Old 24th November 2005, 08:47   #41  |  Link
Pookie
I thought it was my source and choice of codec.
Pookie is offline   Reply With Quote
Old 1st February 2006, 05:00   #42  |  Link
iceborne
iceborne's Avatar
i keep on getting washed out color whenever i applied this script:
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\mt_MaskTools.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\removegrainsse2.dll")
LoadPlugin("C:\Program Files\DGMPGDec\dgdecode.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\UnDot.dll")
mpeg2source("e:\dvd\divergence.d2v")
Telecide(guide=1).Decimate()
crop(4,60,-4,-60)
trim(5000,10000)
dull   = last
sharp  = dull.LimitedSharpenfaster( smode=4, dest_x=720, dest_y=368 )
Soothe( sharp, dull, 20 )
undot()
but if i leave out the resizing parameter
"dest_x=720, dest_y=368 ",
everything's good.
can anyone tell me what's wrong with my script?
iceborne is offline   Reply With Quote
Old 1st February 2006, 05:32   #43  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Heh, I thought it was LSFaster for a few, until I noticed that you never resized dull. Pick a good scene with very sharply defined colors, and you'll notice the chroma will bleed horribly, since it gets copied from the second argument, not the first. Lesson: Always remember to resize both clips.
Old 1st February 2006, 05:48   #44  |  Link
iceborne
iceborne's Avatar
good man!
here's my new script
crop(4,60,-4,-60)
LanczosResize(720,368)
dull   = last
Soothe( sharp, dull, 24 )
undot()
trim(5000,10000)
btw, does it matter where i put undot()?
Old 1st February 2006, 06:41   #45  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
try:
crop(4,60,-4,-60)
dull   = last.LanczosResize(720,368)
undot()
trim(5000,10000)
Old 2nd February 2006, 04:39   #46  |  Link
iceborne
iceborne's Avatar
thanhs guy. another question do you think sooth(sharp, dull, 24) is too low? or should i raise it to make the image sharper
Old 12th February 2006, 01:46   #47  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
In case anyone is feeling the burn and needs for speed, masktools 2:
function Soothe(clip sharp, clip orig, int "keep")
Assert(sharp.width == orig.width && sharp.height == orig.height,
 \  "Soothe: clip dimentions must match!")
keep  = default(keep, 24)
keep  = (keep>100) ? 100 : (keep<0) ? 0 : keep
KP    = string(keep)
diff  = mt_makediff(orig,sharp)
diff2 = diff.temporalsoften(1,255,0,32,2)
diff3 = mt_lutxy(diff,diff2,  "x 128 - y 128 - * 0 < x 128 - 100 / "  + KP
 \                           + " * 128 + x 128 - abs y 128 - abs > x " + KP
 \                           + " * y 100 " + KP + " - * + 100 / x ? ?")
return( mt_makediff(orig,diff3,chroma="copy first") )
[edit: Added a check for dimentions, since that's the most common misuse. Also Didée TS suggestion.]
[edit2: Added both to wiki: http://www.avisynth.org/mediawiki/Soothe ]
Old 12th February 2006, 02:33   #48  |  Link
Didée
Even faster:
'cause here, chroma isn't interesting anyways, and TS runs faster when not having to also process the UV planes ...
Old 12th February 2006, 06:03   #49  |  Link
iceborne
iceborne's Avatar
cool, will try on next encode.
Old 12th April 2006, 14:11   #50  |  Link
diazlaz
Is it possible to get the soothe function to work, when a frame is being resized by LS? Example, currently have a video that is sized at 352,480, and using LimitedSharpenFaster(ss_x=1.2,ss_y=1.2,dest_x=704,dest_y=480,Smode=4,soft=24) to resize it to 704x480, when soothe runs, it errors with:
YV12LUTxy: Clip size must be the same.
KP    = string(keep)
diff  = yv12lutxy(orig,sharp,"x y - 128 +", U=1,V=1)
diff2 = diff.temporalsoften(1,255,255,32,2)
diff3 = yv12lutxy(diff,diff2,  "x 128 - y 128 - * 0 < x 128 - 100 / "  + KP
 \                           + " * y 100 " + KP + " - * + 100 / x ? ?",  U=1,V=1)
return( yv12lutxy(orig,diff3,"x y 128 - -",U=2,V=2) )
Thanks,
Laz.
diazlaz is offline   Reply With Quote
Old 12th April 2006, 15:12   #51  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
See Mug Funky's last post, on this page. Also consider using the version I posted.
Old 15th April 2006, 23:37   #52  |  Link
Oline 61
The output of this script is awesome, but it is extraordinarily slow. Like running pixiedust on a 4096x1920 image. Huffyuv can encode it at ~1.5 fps. Can anyone recommend a way to speed it up?
MPEG2Source("VTS_06_1.d2v",cpu2="ooooxx")
Telecide(guide=1,post=1,back=1)
Decimate()
Crop(2,56,716,362)
LanczosResize(1280,544)
RemoveGrain(mode=1)
dull=fft3dfilter(sigma=1.5)
sharp=LimitedSharpen(dull,
	\	ss_x=1.5, 		ss_y=1.5,
	\	dest_x=1280, 		dest_y=544,
	\	Smode=3, 		strength=115,
	\	Lmode=3, 		edgemode=1)
Soothe(sharp,dull)
Oline 61 is offline   Reply With Quote
Old 16th April 2006, 19:46   #53  |  Link
krieger2005
krieger2005's Avatar
@Oline 61: Don't use fft3dfilter. If the speed-improvement is not enought don't use limitedsharpen... and so on
krieger2005 is offline   Reply With Quote
Old 16th April 2006, 20:59   #54  |  Link
Oline 61
Without fft3dfilter there is no denoising. The output looks horrible because half of what is being sharpened is film grain.
I have tried putting fft3dfilter before the resize, and I think it might just be fast enough that way.
height=1280
width=544
Decimate()
Crop(2,56,716,362)
in=fft3dfilter(sigma=1.5)
dull=LanczosResize(in,height,width)
sharp=LimitedSharpen(in,
	\	dest_x=height, 		dest_y=width,
	\	Lmode=1, 		edgemode=1)
Soothe(sharp,dull,32)
Old 17th April 2006, 02:53   #55  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Well, ft3d isn't the only denoiser; for similar results you might try a degrainmedian (or two). Or possibly mipsmooth, but that's harder to control.
Old 17th April 2006, 04:58   #56  |  Link
Oline 61
DegrainMedian doesn't do all of the things I need. Removing grain is great, but it doesn't clean up the compression artifacts from the DVD like fft3dfilter does. I've got it up to about 2.6 fps for a turbo first pass. That is acceptable. Here is the script:
SetMemoryMax(768)
width=1280
height=544
Decimate()
Crop(2,56,716,362)
dull=BicubicResize(in,width,height)
	\	dest_x=width, 		dest_y=height,
	\	Smode=3, 		strength=100,
Soothe(sharp,dull)
EDIT: I'ma give LimitedSharpenFaster() a shot too.
Old 5th June 2006, 23:59   #57  |  Link
audioslave
audioslave's Avatar
I'm getting an error when using Soothe(). VDub says:
Script error: There is no function named "yv12lutxy".
What am I missing?
My script
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\LimitedSupport_09Jan06B.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\mt_masktools.dll")
Import("C:\Program Files\AviSynth 2.5\plugins\LRemoveDust.avsi")
Import("C:\Program Files\AviSynth 2.5\plugins\LimitedSharpenFaster.avsi")
Import("C:\Program Files\AviSynth 2.5\plugins\Soothe.avsi")
Mpeg2Source("D:\Hea\Video\DVD\Temp\Temp.d2v")
LRemoveDust_YV12(17,2)
Crop(6,78,710,420)
dull  = last.LanczosResize(704,416)
sharp = dull.LimitedSharpenFaster(dest_x=704,dest_y=416)
Soothe(sharp,dull,20)
Addborders(0,80,0,80)
-AudioSlave
audioslave is offline   Reply With Quote
Old 6th June 2006, 00:12   #58  |  Link
audioslave
audioslave's Avatar
I solved it. I didn't have MaskTools in my plugin directory...
-AudioSlave
Old 20th January 2007, 06:47   #59  |  Link
HeadBangeR77
HeadBangeR77's Avatar
I'm just thinking while writing If we resize, we can't write like e.g.:
dull = last
sharp = dull.LimitedSharpenFaster(dest_x=720,dest_y=304)
provided we haven't resized (to our destination resolution) before. That's the mistake iceborne made above in his first script. Then the comparison clip /background (dull) would have a different resolution than the sharpened clip, and the whole function didn't make sense. However, if we write ...
dull = last.LanczosResize(720,304)
than we don't have to specify the resolution arguments in LSF, do we?! I mean sharp = dull + LSF, and dull has already been resized just one line above. So we can write afterwards ...
sharp = dull.LimitedSharpenFaster() ?
How blind & stupid have I been! (bangs his head against the wall ) If the above is right, then LSF has the destination resolution, instead of the source resolution, as an input. That changes the supersampling effect, though the function's arguments don't change, and thus the sharpening strength too. Could anyone confirm /deny the above?
If that's true, I've spent all my day just in vain, encoding samples I didn't actually want to encode. It would rather not matter, if I was downsizing a bit, like in the above examples, but I'm upsizing atm, and that changes a lot ...
"Only two things are infinite: the universe and human stupidity, and I'm not sure about the former."
HeadBangeR77 is offline   Reply With Quote
Old 20th January 2007, 07:31   #60  |  Link
Didée
# how to soothe LimitedSharpen when LS is set up to change resolution
dx = your_target_width
dy = your_target_height
base = last.LanczosResize( dx, dy )
shrp = last.LimitedSharpen( dest_x = dx, dest_y = dy )
shrp.Soothe(base)
