Old 16th January 2019, 21:20   #2101  |  Link
FLX90
I‘m currently 2-pass transcoding a BluRay and it takes about 26 hours on my 5th gen. i7.
CPU load: 100 %
Is it bad for the transcode if I do some web surfing during the process.
Sometimes my browser freezes for less than a second ...
Would that harm my transcodes?
FLX90 is offline   Reply With Quote
Old 16th January 2019, 21:39   #2102  |  Link
Groucho2004
No.
If you are planning to use your computer while encoding you should even lower the priority of the process to low/idle. This way your browsing (or whatever else you're doing) will not 'freeze' and the encoder only gets the CPU cycles that are available. Of course that only works when you have sufficient memory installed.
Groucho's Avisynth Stuff
Old 16th January 2019, 21:52   #2103  |  Link
FLX90
Sounds great.
Thank you for your answer.
I asked because more than 10 years ago, I transcoded my then library with iTunes to mp3. I was gaming and doing other CPU intense things during the transcoding process.
After that, I noticed for 10 % of my 10,000 mp3s an audible click noise for less than a millisecond.
Thought that was because of the high CPU load.
Old 16th January 2019, 22:15   #2104  |  Link
Groucho2004
No idea, should not happen. Does itunes by any chance use the GPU for transcoding?
Old 17th January 2019, 07:15   #2105  |  Link
FLX90
I really don’t know ...
Old 17th January 2019, 08:23   #2106  |  Link
LigH
LigH's Avatar
I would rather suspect misinterpreted ID3 tags as source of distortions.
Back to x264?
New German Gleitz board
Old 17th January 2019, 08:45   #2107  |  Link
FLX90
Yes, that could possibly be.
Thanks for clarification.
Old 21st January 2019, 14:23   #2108  |  Link
sneaker_ger
qcomp 0.8 is part of --tune grain so it's not anything insane. We usually don't recommend users to fiddle with those parameters because they don't really understand them and are better off simply using preset+tune than choosing "wrong" values.
Originally Posted by AVspace View Post
From what i understand of the lower values it distributes more bitrate to more visible areas and uses less bitrate in lower visible areas but when i did some video comparison the lower qcomp appears to take freely from a bunch of areas like parts of the fingers or hair or background were missing, i guess the bitrate for those areas are put elsewhere? I could see the benefit of this in constant rate factor maybe but it doesn't seem to be as needed in two-pass.
Yes, it's about redistributing bits. With higher qcomp the redistribution is less aggressive. This redistribution affects 2pass and crf in the same way.
Old 21st January 2019, 19:47   #2109  |  Link
benwaggoner
There definitely were not GPU accelerated MP3 encoders in iTunes >10 years ago!
Ben Waggoner
My Compression Book
Old 21st January 2019, 19:49   #2110  |  Link
benwaggoner
Yeah, finding a better value for a particular type or piece of content is possible. But finding a significantly better generic default value is highly unlikely.
Ben Waggoner
My Compression Book
Old 22nd January 2019, 10:58   #2111  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Maybe interesting:
https://forum.doom9.org/showthread.php?t=175723
Never mind, I typed into the wrong thread here, too many windows open...
Old 9th February 2019, 22:14   #2112  |  Link
dev84
Why there is no official binary r2935 10bits ?
dev84 is offline   Reply With Quote
Old 9th February 2019, 22:27   #2113  |  Link
sneaker_ger
8 bit and 10 bit are now combined into a single binary. Use --output-depth 10
Old 9th February 2019, 22:41   #2114  |  Link
dev84
i'm using StaxRIP 1.7 but it doesn't work with "--output-bitdepth 10" i get "failed with exit code: -1 (0xFFFFFFFF)"
Old 9th February 2019, 23:06   #2115  |  Link
sneaker_ger
Sorry, --output-depth, not --output-bitdepth
Old 10th February 2019, 00:05   #2116  |  Link
dev84
Thanks
Old 10th February 2019, 13:24   #2117  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Oh, just like x265. Nice.
Old 15th February 2019, 02:40   #2118  |  Link
utack
Does anyone have inisight on how x264 uses NEON instruction sets?
I just upgraded from a mobile device with 8x symmetric Cortex A53 to 4xA53 slower +4xA72 faster that has more or less the same multicore performance for a majority of tasks
However I noticed that x264 has had more than a 2x speedup on this device
Does Cortex A72 come with some special vector magic it uses?
utack is offline   Reply With Quote
Old 19th February 2019, 22:09   #2119  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
IIRC there is a lot of hand tune NEON assembly in x264
Old 6th March 2019, 19:32   #2120  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I've been experimenting with going back to x264 for some of my BD re-encodes where the source is rather soft or noisy/grainy. I'm having a hard time figuring out when one would need to tweak psy-trellis. I understand that psy-rd is mainly responsible for keeping the grain, or at least fooling the viewing into believing that there is detail there, but I don't know what psy-trellis adjusts. Can anyone explain any use cases?
coding, development, x264 dev
