25th February 2012, 18:19 | #14661 | Link |
The target settings won't disappear -- they will just be ignored/overridden during the encode.
I just tested it. I think I see the source of the confusion. The text saying "Performing CRF prediction" is still showing in the log. That is incorrect. It is actually encoding the orignal at that point. I'll correct that for the next release. Last edited by jdobbs; 25th February 2012 at 18:26. |
25th February 2012, 22:21 | #14665 | Link |
I've noticed on the x264 command line BDR uses for 480i 16:9 SD 720x480 sources:
--sar 40:33 but that sar setting is apparently for a 704x480 resolution. I believe the correct sar settings for 720x480 resolution titles are: sar 32:27 for 16:9 720x480 sar 8:9 for 4:3 720x480 The current sar settings may cause a slight error in displayed aspect ratio, for a 16:9 720x480 SD title of 1.82 instead of 1.78(16:9) Last edited by NightHawkGuy; 25th February 2012 at 22:24. |
25th February 2012, 23:02 | #14666 | Link |
BD Rebuilder v0.40.08 (beta)
I've updated the first post of this thread with links to a new version of BD-RB (v0.40.08). Changes for this release:
- Made several improvements to the subtitle resizing routines to provide a more accurate representation of the original PGS when resizing video output. - Corrected a bug that could cause subtitle resizing to fail under some rare circumstances. - Added support for subtitle muxing in ALTERNATE output to MKV. This feature is enabled by adding a new hidden option MKV_MUXSUPS=1 to the INI file (see HIDDENOPTS.TXT). Note: This feature muxes .SUP files in Blu-ray format. SUP formatted subtitles are not supported in all MKV players. Please check your MKV player's specifications. - Corrected a problem that could result in audio desynchronization when converting to PAL under certain circumstances. - Added a new hidden option DISABLE_VIDEO_SLEEP. This will prevent video card sleep mode, and may be useful when running jobs overnight while using DGDecNV with some video cards. - Corrected a problem in which subtitles created by TSMUXER from text-type sources failed to be muxed and resized properly into ALTERNATE/DVD output. - Corrected an error in which adjusting for an audio delay would cause ALTERNATE/MKV multiplexing to fail and BD-RB to abort. - Corrected a reporting error in which "Performing CRF prediction" is displayed in the log even when a fixed CRF is being applied (and not prediction is actually performed). - Updated the included version of MKVMERGE.EXE to the latest release (v5.3.0.0). - Other minor corrections and cosmetic fixes. |
25th February 2012, 23:08 | #14667 | Link | |
Also see this link. Last edited by jdobbs; 25th February 2012 at 23:30. |
26th February 2012, 00:46 | #14669 | Link |
To all:
A reminder: Do not report any bugs on sources that have been preprocessed. If the original has been modified in any way it is preprocessed. If you remove adverts with another package -- it is preprocessed. If you make a little change with another package -- it has been preprocessed. If you decide to "make a change that has not impact anything" with BDEDIT -- it is preprocessed. I really don't like spending hours trying to find a bug (that I can't repeat) only to discover that it has probably been introduced by some other package during preprocessing (especially when the fact wasn't revealed to me until after I'd spent a considerable amount of time on it). Last edited by jdobbs; 26th February 2012 at 00:49. |
26th February 2012, 05:06 | #14672 | Link |
I recently backed up How To Train Your Dragon and viewers have indicated the audio goes out of sync near the middle. I used Imgburn to create an ISO of the AnyDVDHD ripped structure and when mounted and played, the audio is IN sync thru-out. Unfortunately I can't do much with a 38GB ISO. This has apparently been an issue with other software similar to BD-Rebuilder. I won't mention the Fab product directly...
26th February 2012, 05:36 | #14673 | Link | |
26th February 2012, 08:24 | #14677 | Link |
I just ran a couple of batch jobs in a row while I went out and I no longer received the DGDecNV error when moving to the next job after the display went to sleep. This option is greatly appreciated!!!
26th February 2012, 10:56 | #14678 | Link |
hi all,
I'm getting the error condition error still, BD Rebuilder experience an error 2501 , sourcecheck 000055 2501. It's happening everytime now with anything i put in. I've tried wiping my source hard drive and scanning for errors nothing there. I've tried ripping with anydvd using image and rip video dvd to harddisk I've tried downloading other sources over 25gb and trying those it does exactly the same. I've tried taking BD rebuilder off and installing it again. I've ran the inspect tool but nothing there see below - Windows Version: 6.1 [7601] - AVISYNTH Version: [2.5.7.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [3882], Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.40.0.7, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok report looks a bit like this - [23:31:52] SourceCheck() 00009 2501 - [23:32:34] SourceCheck() 00009 2501 - [23:32:45] SourceCheck() 00055 2501 Need help please!!! Last edited by graffight; 26th February 2012 at 11:05. |
26th February 2012, 14:55 | #14680 | Link | |
