9th December 2015, 15:42 | #34541 | Link | |
Otherwise, if its says IVTC, it is actually doing something, since thats not a "source is telecined" marker, but actually indicates a processing step being performed.
9th December 2015, 22:01 | #34543 | Link | |
How "intelligent" is the processing? Let's say, for example, if I have by accident placed a Blu-Ray rip in a folder that has the deint=Film tag, will madVR "know" what to do with the picture, i.e. to leave the source untouched (because it's native progressive)? Just asking because I think I've sometimes seen the OSD say "IVTC" when I think it probably shouldn't have. But if it doesn't do any harm, I guess I'd better just ignore it. Last edited by Uoppi; 10th December 2015 at 09:02. |
10th December 2015, 02:52 | #34545 | Link | |
10th December 2015, 11:39 | #34547 | Link | |
So, unfortunately, this is only for products that already have HDCP 2.2 support. |
10th December 2015, 11:50 | #34548 | Link |
The word "stealing" is probably a bit harsh. It suggests something illegal which they didn't do. They did copy some ideas from madVR, including an algorithm I invented myself, without even mentioning madVR anywhere. But I suppose that's how the world works these days.
10th December 2015, 15:29 | #34549 | Link |
I think it's depends on the certain individual(s), and this mentality always existed.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
10th December 2015, 15:30 | #34550 | Link | |
2) HDCP 2.2 is the least of our worries, first because there is no content using it from a PC, and second because the lack of it is already addressed by the HD Fury Integral and other HDMI tools. Frankly, I'm interested in getting 18Gb/s bandwidth than getting HDCP 2.2, which I don't care about one bit.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K |
10th December 2015, 15:40 | #34551 | Link | ||
There is no secret sauce involved here. I just wanted to correct that HDCP 2.2 does not magically get added onto AMD products, which don't already support HDCP 2.2 natively within their display engine, which they currently do not. The Club3D solution is an active adapter that converts, and it's also a repeater to mirror HDCP functionality, which is already included on the source device. Quote:
Again, I just wanted to correct you here, so that no one thinks they can buy the adapter and magically have HDCP 2.2, when there is no support on the source device, which is the case with current display engine(s) on AMD's HW. There is a lot of miscommunication on the net about this, which is unfortunate (because most media don't understand it). Last edited by iSunrise; 10th December 2015 at 15:48. |
10th December 2015, 16:01 | #34552 | Link | |
Quoting myself:
In my case the rendering queue sizes were set too high. By reducing them from 24 in my case to a maximum of 21 eliminates the described problem (everything from 4 up to 21 seems to work fine). Up to this driver I never changed the rendering queues and always used 24 without problems. Donīt know why Crimson wants smaller queue sizes, but now it works. The number of presented frames in advance has no influence by the way. So now I can use Crimson drivers. And the missing video settings from Catalyst (most of them were killed in Crimson drivers) can be accessed by DXVA checker or RadeonMod utility. Hannes. Last edited by hannes69; 10th December 2015 at 16:05. |
10th December 2015, 16:08 | #34553 | Link |
I have some questions:
Is the problem in https://trac.mpc-hc.org/ticket/3356#comment:11 present with madVR too? Should I restart the player for every option I change in madVR? If not, for which isn't necessary? I tried let the TV do the upscale instead of madVR by setting in devices > display modes a lower resolution, but my Samsung simply showed the lower res + refresh rate I set; I know that madVR has better quality, but how can I still let the TV do the upscale? Thank you. |
10th December 2015, 16:22 | #34554 | Link | |
Model Product Name: DisplayPort™ 1.2 to HDMI™ 2.0 4K60Hz Features Club 3D DisplayPort 1.2™ to HDMI™ 2.0 Active Adapter Compliant to DisplayPort Specification 1.2 for 1.62Gbps,2.7Gbps and 5.4Gbps per lane. Effective (video) bandwidth 17.28Gbps Compliant to HDMI™ Specification 2.0, data rate up to 6Gbps per TMDS channel. Total throughput 18Gbps Supports full link training and no link training Repeater for HDCP 1.3 and HDCP 2.2 24-bit color and 4:4:4 color sampling Internal YCbCr 4:4:4 /4:2:2 to YCbCr 4:2:0 conversion capability Supports UHD resolutions up to 3840 x 2160p @ 60Hz and 1080p 3D Repeater for HDCP 1.3 and HDCP 2.2 Powered by USB Port (no external power needed) At least I won't be part of the misinformation stream anymore Glad I sent the R9 Fury back, we'll definitely have to wait for Arctic Island for this (not that I care about HDCP 2.2 support). This being said, the lack of HDCP 2.2 is a non-issue with an HD Fury Integral, but I accept that it's a bit of an expensive add-on solely for a GPU/PC given that there is no HDCP 2.2 protected content coming from it and there likely won't be any for a while as none of the current content (Amazon, Netflix) streams in 4K/UHD from a PC, mainly for protection reasons. I got mine mainly to be able to connect my upcoming UHD Bluray player to my existing audio/video chain. The main feature of the Club3D adapter is the full speed 18Gb/s HDMI interface. It still makes it a very worthy add-on to current HDMI 1.4 limited GPUs while we wait for Arctic Islands.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 10th December 2015 at 16:31. |
10th December 2015, 16:46 | #34555 | Link |
Hey madshi, is there any plans to create a dedicated MadVR Video Player?
Apologies if it's been asked before (or if it's a stupid question...). MadVR is excellent, though it can be a bit daunting to set up for someone like me with no idea what half the options mean and how they effect quality, performance and power. :-) Having it's own player like MediaPlayer.net with options for low-high end GPU's would actually be quite handy, and eliminate the nuisance of having MadVR as a separate entity to Potplayer/MPC-HC. Last edited by BluesFanUK; 10th December 2015 at 16:59. |
10th December 2015, 18:28 | #34556 | Link | ||
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 10th December 2015 at 18:37. |
10th December 2015, 19:46 | #34557 | Link | |
What should I do to have the TV do the upscale (without my old laptop use any power in case the res of file is the same and not lower; i want madVR for other functions)? I would love a Disable_Upscale/Downscale command because if I must play different files with different resolutions I should always change the values in Display_Modes to be the same of the content I'll play, provided someonw tells me how to see TV in 1080p! |
10th December 2015, 21:16 | #34559 | Link | |
The tier profiles need updating because they don't take into account NNEDI3 or the newest enhancements brought in recently by Madshi, but it's a great way to get started if you find the initial setting intimidating. Use them as a starting point and fine-tune and experiment from there. It's also simple to update madVR if the version included in the latest KCP installer gets a bit old, you just drop the MadVR files into the KCP/MadVR folder and it's up-to-date. Same goes for LAV or MPC-BE. As long as you save your settings beforehand and restore them afterwards (another nice thing about KCP), you'll be fine. Here is the normal link: http://haruhichan.com/forum/showthre...aii-Codec-Pack However a newer 1.0.8 build was posted recently and the link hasn't been updated in the front page. You'll find it here: http://haruhichan.com/forum/showthre...c-Pack/page296 Another option is to go for jRiver Red October which includes MadVR, but that's not free.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 10th December 2015 at 21:22. |
10th December 2015, 23:56 | #34560 | Link |
Zoom Player will also download new versions of madVR, install, and configure it. Zoom Player does not default to using madVR but it is easy to set.
madVR options explained |
