5th September 2008, 12:53 | #441 | Link | |
AVStoDVD Dev
Will do. And surely I will put Aften support to my ToDo list (even if with low priority)
I use latest ffdshow stable release http://ovh.dl.sourceforge.net/source...0705_clsid.exe for everything: divx, xvid, mpeg2, mpeg1, dv, mp4, ac3, etc. Bye |
9th September 2008, 22:46 | #442 | Link |
is it possible to save a Title Setting as default? I would like to use AVStoDVD for converting DV-material so I always need to edit the video settings to "DV Source". Hope that I have not overlooked something... And I found one missing entry in the "Default Language" settings: "DE - German". Thanks in advance, Filbert |
10th September 2008, 04:58 | #443 | Link |
The ffdshow version I was using caused those undersizing problems. I'm using the version you mentioned. But now I have a oversizing problem (50megs over). HC at smaller bitrates tends to oversize more. I just entered a custom size at 50 megs the default, and then re ran it and got to 4.36gb. So maybe when the bitrate is at lower 1500 - 2000. Have a lower default size. I'm running more tests tonight, the avg bitrate for these are 1500kb, roughly. To see if generally thats the case
10th September 2008, 11:33 | #444 | Link | |
AVStoDVD Dev
What do you think? Ah, thanks for reporting the missing language! Bye |
10th September 2008, 12:01 | #445 | Link | |
Greets, Filbert |
12th September 2008, 12:53 | #448 | Link | |
AVStoDVD Dev
PHP Code:
Bye |
13th September 2008, 00:18 | #449 | Link |
1500kb avg is terrible, but trust me hc performs miracles at lower bitrates. Try any other encoder and you will see what shit looks like. I don't think there's a problem with avstodvd its just as the bitrate gets lower hc tends to oversize more. I don't have any log files I deleted everything, but I will run another test, today or tommorow and I will give you the log.
13th September 2008, 20:06 | #450 | Link | |
Can you blush ?
better at low bitrates. Even below 1 MBit. The image is somewhat smoother / blured than HCEnc but has less visual artifacts. |
14th September 2008, 00:22 | #451 | Link |
I disagree totally. Quenc is really blocky imo, and aqe i put in the same department as cce it tends to make a lot of noise. I never tried mencoder though. But thats getting to much off topic... everyone has their opinions and my tends to be infavour of hcenc especially with lumgain and AQ. Solves all the blocking problems at higher bitrates...hehe
14th September 2008, 09:53 | #452 | Link | |
Can you blush ?
@gizzin:
@MrC: I´m currently trying to implement a "guided CQ'" interface for HCEnc similar to manolito´s HC_D2S which is compatible with the standard hc interface and thus not DVD2SVCD dependend. You can follow development here if you are interested: http://www.vmesquita.com/forum/index...ic,8888.0.html I might add a one pass VBR mode without CQ prediction as well. |
15th September 2008, 08:27 | #453 | Link | |
AVStoDVD Dev
What about writing a DLL (maybe an ActiveX DLL)? That would be great, because its spreading and implementation would be very easy. Look at MediaInfo... Bye |
15th September 2008, 13:19 | #455 | Link | |
AVStoDVD Dev
Just my 2 cents.... Bye |
15th September 2008, 23:44 | #456 | Link |
After trying 3 times I can't seem to get this dvd to author. Everytime I come back is error authoring or whatever, but it encodes properly. The only thing different is the source files are on a different hd...but I dont see how that will make a difference.
17th September 2008, 13:05 | #458 | Link | |
AVStoDVD Dev
For example, if your file as a 5+1 AC3 stream and if you use ffdshow, be sure that audio decoder mixer is configured properly. Bye |
19th September 2008, 09:49 | #459 | Link |
I ran into problems trying to keep 5.1 ac3 audio. The first time I did it, It ran through with ac3fix, but the audio was all garbled upon playback on my dvd players. Then I tried It again without ac3fix, but this time there was no audio, just the video. Finally I just re-encoded the audio and everything went a-ok. But no 5.1 surround booo. I tried it a couple times.
19th September 2008, 12:50 | #460 | Link | |
AVStoDVD Dev
Please force ac3 encoding and setup your ac3 decoder output to 6 channels, as I explained in a previous post to keep 5+1 sound. Bye |
