27th November 2012, 16:25 | #20441 | Link |
SuperVirus
Correct. However no one needs ACM for playing MP2 or ATRAC3 stored in AVI, right?
Besides, when I said "RealAudio ATRAC3", I didn't mean that low-quality ACM encoder, which cannot go above 132kbps, I was talking about RealProducer 8, which can use up to 352kbps. And even though the encoder doesn't support other sampling frequencies than 44.1kHz, one may apply a couple of workarounds in order to get proper playback @48kHz. Now, going back to the topic, ... |
29th November 2012, 05:01 | #20442 | Link |
Bug report:
When entering: 03:08:43.176 into the "Go To..." window it goes to: 00:08:47.159 instead. Also when dragging window to different screen the subtitles become stretched until I resize a little bit to fix the aspect ratio of the subtitles. Thanks. |
29th November 2012, 19:27 | #20443 | Link |
Bug report:
in the last official build, when a video is deoced using DXVA and the Overlay Mixer (I'm on XP), the little [DXVA] text does not appear in the status bar, although DXVA is used (confirmed by looking under Play->Filters->MPC Video Decoder). It appears in the status bar when using a VMR renderer. |
30th November 2012, 07:20 | #20444 | Link |
Fantasy Codecs writer
S.Chinese update
http://www.mediafire.com/?c0cwd1u8xlh77aa |
1st December 2012, 08:12 | #20445 | Link | |
MPC-HC Helper xD
1st December 2012, 12:57 | #20447 | Link |
Fix this
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
1st December 2012, 13:47 | #20448 | Link |
S.Chinese update
http://www.mediafire.com/?l39f79wuy625xmv |
2nd December 2012, 19:28 | #20452 | Link |
Is there any way to lock the position (aspect ratio) of PGS subtitles in MPC-HC?
The subtitle's position while playing a 1280x720 video at 100% is perfectly fine, but the moment you go full-screen, the subtitle layer gets stretched over the entire desktop. And in my case the stretching is especially noticeable, because I'm using a 4:3 monitor.
My hobby website |
3rd December 2012, 21:26 | #20453 | Link |
Is there anything that can be done about the REW/FWD? On fastest (4x) it's really slow, or is there some limitation on why it is left like that?
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards MPC-HC (madVR, LAV Filters, XySubFilter) Sony Bravia 85X950H/85XH95 Yamaha RX-V685 Yamaha Piano Black NS-777/555/C444/YST-SW315 |
3rd December 2012, 21:45 | #20454 | Link |
Is there a way to override PGS subtitle positioning? The subs go over the video portion when the aspect of the file is 2:35:1 and I would like it to go on top of the black bars or if the file has been cropped and encoded then it should position relative to the frame and be positioned inside the black bars when the video goes fullscreen.
3rd December 2012, 23:45 | #20455 | Link |
Wouldn't this be possible to do and quite easy to code.
Option to automatically change display refresh rate to match content when MPC-HC goes full screen, and back to normal when it exits full screen? Atleast it's easy to write an app to check current refresh rate, supported refresh rates and make it switch when you want but is there some limitation why this is not on MPC-HC yet? I think it would be an awesome feature to watch Blu-rays at 24p.
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards MPC-HC (madVR, LAV Filters, XySubFilter) Sony Bravia 85X950H/85XH95 Yamaha RX-V685 Yamaha Piano Black NS-777/555/C444/YST-SW315 Last edited by Joniii; 4th December 2012 at 09:19. |
4th December 2012, 09:19 | #20456 | Link |
Is MPC-HC still actively developed or just bugfixes?
4th December 2012, 11:30 | #20458 | Link | |
4th December 2012, 14:11 | #20459 | Link |
Wow, I've been using MPC for years and never noticed that before. Thanks for the info.
Btw, it has the same problem as madVR. If I have another application on background (WMC) that goes automatically full screen when mpc exits from full screen @24p, the display refresh rate is not restored. As if mpc and madvr would still think that mpc is fullscreen and running.
4th December 2012, 19:48 | #20460 | Link | |
updates in Catalyst 12.11 beta 11
http://support.amd.com/us/kbarticles...etadriver.aspx Quote:
Win 8.1 -- Core 2 Duo E7300 & Intel Q43 GMA 4500 |
