAD = 500 my_thSCD1 = my_thSAD + 100 my_thSADC = my_thSAD - 100 SMDegrain(mode="STWM", limit=255, UHDHalf=true, prefilter=pre, tr=my_TR, thSAD=my_thSAD, thSADC=my_thSADC, thSCD1=my_thSCD1, thSCD2=110, LFR=false, limits=false, DCTFlicker=false, refinemotion=true, search=5, subpixel=3) but remove grain was not enough. Rising TR and thSAD did not remove grain more... only reduced speed of encode. this is the picture example where i would like to get clean background but have remain as much as possible details on foreground https://postimg.cc/tZpLdbf8 Last edited by madey83; 31st May 2023 at 21:03. |
31st May 2023, 21:48 | #2592 | Link |
Typically to visibly remove more grain and got less MPEG output bitrate at fixed crf-value it is require to make much larger tr-value adjustments (like doubling of tr-value only make photon shot noise about sqrt(2) lower). So playing around tr of 3,4,5 may be not any visible (also doubling of tr typically make processing fps half lower). To make some more visible step in subtle degraining it is more benefitical to move from linear FIR-type filter (like in current 2.7.45 MDegrainX) to IIR-type (also non-linear) filter (like pmode=2 in post 2.7.45 builds and VSTTempSmooth my tech demo). The IIR-type filter can remember best block or sample value over tr-scope and continue output it (equal to frame-duplicate but at block or sample level) and make most MPEG-friendly frame sequence to encode.
FIR-type filter linear because of its math can not reach such samples stability over many frames with not very large tr-values. And residual very small samples non-stability over sequence of frames to encode still create very high 'noise bitrate' to MPEG encoder. So it may be recommended to wait until new processing modes will be 'officially' released in mvtools/vsttempsmooth (or sample-based vsttempsmooth-like processing will be also integrated as additional mode into MDegrainN as planned depending on some algorithm like for blocks with too bad SAD/dismetrc and so like). Not waste time and CPU/power to use too outdated mvtools manalyse/degrain of about 1..2 decade old. Even with some scripting enchancements over very old and simple FIR-type linear degrain engine. Playing around very simple manalyse/mdegrain engine of 200x years design can not make degraining better and better each year with some 'prefiters' shuffling and simply increasing tr and thSAD. The old 2.7.45-mvtools based denoiser may reach its limits already at 201x years. I hope if pinterf will have time in 202x years we may still see updated mvtools version 'stable' of post-2.7.45 version number with many new features added. So Dogway will make redesign of SMDegrain for better degrain performance. I understand users like to make encodings today and not wait years and decades for next better version of software - but things become slower and slower now. After very powerful design of opensource software in 200x years users may be used to have more and more advanced software releases several time per year and now in 202x as most of opensource at current planet and current EU+US civilization is died already it may be only 1 new updated release per decade or even more rare. Last edited by DTL; 31st May 2023 at 22:14. |
31st May 2023, 23:13 | #2593 | Link |
madey83: Update a sample clip so I can have a look. Typically this is a matter of configuring a nice prefilter. What CPU do you have? So I can compare to mine which isn't top notch either.
1st June 2023, 05:58 | #2594 | Link | |
Posts: n/a
@Dogway Regarding my CPU it is ashamed to admit by it is i7 10750h.... example: https://mega.nz/file/8QgQSTbQ#Y2XXFl...3oSclOZDl1LoPs this is my entire call which gives me bitrate ~3500 Kbps, and yes i know HDR/DV source should have DGHDRtoSDR but i can't properly find white point of my source and i think some colors are shifted/not match to the source. I will update this matter in next time, when i will see this... edit: ConvertBits(16) deep_resize(1920,edge="Zopti1080") MaxFALL=22 #check for DV/HDR white point pre=DGHDRtoSDR(mode="pq",white=MaxFALL,gamma=1/2.4,tm=1.0).ex_Median(mode="IQMST", UV=3,thres=15) pre=ex_blend(pre,"blend",opacity=0.5).ex_median("IQMV").ex_sbr(1,UV=3) my_TR = 3 # 4/5 depends on the grain my_thSAD = 400 my_thSCD1 = my_thSAD + 100 my_thSADC = my_thSAD - 100 SMDegrain(mode="MDegrain", tr=my_TR, thSAD=my_thSAD, thSADC=my_thSADC, thSCD1=my_thSCD1, thSCD2=110, Str=2.0, limits=false, refinemotion=true, prefilter=pre, chroma=true, plane=4, search=5, subpixel=3) LSFplus(strength=50, preset="LSF", secure=true, Lmode=3, soft=-2, soothe=true, Smode=3, Smethod=3, Szrp=16, Spwr=4, SdmpLo=4, SdmpHi=48, overshoot=1, undershoot=1, Overshoot2=1, Undershoot2=1, keep=20, edgemode=0) neo_f3kdb(preset="veryhigh/nograin", dynamic_grain=false, sample_mode=2,keep_tv_range=false,dither_algo=3,mt=false) fmtc_bitdepth(bits=10, dmode=7) Prefetch(10,12) FYI: i'm newbie in avisynth filtering, so this is my level of understanding how to use it.... Last edited by madey83; 1st June 2023 at 07:04. |
1st June 2023, 09:24 | #2595 | Link |
21 years and counting...
Well if you care to bound your encodes to a certain bitrate you may tweak your encoder settings instead of trying to denoise your sources too much.
You can't 'denoise' any source down to your desired bitrate without losing too much detail at some point. Why not do 'some' denoising for better compression and opt for a 2-pass encode at ~3.5Mbit instead of CRF? |
1st June 2023, 09:49 | #2596 | Link |
Posts: n/a
Hi LeXXuz,
If I would have enough powerful CPU then I would be possible to do 2 pass encode, but I don't have it and double the time for single episode it is to much for me. That's the reason why I prefer CRF with denoising + plus clean sharp picture is my preference... |
1st June 2023, 10:03 | #2597 | Link | |
SMDegrain is an excellent script, but after many month and hundreds of tested configurations, it always came down to the very same conclusion that mvtools is the weak spot here and in its current state couldn't cut it to satisfy my needs and expectations of a high-class motion-based denoising workflow on more demanding sources. I'm almost at the brink of saying I'd better buy more hard drives instead of wasting that money on energy cost for half-satisfying 'remastering' jobs of my collection which I may regret one day. And here is the big problem I see for any future development. 20 years ago disc space was expensive and hard drive space even more. So lots of people were looking for smarter solutions to back up their content. Hence began a vast development in filters and codecs to reduce file sizes while maintaining or even improving quality. I've been here long enough and witnessed most of that evolution. Today, storage space is cheap. Talking TB now instead of GB two decades ago. In the same time storage cost went down, energy cost went up constantly. Making video transcoding less and less attractive to many people. In my circle of friends I'm the only one left still caring about encoding efficiency and video filtering. All the other guys do is backing up their discs to their storage networks and be done with it. And here I am, still wasting lots of money on a somewhat outdated 'profession' with results that don't even fully convince me in the end. Makes you think. I do hope mvtools will get the updates one day it really needs to greatly improve motion-based denoising methods to a level that can satisfy ambitious quality expectations. But like you said, we need the people that have the time and knowledge to code and implement those things. And these people get more rare every year. Don't want to get this OT and like I said, Dogways script is excellent but it can only do as much as its core element. It's like having a Porsche with an old VW engine. Looking awesome at first glance but gets more unsatisfying the deeper you look into it. Last edited by LeXXuz; 1st June 2023 at 21:59. |
1st June 2023, 13:15 | #2598 | Link | |
https://forum.doom9.org/showthread.p...31#post1987631 And did you try the script I suggested ?? https://forum.doom9.org/showthread.p...12#post1987812 |
1st June 2023, 21:02 | #2599 | Link | |
I tried to send request to Asd-g for maintaining mvtools versions after 2.7.45 of pinterf build with as most as possible of my additions and will wait for answer. Last edited by DTL; 1st June 2023 at 21:32. |
avisynth, dogway, filters, hbd, packs |
