Old 18th August 2008, 12:09   #1  |  Link
aand
Learning fast
aand's Avatar
any plugin for ghosting?
I was wondering if the is a way to get rid of this artefacts (they are more noticeable in motion):
300kB .mkv sample 1
5MB .mkv sample2
On the Avisynth wiki I've found 'Ghostbuster' which is too old and doesn't work anymore, so I tried the equivalent "Exorcist" VirtualDub filter which I found to be more damage than restore.
aand is offline   Reply With Quote
Old 18th August 2008, 14:09   #2  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
I had to use unblend() once, and it was quite effective. But the source was anime.
...desu!
Mystery Keeper is offline   Reply With Quote
Old 19th August 2008, 10:57   #3  |  Link
mikeytown2
Resize Abuser
mikeytown2's Avatar
Try http://niiyan.net/?EraseGhost
mikeytown2 is offline   Reply With Quote
Old 19th August 2008, 18:43   #4  |  Link
Amrit
How about bobing then restoring?
Amrit is offline   Reply With Quote
Old 19th August 2008, 21:39   #5  |  Link
Mystery Keeper
Beyond Kawaii
1) That's a great quality loss.
2) It may not solve the problem at all if there's progressive blending or other filters artifacts.
...desu!
Old 20th August 2008, 04:36   #6  |  Link
Amrit
So you advice Unblend on Ghosting?
Old 20th August 2008, 10:07   #7  |  Link
Mystery Keeper
Beyond Kawaii
I don't know. Only had that problem once on anime, and Unblend solved it completely. But the main rule of video filtering is "There's no universal solution".
...desu!
Old 20th August 2008, 13:18   #8  |  Link
FlimsyFeet
Posts: n/a
"Ghosting" could refer to 2 seperate things - as I understand it, maybe someone else knows better, but it could be either motion afterimages of bright objects in previous frames, caused by blended fields or a side effect of too strong temporal noise filtering. Or it could be repeated fringes to the left or right dues to analogue refelections or interference.
The "streaking" in the first image looks like an analogue artefact, similar to what I get with my cheap TV when there's a picture showing a window with venetian blinds! Unfortunately I don't know what it is that causes this kind of effect, or what you can do about it.
Old 20th August 2008, 14:14   #9  |  Link
xbox360
xbox360's Avatar
Can anyone help translate to english LGhost ( http://nullinfo.s21.xrea.com/#LGhost ) & warpsharp 2008/03/25 ( http://seraphy.fam.cx/~seraphy/progr...arp/index.html ) for Ghosting Usage, please. Thank You very very very much in advance.
xbox360 is offline   Reply With Quote
Old 20th August 2008, 23:25   #10  |  Link
Nightshiver
Quality Freak
LGhost:
Description
* Plug-ins for the removal of ghost Avisynth
* YUY2 mode and mode YV12
* Brightness only see only brightness changes
* Ghost and the removal of ghost edge brightness (ringing) can be removed
The link you gave for warpsharp doesn't talk about ghost removal, it talks about color conversion.
Nightshiver is offline   Reply With Quote
Old 21st August 2008, 04:34   #11  |  Link
xbox360
xbox360's Avatar
What I meant was translate to english the plugin settings so I know how to tweak them, please help & thank you in advance.
Old 28th August 2008, 10:00   #12  |  Link
xbox360
xbox360's Avatar
Please Help, please !
Old 28th August 2008, 12:26   #13  |  Link
AVIL
Hi:
I've extracted help from zip, deleted japanese chars and added commentaries (bold text):
LGhost.dll v0.3.01 Copyright(C) 2002, 2003 minamina
Avisynth Plugin - Ghost Reduction (YUY2 and YV12 Only, Luminance Ghost Only)
Colorspaces:
Avisynth
YUY2
YV12
Dll suitable for each avisynth's version:
LGhost1.dll : Avisynth 1.0, 2.0
LGhost.dll : Avisynth 2.5
Loading:
LoadPlugin("LGhost.dll")
Sintax:
LGhost(clip, mode0, shift0, intensity0, ... , mode17, shift17, intensity17)
Parameters:
mode 0 : (default), 1 : 2 : 3 : 4 :
shift (-clip.width ‚clip.width, default 0)
intensity (-128 ‚ 127, default 0)
Examples:
LGhost(mode0 = 1, shift0 = 3, intensity0 = -15)
LGhost(2, 4, 20, 2, 7, 10, 1, -4, -15, 1, -7, -5)
I think only obscure parm is mode but trial and error can do miracles.
Anyway, a few is more than nothing.
Good luck
AVIL is offline   Reply With Quote
Old 28th August 2008, 21:17   #14  |  Link
AVIL
Hi again:
I've found an translation to english of the readme.txt:
- Description
Avisynth ghost removal plugin
YUY2 and YV12 luminance ghost and edge ringing removal
- Method of use
0 - 17 corresponds to up to 18 ghosts
mode 0 : disabled (default)
1 : edge ghost removal
2 : brightness go strike removal
3 : leading edge ghost removal
4 : trailing edge ghost removal
shift shift width (-clip.width to clip.width, default 0)
intensity strength (-128 to 127, default 0)
- Example
- History
2003/03/16 v0.3.01 Avisynth 2.5 version written
YV12 mode written
2002/12/23 v0.2.01 Added leading and trailing edge ghost removal
LGhost.auf.avs bundled
2002/12/15 v0.1.02 Corrected bug when using FrameCache with LGhost
2002/11/11 v0.1.01 Open failure cord/code ??? deletion
2002/11/03 v0.0.03 Setting UI deletion -> LGhost.auf.avs compilation
2002/11/03 WarpSharp added to avsfilter
2002/10/07 v0.0.02 edge ghost removal added
2002/09/26 EraseGhost added to WarpSharp
2002/09/24 v0.0.01 First release
Unauthorized translation to English by Fred Thompson utils@mindspring.com
Old 2nd September 2008, 12:46   #15  |  Link
xbox360
xbox360's Avatar
Thank You very very much ! This is awesome ! I really really really really really apreciate it. Also it would have helped many other leechers !
Old 4th January 2010, 19:09   #16  |  Link
fjhdavid
xbox 360, did you use the LGhost filter finally?
what about the parameters you choose? what are the results?
did you find another avisynth filter?
thanks
Francois
fjhdavid is offline   Reply With Quote
Old 13th April 2010, 05:28   #17  |  Link
whatyaar
i also waiting for the xbox360 reply...show us some light dude.
whatyaar is offline   Reply With Quote
Old 11th May 2014, 23:39   #18  |  Link
satmonk
LGhost does not have a named argument "mode0"
I cannot get this filter to work :-(
satmonk is offline   Reply With Quote
Old 12th May 2014, 07:23   #19  |  Link
RT_PluginParam() should extract CPP type argument list.
RT_Stats here: http://forum.doom9.org/showthread.php?t=165479
From Docs
RT_PluginParam(String FunctionName)
 FunctionName, String, name of Avisynth built-in or Plugin filter or function name.
 Returns "", if FunctionName Parameter string not found.
 Returns String, the Avisynth CPP Interface style argument specifier string used by Avisynth to determine argument types and optional names.
  Optional arguments have square brackets surrounding their name as in [name] and are followed by a type specifier character that gives
  the type. Unnamed arguments are not optional. eg "cc[arg1]b[arg2]i" would be two compulsory unnamed clip args, followed by optional
  'arg1' of type bool and optional 'arg2' of type int.
    # Argument type specifier strings.
      c - Video Clip
      i - Integer number
      f - Float number
      s - String
      b - boolean
      . - Any type (dot)
    # Array Specifiers
      i* - Integer Array, zero or more
      i+ - Integer Array, one or more
      .* - Any type Array, zero or more
      .+ - Any type Array, one or more
    #    Etc
   To show params:-
      colorbars().Killaudio()
      S=RT_PluginParam("RT_YStats")
      S=RT_StrReplace(S,"[",Chr(10)+"[")
      RT_Subtitle(s)
Old 31st March 2015, 01:36   #20  |  Link
real.finder
thanks
Francois
use value directly by arrangement and it will work, EX:- http://forum.doom9.org/showthread.ph...99#post1715299
it is the best solution available at this moment
http://avisynth.nl/index.php/Externa...#Ghost_Removal
But unfortunately, it doesn't touch chroma, just luma
hope someone update it since it open source
See My Avisynth Stuff
ghosting
