Old 13th March 2018, 07:36   #15661  |  Link
burt123
Fix available via auto-update.
Hi Atak,
Thanks so much for looking into this, I guess it was a "bug" of some sort.
So I have just finished doing a test after the new update, and I still had the original 13 job queue in place, as I had only done 3 before stopping due to the error.
So I didn't re load a new queue, instead I tested job 5, and it still errored, I had to re load job 1, as I deleted a few files from that when I rar'ed it up to send to you, and it worked to completion.
So I will reload the whole queue again, and it should be fine.
I'm still running Windows Server 2016, haven't quite finalized my Windows 7 situation, yet, but your Image Tool is doing a good job
Another thing I would like to mention again (referring to some PM's I sent you), I still don't think the Abort function works as well as it used to, when you could abort from the DE window.
Sure it abort's, after a short "think", but I don't have any luck with the job resuming from where it left off.
Anyway, it might work properly under W7.
Cheers
And thanks for your constant support of this great program you've created
burt123 is offline   Reply With Quote
Old 13th March 2018, 10:44   #15662  |  Link
GZZ
Originally Posted by burt123 View Post
Hi Atak,
I can confirm that the Abort not always work as it should. Some time you press Abort and nothing happen, DE window keep running. Killing it in task manager makes the application to abort.
Pressing abort doing initialization (copy Video file in DE window) also dosnt work as it should.
GZZ is offline   Reply With Quote
Old 13th March 2018, 13:06   #15663  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Literally a typo (one word) in code!
Old 14th March 2018, 19:08   #15664  |  Link
byteshare
ByteShare
byteshare's Avatar
Originally Posted by byteshare View Post
He ran Prime95 for about 3 hours no issues for CPU. Ran HeavyLoad test for RAM, no issues. I'll have him update AVISynth.
AVISynth update didn't help
Also try with simpler x265 command line...
Will have him try this now. The issue isn't happening with StaxRip, not sure what is exactly different but I know there are lots of differences between the two, for example RipBot is better
Old 14th March 2018, 19:12   #15665  |  Link
MaistroX
Just tryed Another Movie with DE Mode Active in settings...
Fist off, it demuxes the *.mkv without subs (I choose all subs) and no Sound at all, even thou I have choosen to keep DTS-MA as first choice and DTS track as second.
(the *.mkv has DTS-MA and DTS tracks + 6 subtitles)
Thatīs DE Mode for me! *EDITED*
just tryed without DE Mode, and no sound or subtitles are avalibe after demux!!! :/
Please help!
Regards MaistroX
MaistroX is offline   Reply With Quote
Old 14th March 2018, 19:19   #15666  |  Link
MerolaC
Atak, is there any chance that for the next release you add a lossless output for x264?
--qp0?
Thank you in advance!
MerolaC is offline   Reply With Quote
Old 14th March 2018, 19:23   #15667  |  Link
sneaker_ger
It's --qp 0
But is this not possible with the current version? Instead of --qp 0 you can also use --crf 0 (8 bit encoding) or --crf -12 (10 bit encoding), I believe RipBot calls it "CQ".
Old 14th March 2018, 19:28   #15668  |  Link
MerolaC
Originally Posted by sneaker_ger View Post
It's --qp 0
Thank you for your comment.
Yes, I mistyped there the switch.
I will check.
But, i don't think crf is the same as qp 0.
Old 14th March 2018, 20:02   #15669  |  Link
Atak_Snajpera
Please help!
Regards MaistroX
Remove current ripbot264 and download again v1.22.0.
Old 14th March 2018, 20:26   #15670  |  Link
MerolaC
I realized that I can just modify the job1_EncodeVideoPass1.cmd script.
Thank you.
Old 14th March 2018, 20:39   #15671  |  Link
Atak_Snajpera
I think you can force --qp 0 in profile.
Old 14th March 2018, 20:41   #15672  |  Link
MerolaC
Yes, you can, but the cfr switch stays there and i think it overides the qp one.
Still, since I can modify the cmd, it's not problem.
Thank you Atak!
Old 14th March 2018, 20:43   #15673  |  Link
sneaker_ger
Result is the same whether you activate lossless encoding via --crf or --qp. Only to keep in mind that during 10 bit encoding --crf 0 is not lossless, only --crf -12.
Old 14th March 2018, 20:47   #15674  |  Link
Atak_Snajpera
Thank you Atak!
No --QP switch in profile will override --CRF value in gui.
Old 14th March 2018, 21:25   #15675  |  Link
MerolaC
Got it to both.
Thank you!
Old 14th March 2018, 21:37   #15676  |  Link
MaistroX
@Atak_Snajpera
I did that just now, Remux works again and then I tryed a DE Mode with 2 servers.
RipBotx264 started copying "Please wait.....copying video file to shared folder...", is that something it should do when "Move video file to shared folder (not recomended)" is NOT ticked?
See here -> https://imgur.com/a/7AHNG
Regards MaistroX
Old 15th March 2018, 11:51   #15677  |  Link
Atak_Snajpera
@MaistroX
Yes.
BTW. Chunk Size = 0 (one chunk per server) may take slightly less time in your case (encoding on single machine)
Old 15th March 2018, 18:54   #15678  |  Link
MaistroX
@MaistroX
Yes.
Jsut tryed that, got alot of errors, se PM with link to all info!
Regards MaistroX
Old 15th March 2018, 19:35   #15679  |  Link
Atak_Snajpera
@MaistroX
Forget about DE mode...
Old 15th March 2018, 19:46   #15680  |  Link
MaistroX
@MaistroX
Why, it should work right?
