19th February 2009, 11:01 | #41 | Link |
I've updated AVCHDMe to match the AVCHDMe routine from AVCHDManager which is bascally a lot more stable, I've updated the link on the first page. Now that TSMuxer development seems to have started up again, I hope to be able to remove all the .clpi fixing stuff from it and get it back to a basic file renamer but for now, the clpi fixes remain.
2nd March 2009, 18:16 | #43 | Link |
Sure, I've updated the first post with a new link.
On a side note, I recommend anyone who still uses this for doing AVCHDs on a FAT32 hard disk to move over to AVCHDManager which includes all the functionality of AVCHDme and more. Last edited by idbirch2; 2nd March 2009 at 18:27. |
4th March 2009, 03:49 | #44 | Link |
Well you be updating to fixclpi v231 soon? Thanks
Also I noticed if you select your BDMV folder but choose not to process it, AVCHDMe leaves a fixclpi.exe in the CLIPINF folder after you close it. Last edited by DMagic1; 4th March 2009 at 03:52. |
7th March 2009, 18:21 | #47 | Link | |
I'm not trying to derail this, but are you saying there is a fix for the pause @ 4G, or just saying it is a different issue? If there is a fix, could you point me in the correct direction? (I have searched for it, but haven't found one yet). Thanks |
7th March 2009, 18:31 | #48 | Link | |
Location: The Great North (the better half of North America)
So, AVCHDMe will (does) fix the 4GB pause issue. |
17th March 2009, 17:58 | #51 | Link |
I've updated this to 2.0 which should be the last update required as TSMuxer has been updated to address all of the previous CLPI issues. The GUI has been simplified and I've added a button to undo the file renaming.
Other changes include: --4GB max file size check --Path input box now accepts drag and drop --CLPI verification If any problems are found, just click "Fix It" and the problem will either be corrected or you will be told what you need to do. New download link and screenshot in the first post. |
