19th October 2011, 17:39 | #6321 | Link | ||
19th October 2011, 19:52 | #6322 | Link | ||
Second, you're just boosting some frequency range. It had been a known problem with iPods that when using EQ you could get clipping fairly easily. Apple JUST fixed it with the iPod Touch 4 and probably others. Fix was simple, boost frequency, then dial back overall gain.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
19th October 2011, 20:13 | #6324 | Link |
"Editions" and "ordered chapters" are only a different names for the same feature, which is actually not included in the matroska part of the LAV_splitter. Therefore ATM you will have to use Haalis splitter if you need this. Hopefully, this feature will be integrated in the future, but of course it is totally nevcariel choice if and when this may happen.
20th October 2011, 10:00 | #6326 | Link |
Do you have an Nvidia GPU? If not, it won't work.
SETUP: Win 10/MPC-HC/LAV/MadVR HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750 |
20th October 2011, 12:35 | #6327 | Link |
I want to swap my ATI HD5450 for a NVIDIA card for two reasons:
1. Use CUVID and that way: 2. reduce CPU usage. I want to use my CPU for a heavy frame interpolation script with avisynth. What the best card for CUVID? |
20th October 2011, 13:07 | #6328 | Link | |
Here in Portugal, such a card is available for about 125 EUROS. The GT440 or the GTS450 would also be good alternatives, but are from an older generation. You may compare other editions here: http://www.geforce.com/Hardware/GPUs
Win 11 x64, Geforce RTX 4060 Ti 16GB, TV Sony KD-55X8509C HDMI, Denon AVR-X2700H, Core i7-9700K, 32GB DDR4, Creative Labs Gigaworks S750 7.1 speakers MPC Home-Cinema madVR LAV Filters |
20th October 2011, 13:09 | #6329 | Link |
Hi. I asked this on the CUVID thread but I got pointed here, so here I fire my question.
I'm trying to fix an issue I have with h264 decoding: when video has 9, or 16 ref frames, the seeking will disable the video; I have to seek some more to get the video back on, and it doesn't always work. The resolution of the video doesn't seems to be important, it happens for both dvd or fullhd resolutions. Using mpc-hc as player, haali as splitter (need it for ordered chapters), ffdshow for audio decoding (exept FLAC), video decoding done via software, for fullhd the cpu (AMD 4cores) usage is less than 20% (mardock scramble), haali or madvr for rendering. So the question is: what is causing this seek issue? my box horsepower should be more then enough, and there aren't spikes of cpu or gpu usage when it happens. |
20th October 2011, 13:25 | #6330 | Link |
Firefox User
Got some feedback regarding my rv34seekkeyframe patch/"hack":
The patch did its job well, but sometimes the audio become muted. When seeking to same point again, the audio recovers. Actually whats the problem between LAV Audio, LAV Video, and the whole DirectShow graph? |
20th October 2011, 15:35 | #6331 | Link | |
20th October 2011, 17:04 | #6335 | Link | |
20th October 2011, 17:09 | #6336 | Link |
Did you enter any advanced configuration, or was the box empty?
20th October 2011, 17:23 | #6338 | Link |
Thanks, should be fixed.
