3rd April 2008, 15:02 | #1802 | Link |
@MuLTiTaSK
Thanks for reporting the tooltip issue. I'll add the x264 switches as real controls. @Flexy There is not much demand and thus no first class support. Run DGIndex on your VOB files and copy the ifo file using same name as d2v file. Open the d2v file. Never tried this but it should work.
3rd April 2008, 16:16 | #1803 | Link |
Najarenthur
I've got a bug with StaxRip. Using this script
MPEG2Source("VTS_01_1.d2v") TomsMoComp(-1,5,1) Crop(22,8,-26,-8) RemoveGrain(24) DeGrainMedian(limitY=255,limitUV=255,mode=5,interlaced=false,norow=false) Import("D:\VIDEO\AviSynth 2.5\plugins\SeeSaw.avs") a=last b=a.FFT3DGPU(sigma=2.5) SeeSaw(a,b, NRlimit=3, NRlimit2=4, Sstr=1.5, Slimit=5, Spower=4, Sdamplo=5, Szp=16) gradfun2db(thr=1.6) After updating to your latest unofficial build, I have to say this: I hate it to update StaxRip and all of my own profiles get erased. It's no great deal with the filter profiles because I can copy everything into a text file, but the Encoder (Video & Audio) profiles are a greater problem. Wouldn't it be better at resetting just your standard profiles gets updated and everything else spared? PS.: You put two Audiofilter to your profiles? Did you start investigating into audio edit with Avisynth? Last edited by Deinorius; 3rd April 2008 at 16:19. |
3rd April 2008, 18:53 | #1804 | Link | |||
3rd April 2008, 19:52 | #1805 | Link | ||
Najarenthur
What can I do more to find the culprit? I tried SetMemoryMax(64) too, but it didn't work. Quote:
But is it possible to update just the profiles, which get updated? I see. |
3rd April 2008, 21:09 | #1806 | Link | |||
StaxRip beta Changelog: Quote:
3rd April 2008, 22:20 | #1811 | Link |
Najarenthur
OK. Here you can find SeeSaw and here is FFT3DGPU. (You need to copy the hlsl file into plugins folder too. fftw3.dll needs to be pasted into system32 folder.
Well, it's your decision. *lieb guckt* Last edited by Deinorius; 3rd April 2008 at 22:24. |
4th April 2008, 09:05 | #1815 | Link | ||||
Import("D:\Software\AV\StaxRip Anwendungen\AviSynth Plugins\SeeSaw v0.3e.avs") a=last b=a.FFT3DGPU(sigma=2.5) SeeSaw(a,b, NRlimit=3, NRlimit2=4, Sstr=1.5, Slimit=5, Spower=4, Sdamplo=5, Szp=16) The cmdl tooltip on the donate menu item is because the tooltips come from the underlying command which executes a cmdl, I've added now special handling for the cmdl command, instead of showing the tip of the command it shows the parameter, the command line which in this case is a URL. The parameter for the cmdl command can be files, folders, url's, everything the shell can handle. The menu items to open the source and target dir use the same command and macros of the dirs as params which are now shown as tooltip. Quote:
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 4th April 2008 at 09:09. |
4th April 2008, 13:11 | #1817 | Link |
4th April 2008, 15:12 | #1818 | Link |
Skittle
Well according to staxrip... its using vorbis (lancer) vintage 2005.
Even the lancer builds have been updated. The last one I could find was from 2006. (site is in japenese) http://homepage3.nifty.com/blacksword/ Lancer builds seem to be sse optimized versions of libvorbis.dll and oggenc. There also appears to be a multithreaded build. I havnt tested them. Libvorbis: http://www.rarewares.org/ogg-libraries.php |
4th April 2008, 15:31 | #1819 | Link |
Which Vorbis build should StaxRip use, what is the download URL and does it work with most common CPUs?
4th April 2008, 15:44 | #1820 | Link |
Skittle
Umm I would assume a build from the latest source tree:
http://downloads.xiph.org/releases/vorbis/ Im no expert with ogg/vorbis... but I just thought it was odd to use a build from 2005. |
gui, h.264, h.265, hevc, mkv, x264, x265 |
