8th March 2014, 02:49 | #17261 | Link |
So I've installed 0.61.1, noticed that watching avisynth scripts works terrible with lav-potplayer-madvr, installed 0.60 and can't open .avs anymore??
Installing ffdshow and ticking avisynth and raw video does nothing. Ok, back to 0.61.1, installed with installer: With 0.61.1-potplayer-madvr i have to wait 5 seconds for video to start after every unpause. But it's fine with mpc-hc and madvr or in potplayer with evr-cp. Now, it's kinda hard to see what's the problem is out of madvr/lav/potplayer, as I updated them all at once and can't revert to previous lav version, but: When I use mpc-hc there's a lav video decoder in filter list (lav splitter-lav video-madvr), but in potplayer it's just splitter and madvr (and yes it plays video). After i switch to evr-cp lav video appears and 'delay after resume' is gone. after i switch back to madvr lav video stays and 'delay after resume' is still gone. If i force lav video to 'preferred' in potplayer, it loads lav video and there's no 'delay after resume'. Also, potplayer uses async source+lav splitter for avs unless I force lav splitter source, although it's configured to use lav splitter source for everything. Don't know what to make out of all this really but I hope there's a resolution. |
8th March 2014, 08:49 | #17263 | Link |
Sounds like you enabled madVR's decoders. If LAV Video isn't even used, and even more, the issue goes away when its used, its definitely not a LAV issue.
8th March 2014, 17:02 | #17264 | Link |
I want to ask a little more technical question about HW de-interlacing and LAV Video options.
There is an option of HW de-interlacing activated only using QuickSync or NVCUVID, called Adaptive HW deinterlacing. Is the algorithm used by this option, different/ better than the default HW algorithms selected automatically by EVR/ EVR-CP when using DXVAn for Nvidia and Intel HW decoders ? The comparison should be CUVID vs DXVAn for Nvidia regarding HW deinterlacing algorithms and QS vs DXVAn for Intel. Not Nvidia vs Intel.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
8th March 2014, 17:05 | #17265 | Link |
Its the same deinterlacing algorithm, just performed by the decoder immediately after decoding instead of the renderer later - but otherwise exactly the same GPU deinterlacing.
Both the CUVID library and Eric's QuickSync Decoder offer a simple option to turn it on, so it was trivial to add it - and it can be useful if you want to do post-processing on the image, or for transcoding. In theory it could also be implemented for DXVA2-CB, but its quite a lot of effort and IMHO not generally worth it. For DXVA2-Native it doesn't make any sense, since you cannot use it for post-processing or transcoding anyway, and the renderer comes immediately after the decoder.
8th March 2014, 17:12 | #17266 | Link |
Thanks
8th March 2014, 19:49 | #17267 | Link | |
Δ
I have no problem in PotPlayer since I can select HW/SW de-interlacing method there. And I don't use LAV with PotPlayer. I want to have software de-interlacing with LAV+MPC-HC |
8th March 2014, 19:54 | #17268 | Link |
If you want SW de-interlacing you have to forget HW decoding too.
You have to use SW decoding for SW deinterlacing. So, put in hardware decoder option "None" and then Enable YADIF. You will have SW decoding and SW deinterlacing, although I really don't understand why you want SW deinterlacing. All of my clips tested with HW deinterlacing look better than YADIF for all three HW decoders (Intel, Nvidia, AMD)
8th March 2014, 20:11 | #17270 | Link |
So if you select DXVA-CB or QS for Intel and NVCUVID for Nvidia you can have SW de-interlacing ?
I'll try it. I always use DXVAn for HW decoding. UPDATE: Yes, SW deinterlacing works for both DXVA-CB and QS.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all Last edited by NikosD; 8th March 2014 at 20:21. |
8th March 2014, 20:12 | #17271 | Link | |
Also, if you have a really crap GPU then using software deinterlacing can take offload some of the burden to the CPU. I agree that hardware deinterlacing is generally better though.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
8th March 2014, 20:23 | #17272 | Link |
Δ
Ok, just found the issue and it's because of playing a 1080i H.264 4:2:2 video.
LAV makes MPC-HC to encode via CPU (correct) but de-interlace via GPU! And nothing lets me to change HW de-interlacing to SW/QS de-interlacing for that file. Last edited by P.J; 8th March 2014 at 20:25. |
8th March 2014, 20:25 | #17273 | Link |
I'll check my 7 year old Radeon 3650 (UVD+) card against SW de-interlacing on some difficult H.264 and VC-1 interlaced clips and I'll tell you.
8th March 2014, 20:29 | #17274 | Link |
Are you sure you enabled YADIF Software Deinterlacing in LAV Video? It supports deinterlacing 4:2:2 too.
8th March 2014, 20:34 | #17276 | Link |
QS/CUDA only works if the hardware decoder for those is used as well, which is not compatible with 4:2:2 in general.
How do you know its not working? I just tested such a file, and it deinterlaces fine. Note that it only deinterlaces 8-bit, if you are using 10-bit 4:2:2 videos, you're out of luck.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 8th March 2014 at 20:39. |
8th March 2014, 20:47 | #17277 | Link | |
Δ
Any chance to add SW Motion/Vector adaptive instead of YADIF? Last edited by P.J; 8th March 2014 at 20:49. |
8th March 2014, 20:49 | #17278 | Link |
In theory YADIF supports those, maybe I can hook that up for a future version.
But for now, no deal.
8th March 2014, 20:51 | #17280 | Link |
If you provide a patch to do so, sure.
If you want better quality deinterlacing, let your GPU do it.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 8th March 2014 at 20:56. |
