3rd March 2013, 22:21 | #2041 | Link |
I don't understand. From everything I've read in regards to this, if you're writing spec-compliant files, then 720x480 NTSC files should be downsized to 640x480 since 480 must stay 480. Personally I hate that, but it is what it is and I'm trying to understand how 720x480 taken up to 720x540 is spec-compliant? I agree that even the players that do an outstanding job of playing BDs seem to not have it exactly right when playing back SD media files.
Chumbo |
3rd March 2013, 22:24 | #2042 | Link |
MKVToolNix author
The Matroska specs is what I meant. And they do not make any rules about how display width/height should be calculated for video of size X with pixel aspect ratio Y.
If I'm producing a DVD then I have to follow the DVD specs. Same for Blu-rays. But if I'm creating a Matroska file then I don't care about Blu-ray or DVD specs or NTSC specs. End of discussion for me.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
4th March 2013, 08:55 | #2045 | Link |
MKVToolNix author
Where is that piece of information stored?
4th March 2013, 09:00 | #2047 | Link |
MKVToolNix author
Then the answer would be "no".
4th March 2013, 09:05 | #2048 | Link |
Acid fr0g
When I finish a x264 encoding, I put in the same directory v.mkv (the output video), ita.ac3 (my language), eng.ac3 (or any other original language), ita.srt and eng.srt.
With the latest pre version in windows and not with 6.0, whenever I drop v.mkv and then ita.ac3, mmg adds v.mkv again. If, at this point, I delete v.mkv and drop eng.ac3, mmg adds v.mkv twice! Anyone with my same problem?
@turment on Telegram |
4th March 2013, 09:09 | #2050 | Link |
MKVToolNix author
Oh yikes I know exactly what the problem is... Thanks for reporting; will be fixed in the next pre-build that's currently compiling.
4th March 2013, 09:56 | #2051 | Link |
MKVToolNix author
4th March 2013, 14:49 | #2053 | Link | |
This means, forced subtitles can be detected. Imho, Mkvmerge should auto-flag them as forced subtitle "YES". |
4th March 2013, 14:51 | #2054 | Link |
MKVToolNix author
Let me repeat: where is that information stored? I mean where exactly? "Others can do it" and "mkvmerge should do it" don't help me.
4th March 2013, 15:05 | #2056 | Link | |
But Blu-Ray players go through the menu system first. These tell the player which (if any) subtitle track it should select and if it should play all or only forced lines. Bottom line: Blu-Ray and DVD only work with forced lines which may or may not (separate track) be used by the authoring house. Matroska uses forced tracks instead of lines, so that's a different concept, meaning you cannot simply transfer these informations. Last edited by sneaker_ger; 4th March 2013 at 15:09. |
4th March 2013, 15:38 | #2057 | Link |
Thats one of the main reasons i demux with eac3to, which notifies me if a stream contains forced lines, and also lets me look into the demuxed PGS streams with BDSup2Sub to identify the other streams, and make a decision which streams i want.
There isn't really a good automated way to solve all the troubles of BD forced subs. The only think mkvmerge potentially could do is allow splitting forced lines into another track, like most of the other tools support, but imho its not something i would use, because it only solves a small part of the problem.
4th March 2013, 18:36 | #2058 | Link | |
Thanks to sneaker_ger we now have the answer: the forced lines are marked as forced within the subtitle track.
If a track contains forced lines and normal lines:
This would also solve the problem of the 2 different kinds of tracks (the tracks that support both forced and normal lines in the same track, and the separate tracks that contain only forced lines). In both cases, the above procedure would work (i.ex: if a track contains only forced lines and no normal lines, then the track with the normal lines would not be created). |
4th March 2013, 18:40 | #2059 | Link |
MKVToolNix author
Sorry, but that is not going to happen. Mkvmerge would have to know in advance whether or not a track contains forced entries in order to write the file headers correctly. That could only be achieved by implementing two-pass muxing, something that I will most certainly never do. Way too much effort.
4th March 2013, 23:02 | #2060 | Link | |
