18th June 2004, 07:43 | #21 | Link | |
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
18th June 2004, 14:54 | #22 | Link |
mpegable AVC on Win98
There is a little patch for mpegable AVC on Win98 machines. You can download it from http://www.mpegable.com/download.
In addition to the actual installation file, you must download the file 'davc.inf' and install it (click right on file and chose 'Install'). This script does the neccessary entries in system.ini. |
18th June 2004, 20:57 | #23 | Link | |
frying subs
What i would check back in your situation is who uses I420, i always thought this were simply a "re-packed YV12" (different storing order) and i have never explicitely seen a file using it, but it could be it were used on Real or Quicktime based systems in which case it were quite important ..but i really don't know, this is just a feeling this colorspace could be used somewhere i do not usually go
-nyo |
19th June 2004, 11:42 | #24 | Link | |||
mpegable, can you plz give us some more information on the used settings in your avc codec, like loopfiltering is enabled always, what is the exact difference between very slow, medium, fast encoding speed (only motion search?), what is rection time aso...
also it never harms if you give the user the possibility to configure your codec, like en/disabling loopfiltering aso... thanks Quote:
edit: i did some first tests with it and noticed the same behaviour as with mainconcepts implementation: the first few frames are totally blurred and ugly, only after a while they seem to look ok
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 19th June 2004 at 12:11. |
19th June 2004, 13:55 | #26 | Link |
Moderator, Ex(viD)-Mascot
I'm afraid you're wrong; it wouldn't be useful, it would make it usable.
It's a man's life in Doom9's 52nd MPEG division. "The cat sat on the mat." ATM I'm thoroughly enjoying the Banshee - a fantastic music player/ripper for Linux. Give it a whirl! |
21st June 2004, 14:26 | #27 | Link |
Support for YUV
Thank you all for the input. There is an updated version of mpegable AVC available from www.mpegable.com. The new version supports different YUV formats including YV12, IYUV, YUY2 and UYVY.
There will be some more updates in the near future before we release a 1.0. They will include automatic I-frame insertion, more options for the codec configuration as well as quality and performance improvements. :-) One more remark also to the first results of PSNR measurements. Since the reference software does not support bitrate control (at least nobody knows if and when it really works) it is difficult to ensure equal test conditions. To make a fair comparison you can either make a longer test with full PSNR curves, or - to test only at a certain bitrate - you should first encode the sequence with the reference software configuring a certain quant step. Then determine the bitrate needed by the reference sofware, and configure the mpegable AVC accordingly. Using the tempete sequence, the difference between mpegable AVC (slowest mode) and the reference software (base profile) should be around 0.5db. This is at least true with the version 0.8 of mpegable AVC when the input color format is YV12 (no RGB). |
22nd June 2004, 00:01 | #28 | Link |
I have tried encoding with fast recompress video mode in Vdubmod but all i get is a garbled picture with yv12 sources. If i connvert the video in avisynth to YUY2 then fast recompress works fine however as you know this is not ideal.
HQ XviD Music Video Forum When I'm good I'm very, very good but when I'm bad I'm better. |
23rd June 2004, 12:33 | #29 | Link |
Satsuki'S Softs Maker
Just an idea, could you add a smp implementation in your codec ? I'm running on dual cpu only ^^.
i've tried this codec, it's a good base for future good codec. i think it need: +1-pass quantitzer mode +2-pass mode +inloop configuration (and desactivation) +... ++ |
23rd June 2004, 13:45 | #30 | Link |
hi shinobu, thanks for your input.
We plan to add multi-processor support to the codec but this will probaly take until end of the year. + constant quantizer mode: will be part of the next release + work in progress: not yet sure when it is finished + inloop configuration: it seems that a optional inloop filter is what some people like... In general we do not want to make a codec only for video coding experts but for all users. To many configuration settings may be puzzleing. We need good mixture ... |
23rd June 2004, 14:27 | #31 | Link | |
if not activated (the default setting) your "for all users" gui gets displayed
23rd June 2004, 18:05 | #33 | Link |
frying subs
well this is not actually a poll, but i'd also vote for the advanced settings panel as i like to play with this kind of things.
Maybe you should do it in a way that as soon as you use the normal panel again it restores the default values because else you will have people who tried something in the advanced part only once and forget about, then only use the nomal part and have special settings without knowing for a long time - i'm thinking about xvid here where people sometimes still have overflow and curve compression settings they set a year ago (=completely outdated).
-nyo |
20th September 2004, 23:04 | #34 | Link |
seems version 0.10 of the mpegable mpeg-4 avc/h.264 encoder has been released some days ago
hopefully they have considered our "experts mode" request enjoy
26th December 2004, 19:51 | #36 | Link | |
is anyone able to decode h.264 .avi files created with x264 (mencoder/ffdshow) in vfw with the mpegable avc vfw implementation?
i tried it with files created with mencoder in vdm with no success (the DAVC fourcc is needed for the mpegable vfw decoder) the dicas vfw decoder even crashes when the stream doesnt use b-vops, cabac, loop and 4x4mv i always get the message: Quote:
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 26th December 2004 at 21:08. |
27th December 2004, 18:28 | #37 | Link |
<The VFW Sheep of Death>
Ah, indeed, the x264 seems to have added some efficiency/compression code that renders it non-decodeable with older implementations of AVC decoding software. I have the same problem, but in VDUB mod. Just get the ffdshow vfw decoder set up, and it doesn't matter whether or not the DAVC decoder functions.
Cheers, baa
Recommended all-in-one stop for x264/GCC needs on Windows: Komisar x264 builds! |
27th December 2004, 19:59 | #38 | Link |
ffdshow now also offers vfw decoders? seems i missed something
just to put emphasis on it again: i tested _very_ basic x264 streams (no cabac, aso, as described above) in .avi with mpegable (to be sure that not advanced technologies cause the problems), still it didnt handle it
27th December 2004, 23:58 | #39 | Link |
Woah. Wierd. Happens here too. I wonder if DAVC vfw looks for a "fingerprint" of its native encoding? I've heard about some sort of vfw protection for a while now, just never saw it happen. Perhaps this is an example of "vfw fingerprint checking." Perhaps mpegable only wanted its decoder to decode its own stream for testing purposes (in version .10). However, I've only noticed this after the installation of Nero...
'Spose I'll look into it. Cheers, baa
28th December 2004, 00:02 | #40 | Link |
bond, oh yeah, I forgot to say... Um, yeah, vfw decoders. Ain't I the observant little snake? Or should I say... SHEEP? BWAHAHAHAHA BAAAAHAHAHAHAA baaa. (Or maybe I'm just stupid and out of it) Ok, here goes:
