Old 17th November 2011, 18:18   #7061  |  Link
iSeries
Thanks - I just tried to register the splitter from the debug build and I got an error saying "The module "LAVSplitter.ax failed to load"?
I had used EasyBD to mux them - I've emailed their support about it but they are adamant that it is not an EasyBD issue. Indeed, all muxes made with EasyBD have played in my three standalone players perfectly.
iSeries is offline   Reply With Quote
Old 17th November 2011, 18:23   #7062  |  Link
nevcairiel
Ah, my bad, use this instead:
http://files.1f0.de/lavf/LAVFilters-...605-debug2.zip
Old 17th November 2011, 18:33   #7063  |  Link
iSeries
Thanks Nev, here are the logs:
http://www.mediafire.com/?aue6muh3dba97t3
http://www.mediafire.com/?yssyx1p2ckvzkvb
Old 17th November 2011, 18:54   #7064  |  Link
nevcairiel
In the LAV Splitter options, uncheck "Try to fix broken HD-PVR recordings" and see if that then breaks the m2ts playback?
That seems to be the only big difference between m2ts playback or Blu-ray playback.
Old 17th November 2011, 20:21   #7065  |  Link
VipZ
Nev, I read that you are looking to support DVD decoding and possibly putting the subs directly on the image. Hope this is part of the work you talking about that's wont be available for awhile
I assume LAV Video would need to deinterlace the video 1st for this, or not needed?
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1)
VipZ is offline   Reply With Quote
Old 17th November 2011, 20:22   #7066  |  Link
nevcairiel
Actually, i'm not sure. Since the subtitles don't move, i think it might be OK'ish.
For the future, i'm exploring ideas to send them to the renderer for painting onto the image after all its processing.
Old 17th November 2011, 20:29   #7067  |  Link
VipZ
Yep, when I 1st thought about it I assumed it would be required, but as you say, they don't move so it may work. Also would doing such a thing mess the interlaced flags on the video stream?
I do prefer the rendering of subs to the renderer myself.
Old 17th November 2011, 21:17   #7068  |  Link
joe42
Without looking at the file, i guess its interlaced, and thus not supported.
Edit:
After looking at the file, i'm sure its interlaced.
Use the MS decoder.
I found that madVR's video decoder works well if you include the Intel decoder DLL. It seems that madVR is smart enough to use the libav decoder for non-interlaced VC-1, and to automatically use the Intel decoder for interlaced VC-1.
I guess that is an advantage to the way madVR integrates its decoder? Or is it possible for LAV video decoder to do something similar?
joe42 is offline   Reply With Quote
Old 17th November 2011, 21:18   #7069  |  Link
nevcairiel
I don't understand why you don't just simply use the Microsoft decoder? Its faster and decodes every VC-1 stream available.
Old 17th November 2011, 21:29   #7070  |  Link
jmonier
My experience with the Microsoft decoder is that it uses a lot more CPU time for VC-1 interlaced than non-interlaced. Since it's apparently not multi-threaded, that means that one processor can get close to the practical limit.
One VC-1 interlaced file that I have won't run smoothly on anything less than than an i7-960 using the Microsoft decoder.
jmonier is offline   Reply With Quote
Old 17th November 2011, 21:32   #7071  |  Link
nevcairiel
The libav or Intel decoders aren't any better.
libav is not multi-threaded, and of course fails on interlaced completely. The Intel decoder seems generally to be pretty slow.
Old 17th November 2011, 21:45   #7072  |  Link
iSeries
Hi Nev,
I'm out at the moment but will do as soon as I'm home. So if I uncheck that and m2ts playback then also becomes bad does that mean a muxing issue?
Old 17th November 2011, 21:46   #7073  |  Link
nevcairiel
Yes, but it also means i can fix it.
It would probably help if you can cut a small sample off the m2ts and upload it to mediafire or similar (~20mb would be good). Use something like DGSplit, not a special mpegts splitter.
Old 17th November 2011, 21:51   #7074  |  Link
iSeries
Hmmm the EasyBD guys were adamant to the point of dismissive that this is not an EasyBD muxing issue. Although if it was wouldn't playback also be choppy in a standalone player?
Glad that you can fix it though - although a bit annoyed that the software that I've paid for is at fault. Looks like I'll be going back to tsMuxer
Will certainly provide a small sample for you.
Old 17th November 2011, 21:54   #7075  |  Link
joe42
I guess I like to minimize the number of external filters in my list. I don't have a good reason I can explain for my preference. But madVR appears to do what I wanted, so why do you think I should use the Microsoft decoder? Is it better than madVR's combo of libav for VC-1(p) and Intel for VC-1(i)?
And just to verify, by "Microsoft decoder", do you mean "WMVideo Decoder DMO"?
Old 17th November 2011, 21:55   #7076  |  Link
nevcairiel
Thats the right filter, and yes, the MS decoder is better then those two.
Old 17th November 2011, 21:57   #7077  |  Link
nevcairiel
Cut the sample off the start of the file, and if you can, also upload the Blu-ray metadata with it, the two bdmv files, the playlists and clipinfo files, so that i can directly see the difference.
Old 17th November 2011, 22:04   #7078  |  Link
iSeries
Ok no problem with the bdmv files etc, although how do I provide the metadata?
Thanks again!
Old 17th November 2011, 22:06   #7079  |  Link
nevcairiel
Ok no problem - how do I provide the metadata?
Thanks again.
Just zip up following files/directorys:
BDMV\index.bdmv
BDMV\MovieObject.bdmv
BDMV\PLAYLIST
BDMV\CLIPINF
Add to that some 20mb of sample from the m2ts, and it should be good.
Old 17th November 2011, 22:16   #7080  |  Link
Matching_Mole
For VC-1 encoded blu-ray I use Arcsoft one because it is multithreaded and works perfectly on interlaced VC-1 file, so it is far better than these ones. Its (big) issue is it do not recognize other aspect ratio that the blu-ray one. But personally I don't care because I don't have other VC-1 file that the Blu-ray ones and so I'm happy with it.
I know that "reverse engineering" to use ASVC1Vid.dll is far too big but use it in LAV Video Filter as LAV Audio Filter do with dtsdecoderdll.dll would be the better situation possible... We can just hope that someday libav VC-1 decoder will be "finished".
Matching_Mole is offline   Reply With Quote
