13th April 2015, 19:50 | #28901 | Link |
@madshi
same as tobindac on (un)install.bat. It does not work as intended without the manual "run as admin". Win 8.1 with the latest updates. EDIT: it shows that madvr was (un)registered but that doesn't seem to be the case when I look at the Output Renderer Settings on both mpc-hc & potplayer.
Windows 10 64-bit PowerColor HD R9 270 Last edited by ikakun; 13th April 2015 at 20:28. Reason: Adding something |
13th April 2015, 20:21 | #28902 | Link | |
God bless you madshi and may you prosper doing the things you love.
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410. |
13th April 2015, 21:26 | #28904 | Link | |
http://forum.doom9.org/showthread.php?t=171323 |
13th April 2015, 21:27 | #28905 | Link | |
13th April 2015, 22:03 | #28908 | Link | |
Voting to not have it enabled by default. x64 playback chain seems to be stable now, many thanks!
AMD Phenom II X4 970BE | 12GB DDR3 | nVidia 260GTX | Arch Linux / Windows 10 x64 Pro (w/ calling home shut up) |
13th April 2015, 22:07 | #28909 | Link | |
http://bugs.madshi.net/view.php?id=90 that's why i asked for the OS. |
13th April 2015, 22:11 | #28910 | Link | |
is the issue something like this? http://forum.doom9.org/showpost.php?...ostcount=28783 if yes check here: http://forum.doom9.org/showpost.php?...ostcount=28810 |
13th April 2015, 23:19 | #28913 | Link | |
cosmic entity
@ huhn.. THX for the info..
.---------------------------- Quote:
Yay... i just tested needi3 with the new NV Drivers, and ITS FIXED Finally i can use Needi3 without artefacts.. oh, and HUGE THX to madshi for teh 64bit version of MadVR. i can confirm from first testing that theres an performance increase my gpu now needs less power to do more work, awesome.. |
13th April 2015, 23:57 | #28914 | Link | |
EDIT: driver is most likely still buggy.
good that my prediction for this driver are totally wrong. respect nvidia that was pretty fast. i hope cyberbeing is going to see the same effect with that driver. Last edited by huhn; 14th April 2015 at 02:14. |
14th April 2015, 01:14 | #28915 | Link |
Posts: n/a
Now that madVR supports 64bit, does it mean we can use MPC-HC 64bit with it? Are there any advantages over 32bit version?
The problem with 64bit is that ReClock won't work with it... Are there any alternatives to ReClock that work with 64bit MPC-HC? I know JRiver Media Center has its own "ReClock" feature and works in 64bit, but I dislike the actual player because its too cumbersome... I also keeping having the same issue over and over and over again... FullScreen Exclusive Mode continues to cause me to drop frames. When I turn it off, no frames are dropped. Is it something with madVR or my setup? |
14th April 2015, 01:23 | #28916 | Link | ||
Troubleshooter
Edit: madVR v0.87.21 (like .20) works fine for me in fullscreen windowed mode. Quote:
I tested with FullScreen Exclusive Mode just now (again with the all 64-bit configuration), and didn't get any dropped frames on my system. Are your fullscreen exclusive and windowed settings differing in present frames in advance settings or flush settings in madVR, or are they both set identical?
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. Last edited by Anime Viewer; 14th April 2015 at 01:41. Reason: added 87.21 update, added reply to XMonarchY |
14th April 2015, 01:33 | #28917 | Link |
@XMonarchY
64 bit has better decoding performance. so it can matter a lot for software decoding. in term of madVR performance there shouldn't be any real differences. and about your issue we need way more information that just "if i got in FSE mode i get dropped frames" resolution? what settings what are the renderer times, FPS, and way more questions. |
14th April 2015, 01:36 | #28918 | Link |
can someone with a nvidia kampler GPU try to reproduce this issue: http://bugs.madshi.net/view.php?id=250
the openCL issue discussed later in this issue. edit: not important anymore. Last edited by huhn; 14th April 2015 at 02:16. |
14th April 2015, 02:06 | #28920 | Link | |
