22nd April 2019, 08:32 | #55881 | Link | |
3700X - RTX2070 - 970EVO - EVGA Supernova 750W Gold - Sony KD55X720E |
22nd April 2019, 09:28 | #55882 | Link | ||
@hotripper just stick to power saving. it not changing the power that's send over HDMI and it does other more complicated things... and it will not lower your general performance it just trys to waste less power. and you should leave pre rendered frames to application control madVR by default uses 3 or 8 by default depending on the rendering surface and we still can't see your image. |
22nd April 2019, 14:14 | #55883 | Link |
Hi all, I've been using MadVR (v 0.89.5) with MPC-HC for over 2 years now without problem. I'm still running a PC with Win XP SP3. Today, I encountered this error message for the 1st time:
madHcCtrl.exe - Entry Point Not Found The procedure entry point _time32 could not be located in the dynamic link library msvcrt.dll It appears every time I launch a new video. I've tried reinstalling MPC-HC, and also reinstalled MadVR (with latest 0.92.17) to no avail. That error message still comes up. Any idea how I can fix it? Last edited by jcwc; 22nd April 2019 at 14:18. |
22nd April 2019, 15:51 | #55884 | Link |
Did you by chance install or update another application just before this started appearing? Maybe another application updated/reverted that DLL and it caused the problem.
Did you try reinstalling older versions of MPC? I'm not sure if XP is still officially supported in newer versions.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
22nd April 2019, 18:13 | #55886 | Link | |
One thing i don't understand is when i do play a hevc main file with madvr, the lav filter uses avcodec and GPU is around 60% and cpu around 10%. I had a hevc main10 version as an experiment and dxva2cb was used and gpu was around 65% and cpu around 8%. So the gpu card is rendering either way with small % differences. So what is the gpu card doing with hevc main? Last edited by coolgit; 22nd April 2019 at 18:21. |
22nd April 2019, 20:34 | #55889 | Link |
shader work.
chroma scaling, upscaling dithering the list is long. real hardware decoder are not using shader to decode they use a so called ASIC which is a an extra part on the GPU dedicated to only do these tasks. if you go to the windows taskmanager to your GPU you may see the "video decode" not sure if this works with AMD. |
22nd April 2019, 20:42 | #55890 | Link |
Thanks for the clarifications huhn.
This link you previously posted https://cdn2.techbang.com/system/ima...png?1492501244 has hevc main. Do you know what window version it was? Does window 7 (mine) has anything to do with it? |
23rd April 2019, 00:49 | #55892 | Link | |
MPC-HC isn't the problem, the error message doesn't appear if I select another video renderer like Haali or VMR. Only appears with MadVR. Oh, I also just installed MPC-BE and when I use MadVR, the same error message appears. Last edited by jcwc; 23rd April 2019 at 01:43. |
23rd April 2019, 03:11 | #55894 | Link |
frustrated. 4k plays smoothly with just a jump every now and again and 1080p does more jumping than the 4k. No setting I give it seems to fix it. The NvidiaProfile thing doesn't seem to help it either. gpu is at 41%
23rd April 2019, 12:39 | #55895 | Link |
@jcwc, you probably need the Universal CRT. You can get that by installing these VCRedist:
https://download.microsoft.com/downl...redist.x86.exe https://go.microsoft.com/fwlink/?LinkId=746571 |
23rd April 2019, 12:41 | #55896 | Link | |
msvcrt.dll is a standard Windows file, it seems strange that this error would appear out of the blue without any change to apps or the OS. Have you tried older versions of madVR? Maybe try successive older versions until you find one that works. Also search your system for copies of msvcrt.dll and check the timestamp to see if they have been changed recently? I don't remember enough about WinXP to troubleshoot this.
23rd April 2019, 14:26 | #55897 | Link |
New Nvidia Drivers. Changes and Fixed Issues in Version 430.39:
Fixed Issues in this Release [madVR][HDR]: MadVR is not rendering videos in HDR mode using MPC player. [200505657] [Surround][G-SYNC][Pascal GPU]: G-SYNC does not engage when using Surround resolution. [200505986] Random desktop flicker occurs on some multi-display PCs [2453059] Memory leaks occur when launching games. [2551904]
Win 10 x64 LTSC 1809, 16 GB RAM, Nvidia GTX1080, AMD FX-8350 |
23rd April 2019, 17:42 | #55900 | Link |
Thank you, sir. For some reason I thought I was replying to the driver thread. In there it's claimed they're passing correct metadata and a few other awesome fixes for us. This could be our new benchmark driver finally.
