Old 25th June 2020, 17:13   #7521  |  Link
fried chicken
I'm using "MPC-BE 1.5.5 (build 5274) beta" and am not getting a list of embedded subtitles. If I try the same file in "MPC-HC 1.9.5.17 x64", I get the full list which appear with "(subrip)" next to the languages. Mediainfo shows the subtitle tracks as "Format: UTF-8, Codec ID: S_TEXT/UTF8, Codec ID/Info: UTF-8 Plain Text". Any ideas what could be the problem?
edit: I installed LAV filters, added splitter/splitter source/audio/video as external filters, set them to prefer. Now when I right-click on the video I see all the subtitles but when I select one, they aren't displayed.
Thanks for any help/suggestions!
fried chicken is offline   Reply With Quote
Old 25th June 2020, 19:11   #7522  |  Link
v0lt
@fried chicken
I can not check your file. Reset player settings.
v0lt is offline   Reply With Quote
Old 25th June 2020, 20:12   #7523  |  Link
fried chicken
Originally Posted by v0lt View Post
@fried chicken
Reset has fixed it. Not sure what was wrong but it's working fine now. Thank you for the suggestion!
BTW, does Options->Player->Store settings in the player folder make MPC-BE 100% portable?
Old 25th June 2020, 21:58   #7524  |  Link
M.Scott
M.Scott's Avatar
I don't think MPC-BE can be fully portable, I do wish it's various other tools could be made portable... here's what I've learned, I'm open to correction.
If you use the zip or 7z archives (non installers), and create a ini file to store the settings, the player should be portable. I've used the 7z from the get-go, and created a ini to match the exe. I always save a backup of the ini and just copy it to the new version, all the settings are saved including the lav filter settings.
mpc-be64.exe
mpc-be64.ini
The player becomes less portable when you begin to need external filters, like the lav filters, mad-vr. Of course, if you are already using the external tools then MPC-BE can simply be pointed to them, but (in my case), if you want to add these tools to MPC-BE I believe they must be registered, which in my view makes things less portable.
Now, I don't know if I'm fooling myself but because I like to use only portable apps (stealth if possible, no writting to the registry, etc), I did extract the lav filter zip to my MPC-BE root folder:
C:\MyApps\MPCBE
...........................\x64\ -> this is where MPCBE is
...........................\lav\ -> the extracted lav filters (0741)
Here's where I might be fooling myself as to whether I'm even benefiting from the lav filters, I only extracted the lav filter zip, I did not register the filters using the bat file. I disabled all the Internal filters in Options and in External Filters pointed to (IIRC) ax files, set to Prefer... as far as I can tell I'm using the four required files:
LAV Audio Decoder
LAV Splitter
LAV Splitter Source
LAV Video Decoder
As far as I can tell MPCBE is using LAV and the player is excellent, and I figure portable...??? I've wanted to try the other video renderer but I haven't because I don't want to have to register anything... leave my registry alone
MPCBE is working fine, but I could be missing out on better performance but my system is very modest so I don't know that I would benefit from mad-vr, the stand alone filters, or the mpc video renderer.
I've had some questions about my setup (the settings in Options), how to get the most out of things, I'll save them for another day.
Sorry for the long rant, hope some of it is useful
M.Scott is offline   Reply With Quote
Old 26th June 2020, 00:05   #7525  |  Link
fried chicken
LAV Audio Decoder
LAV Splitter
LAV Splitter Source
LAV Video Decoder
I did the same as a test here and it looks like the whole path to the lav .ax's is stored in the .ini. I changed the path from the full path to just ".\LAV\<whatever>.ax" and they still showed up in external filters.
If MPC-BE's `current dir` is the dir where mpc-be64.exe resides, and the paths in mpc-be64.ini can actually be set to "." instead of something like "C:", then I think it can be completely portable. If so, maybe a `portable` switch can be added to the external filters settings which will set the path to "path=." if the .ax is located in the same dir as mpc-be64.exe, or a subdir of it. Something like:
if MPC-BE dir = C:\portable\mpc-be\
then mpc-be bin = C:\portable\mpc-be\mpc-be64.exe
if LAVSplitter.ax = C:\portable\mpc-be\lavfilters\LAVSplitter.ax
and external filters portable switch is on
then mpc-be64.ini would point to "path=.\lavfilters\LAVSplitter.ax"
if external filters portable switch is off
then mpc-be64.ini would point to the full path "path=C:\portable\mpc-be\lavfilters\LAVSplitter.ax"
Old 26th June 2020, 00:15   #7526  |  Link
clsid
External LAV Filters will store its settings in the Registry. So not really portable.
Old 26th June 2020, 15:48   #7527  |  Link
Klaus1189
Updated german translation based on r5353
Klaus1189 is online now   Reply With Quote
Old 26th June 2020, 22:16   #7528  |  Link
s0meone_new
Need to update language translation? New text?
s0meone_new is offline   Reply With Quote
Old 27th June 2020, 04:31   #7529  |  Link
Klaus1189
Yes, see here:
https://sourceforge.net/p/mpcbe/code...15b75022c:5352
Old 27th June 2020, 11:32   #7530  |  Link
wushantao
https://send.firefox.com/download/61...ra-2yImAEJ4tbg
Updated Simplified Chinese translation
wushantao is offline   Reply With Quote
Old 28th June 2020, 00:04   #7531  |  Link
s0meone_new
Originally Posted by Klaus1189 View Post
Two lines?
"Enable preview"
"Preview is currently disabled. You can enable it in MPC-BE's options."
Here is the Hungarian update:
https://www118.zippyshare.com/v/ez5AZ0Y5/file.html
Old 28th June 2020, 06:24   #7532  |  Link
v0lt
@Klaus1189, @wushantao, @s0meone_new
Thanks. Updated in r5354 and r5358.
Old 28th June 2020, 06:51   #7533  |  Link
wushantao
https://send.firefox.com/download/d1...VW9DKmbcjsfg0g
minor correction
Old 28th June 2020, 10:04   #7534  |  Link
tormento
Acid fr0g
tormento's Avatar
Need someone for italian version?
@turment on Telegram
Old 28th June 2020, 10:13   #7535  |  Link
Klaus1189
According to history of italian translation, definitely
https://sourceforge.net/p/mpcbe/code...yerc.it.rc.txt
Download this file:
Edit and upload to google drive or what you like and post link for devs
Old 28th June 2020, 16:24   #7536  |  Link
tormento
Acid fr0g
tormento's Avatar
Glad to help!
Please link me the english resource file, I'd like to check translation errors too.
Old 28th June 2020, 16:37   #7537  |  Link
Klaus1189
Here it is:
https://sourceforge.net/p/mpcbe/code...playerc.rc.txt
Old 29th June 2020, 03:58   #7538  |  Link
v0lt
All actual text files for translation.
And all the actual .RC files to help.
Old 2nd July 2020, 00:17   #7539  |  Link
beter
Update for translation of Chinese Traditional and Dutch based on 5353.
https://www.sendspace.com/file/9zuhm4
beter is offline   Reply With Quote
Old 2nd July 2020, 02:40   #7540  |  Link
ryrynz
ryrynz's Avatar
dav1d update please
