Old 7th December 2019, 16:44   #17961  |  Link
GZZ
Originally Posted by Pauly Dunne View Post
So I would imagine that most of you have a reasonable collection of both unprocessed and processed movies & series, etc, which can add up to a LOT of Terabytes.
I would be interested to know what some of you (who are happy to oblige) have & use for storage, of said data ???
I have several reasonable capacity Supermicro storage servers, and a couple of Unraid "box's", but unfortunately, every so often there is a problem, and as a result, I get data corruption.
I don't really have too much backed up, so sometimes it's a complete loss , which can be very frustrating, especially if it was irreplaceable.
Anyway, I'm just curious...
Should be in another thread or properly another group, try search forum as its out off topic for this thread.
GZZ is offline   Reply With Quote
Old 7th December 2019, 17:34   #17962  |  Link
tkwou
Originally Posted by tkwou View Post
Hi Atak, I recently updated to v1.25.0. I just tried encoding the movie Life in DE mode and it failed with about 8 minutes left in the movie. When I look at the Chunks folder there are no *.264 files for the last 8 chunks. When I try to run each .cmd file manually I get these errors.
y4m[error]: bad sequence header magic
x2464[error]: could not open input file `_'
If I rerun the .cmd files for any of the completed chunks I get the normal .264 output. I don't understand what's going on. Should I just try recoding again from scratch?
Hi Atak, strange this just happened again. Processing stopped with just 2 chunks to go. With the missing chunks, the CombineChunk.cmd fails and video.264 is missing for the mux. I restarted the encode and again it finished the final 2 chunks and everything completed fine.
tkwou is offline   Reply With Quote
Old 7th December 2019, 18:31   #17963  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
You have some network issues or some instability in RAM/CPU...
Old 7th December 2019, 18:57   #17964  |  Link
Ryushin
With latest version of lsmash I recommend to use it for ALL formats! Just forget about ffms. Lsmash is superior in almost every aspect.
So the random frames happening around the end of the DE chunks should be fixed? Works for VC-1 too?
Ryushin is offline   Reply With Quote
Old 7th December 2019, 20:17   #17965  |  Link
Atak_Snajpera
yes...
Old 8th December 2019, 01:43   #17966  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
OMG, GZZ !!!
I knew that I was off topic for this thread, but I thought I'd just ask the question of the member's on THIS thread, as they MUST have some form of reliable storage.
So why you reply to state the bleeding obvious is a waste of your time, when for the same effort you could have said something like ....I have a Synology or Unraid backup....
Not poorly done, just doin' it my way !!!
Pauly Dunne is offline   Reply With Quote
Old 8th December 2019, 07:05   #17967  |  Link
Pauly Dunne
Grumpy Old Man.
Att:- Atak (MDegrain custom filter testing)
Is there a way to confirm that these "Custom" MDegrain filters are / or have been used ??
Other than creating some short test encodes and comparing the fps, kbps (whilst processing), or time taken to encode & final file size ??
Anyway, I did that, and here's some interesting results:-
a test tv episode, mp4, 17 minutes long.
MDegrain1 took 8:34m
MDegrain2 took 11:43m
MDegrain3 took 15:18m
they are ALL with MT enabled.
Then I ran MDegrain1 test again changing the MT settings.
with no MT, it took a "massive" 28:25m.
with MT enable, but using 16 threads took the original 8:34m
with 8 threads it took 8:17m
with 0 (which must be unlimited) it took 8:08m (on my 24 thread pc)
so going on that all the above times would be a touch faster if I had of had it set on 0 threads.
As for file size change:-
original file is 255,856kb @ 1,923kb/s
MD1 encoded is 303,196kb @ 2,192kb/s
MD2 encoded is 289,490kb @ 2,126kb/s
MD3 encoded is 281,275kb @ 2,126kb/s
No other filters or changes where made, using CRF 20, and ONLY the custom MDegrain filters.
Old 8th December 2019, 13:26   #17968  |  Link
Atak_Snajpera
Zero means number of physical cores If I remember correctly. So If your CPU is 12c/24t then value will be 12.
Regarding file size. You should try with noisy source. Difference will be much higher. MD2 should give you up to 1.8x bitrate reduction.
Old 8th December 2019, 13:57   #17969  |  Link
Pauly Dunne
Grumpy Old Man.
So does "0" automatically determine how many cores/threads are available ??
As "0" is the fastest of the settings I tried.
Also, I DID do a test on much noisier source (The Fifth Element), and there was a bigger file size/bitrate difference between the three.
Old 9th December 2019, 04:26   #17970  |  Link
Pauly Dunne
Grumpy Old Man.
Random errors, several times during 1 job..
Me again,
I thought I'd run a few job thru RB today, on a pc that I was using successfully just last week, and I just keep getting errors, several time during the same job.
Cannot find file F:\Temp\RipBot264temp\job10\video.264
Error importing F:\Temp\RipBot264temp\job10\video.264:name=The Report 2019: Requested URL is not valid or cannot be found
It got thru approx 12 chunks before the 1st error, then after restarting the job, it got thru to chunk 24, then the next time I think it got thru quite a bit further, and errored again.
After several more attempts with different jobs, restarting the pc, I gave up, and went and did some cooking.
Old 9th December 2019, 15:19   #17971  |  Link
Atak_Snajpera
Auto-update 2019.12.09
Added: EncodingClient combines chunks with output file on fly as soon as they are encoded in correct order
Added: Audio profiles in Profile\Audio.txt
Changed: Jobless servers will be suspended only if ETA>60s (reason: reduce unnecessary suspend -> resume cycles)
Fixed: Excessive flickering of encoding status in EncodingClient
Fixed: EncodingClient didn't resume suspended jobless servers before starting second pass.
Fixed: EncodingServer didn't go to suspend mode again after previous resume
Old 9th December 2019, 16:03   #17972  |  Link
ReinerSchweinlin
Thanks for the update log. This is very helpful, please continue posting when updates are done
Old 9th December 2019, 16:54   #17973  |  Link
byteshare
ByteShare
byteshare's Avatar
https://www.reddit.com/r/DataHoarder/
I use 1 to 1 backups
Won't give you the benefits of a test encode (seeing the actual file results) but you can check:
(on a job) edit > AviSynth > Show Video Script > Look under the custom section that you see your script, then...
> Preview (first to make sure there are no errors in your script.
If no errors and your script is being loaded > AVS Meter to see the speed and such it runs at.
If you're still skeptical that your script isn't being used because of a mistake in your code that you're not seeing try removing it and then running the AVS Meter again, if there is no difference in speed (FPS) then something could be wrong with your script and then you'd want to run a test encode to see if there are any filesize differences, if none then it is likely your script or you're using a filter that is not having an impact either by design or by an error in your script.
(tip, on your script be sure "video" is somewhere after the "=" otherwise it isn't being using in the final video sent to the HEVC encoder, otherwise it is fine if you're using it for a mask, prefilter, etc...
Besides MD1-3 (there are higher ones as well) you can try adjusting the strength as well (thSAD, higher values mean more removal of grain/noise but too high removes noticeable details). Can also try after MD a filter like FineDehalo/HQDeringmod (there are a lot of choices in this area) to remove some created/leftover temporal noise (mosquitoes) depending on your source and filter results.
Old 10th December 2019, 03:45   #17974  |  Link
Pauly Dunne
Grumpy Old Man.
Thanks very much for that, will be a lot easier on the eyes
And how do you use the "audio.txt" ?
Just need to add that I updated a client & 1 server with the latest, and it was running well, it had done 2 3/4 jobs, and Encoding Client just stopped all processing, both Client & Server...had to force RB shutdown with Processhacker, started again, and away it went.
edit addition:-since that error, I have had no more problems, maybe it just needed to "warm up"
I do have a question about the function of the Encoding Client "button" on the very right of the 4 buttons...
Not sure what you've named it, but I did a little fiddling, and noticed that if that button is enabled, as soon as the processing chunk is complete, that server/port goes idle....and if thats the only chunk on a particular server, it would then shut that server down....so my question is why, if there are more chunks for that server to process.
All that comes to my old mind is that if you had a very long queue and you wanted to stop it part way thru, you'd enable that button. Then eventually all the servers would turn themselves off, and you'd only be left with the client.
I actually thought that that button would do similar to the suspend option, BUT turn them off !!
I really like the suspend option, that's great, and seems to work well for me.
Old 10th December 2019, 03:51   #17975  |  Link
Pauly Dunne
Grumpy Old Man.
Thanks for the great reply
I did do a run on the first few minutes of The Fifth Element (which is VERY noisey), and I was pretty happy the MD3 results (thSAD=800).
I do have slightly different thSAD numbers for MD1 & MD2.
I might go back to a much older version of RB, and see what the HQDN3D settings were, and maybe create a custom filter for non 10bit encodes.
Old 10th December 2019, 12:03   #17976  |  Link
Ryushin
Do you have a copy of those custom scripts for FineDehalo/HQDeringmod. Originally that is what I was using mdegrain2+hqdn3d. If it does a good job I'm hoping Atak will add those as additional features.
Old 10th December 2019, 14:57   #17977  |  Link
Ryushin
Sorted Order Reverts on Closing
Just updated and I noticed something, which I'm not sure is related to the last update or not. If I open RipBot264, change the order of the encodes, close RipBot264 and open it again, the order goes back to what it was before I changed the order.
Old 10th December 2019, 15:15   #17978  |  Link
Atak_Snajpera
= SUSPEND JOBLESS SERVER (All chunks have been already assigned to other servers)
= SHUTDOWN SERVER AT IDLE STATE (Finish encoding current chunk and then shutdown)
Old 10th December 2019, 18:26   #17979  |  Link
byteshare
ByteShare
byteshare's Avatar
I usually use SMDegrain rather than straight MDegrain. I don't like HQDN3D on its own. I'd rather use KNLMeansCL with GPU, which is actually the prefilter I use with SMDegrain.
For FineDehalo I either use the default: FineDehalo() or something like:
"FineDehalo(rx=2.0,ry=2.0,thmi=80,thma=128,thlimi=50,thlima=100,darkstr=1.0,brightstr=1.0,showmask=0,contra=0.0,excl=true)"
There are some safer settings if you're using anime/cartoons.
For HQDeringmod I also use the defaults "HQDeringmod()" or something like: "HQDeringmod(nrmode=2,Y=3,U=3,V=3,lsb=False,thr=255.0,darkthr=255.0)"
For those filters and others it depends on the source and what you want.
I'd stay away from thSAD values of 800 and higher for MDegrain, as it can soften the image under closer inspection. SMDegrain values of thSAD are a little different because it combines more filters.
Old 11th December 2019, 01:01   #17980  |  Link
Pauly Dunne
Grumpy Old Man.
Thankyou for that, I thought that put that particular server to "sleep" after the encoding was completed, then once the next job queue was starting, they would wake up, and start encoding
However, I really can't see that is all that necessary until towards the very end of the chunk queue, and you want individual servers to turn off.
The only reason I can see for it's use is if you have a LONG queue, and you want to stop it part way thru (for what ever reason).
I think one nice function would be to have a similar option for the client, but when the chunk that was processing completed, it didn't start the next one.
Used in conjunction with you could completely (automatically) pause or stop an encode, without doing it manually.
Anyway, enough of that, it's all a little bit over my head, but I know what works for me.
Could you please explain the use of the new "audio.txt" ?
