18th May 2006, 07:34 | #401 | Link |
Najarenthur
I could do that. It would be better, but to measure better compression this way should do it.
I think, I can use for the same source the same .stats file, because settings in 1.pass are identical, right? It would speed up tests extremely. I will get some tests on an Opteron 144@2250 too. So we will see, how speed differs from the settings. But he will use newest Sharktooth's profile. |
18th May 2006, 13:13 | #403 | Link |
Mr. Sandman
Here and there this forum.
Im not even sure it is completely compliant, that's why i asked for testers. @Deinorius: i thought you were using constant quant... crf is not good for that comparison.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 18th May 2006 at 13:19. |
18th May 2006, 13:25 | #404 | Link |
You can use the same first pass stats file if the settings you use for first pass are the same. Since you are testing turbo, that's probably the case.
I'm not sure how constant quant fits into all of this, but I still imagine that 2pass is the best scenario to test the efficiency of settings, because it ensures that filesizes are the same, so a visual judgement is the be-all-end-all. |
18th May 2006, 13:31 | #405 | Link |
Mr. Sandman
then you'll need PSNR or SSIM or whatever to distinguish one encode from the other...
19th May 2006, 16:27 | #406 | Link | |
Mainconcept's HD DVD preset shows 2 B-frames, so maybe it is best to use 2 instead of 3 to be on the safe side. |
19th May 2006, 23:02 | #407 | Link | |
22nd May 2006, 14:19 | #410 | Link |
Mr. Sandman
v26: updated SA-HD-DVD profile.
24th May 2006, 17:04 | #412 | Link |
Mr. Sandman
ill see what i can do
24th May 2006, 18:05 | #413 | Link |
HDConvertToX author
@smok3
quick way: open megui, load a profile , check show command line. BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
27th May 2006, 03:07 | #414 | Link |
I have HD DVD player buy in USA. When I put H264 video from x264, I have warning messages
about maximum bitrate (--vbv maxrate at 12000kps and --vbv bufsize use ) in HD DVD authoring software (professional). There is some pic over the maximum bitrate of HD DVD specification. And when I play in HD DVD player (DVDR with HD DVD image), the video block when there is pics of maximum bitrate. The Sonic Scenarist tutorial say the GOP must be less than 0.606 second, so 18 frame in NTSC framerate (29.97) and 15 frame in PAL framerate (25). for AVC (H264 video) and VC1. The number of B frame is 2 no more. No information about MBAFF and PAFF use (I don't recommend it because there is not lot of hardware chipset that support it). I need to know how I can encode in CBR with MeGui (-ratetol at 0 don't work -> change at 0.1) to test video in HD DVD player. And we don't need to put maxbirate at 25Mbit/s because at 10Mbit/s and ABR at 8Mbit/s the picture is beautiful (LCD Samsung 42" HD Ready). Golgot13 Last edited by Golgot13; 27th May 2006 at 09:44. |
27th May 2006, 03:18 | #415 | Link | ||
28th May 2006, 03:52 | #416 | Link |
Golgot13 could you please try this encode with Scenarist 4
http://rapidshare.de/files/19907080/...part1.rar.html http://rapidshare.de/files/19907412/...part2.rar.html thx in advance
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 28th May 2006 at 04:06. |
29th May 2006, 01:05 | #417 | Link |
The big problem with x264 encoder is " NAL_HRD_PARAMETER ".
In this header, somes professionnal software read information about H264 video file. The most import information is the bitrate (there is a minimum and a maximum to be compliant with HD DVD and BluRay compliant). The last version of Scenarist 4 don't accept file without this header. I must to use a older version to mux the video data. And demux (with transport stream software) the EVO file to have good file (with the most important header: NAL, VUI,...) I recommend to encode in CBR mode but I don't know how I can do this with MeGui (no option in MeGui to encode in CBR ???) Golgot13 Last edited by Golgot13; 2nd June 2006 at 00:48. |
29th May 2006, 01:17 | #418 | Link | |
Scenarist 4 accept mp4 container but with only video stream H264 (compliant with HD DVD and BluRay specification, with all headers....) AAC audio track is not compliant HD DVD/BluRay. Golgot13 Last edited by Golgot13; 29th May 2006 at 09:53. |
1st June 2006, 20:06 | #419 | Link |
Huh?
On the iPod profile, the "I4x4" and "P4x4" macroblock options are not greyed out but they aren't enabled either. If I enable them, will the encode still be playable on an iPod?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. |
2nd June 2006, 03:09 | #420 | Link | |
Mr. Sandman
