Old 14th April 2005, 04:20   #21  |  Link
vcmohan
A new plugin FanFilter is now available for free download at[url]http://www.avisynth.org/vcmohan[\url] and at www.avisynth.org/warpenterprises . This plugin tries to remove regular frequency interference in video (sometimes seen while capturing a weak TV signal) that appears as inclined bars on image. There is a discussion on this in this forum under topic "How to remove diagonal bars from video?"
mohan
my plugins are now hosted here
vcmohan is offline   Reply With Quote
Old 1st May 2005, 21:52   #22  |  Link
Wilbert
I've added a Japanese plugin section (and links to descriptions at avisynth.org)!
Old 27th May 2005, 20:40   #23  |  Link
Karyudo
Wilbert, I'd like to take a crack at providing better translations of the Japanese instructions for these filters. However, there's no reference to the original Japanese locations. Could you add that to the AviSynth wiki, so that I (or anyone else who knows some Japanese) might be able to help out?
Karyudo is offline   Reply With Quote
Old 2nd June 2005, 20:53   #24  |  Link
Wilbert
Yo, your pm box is full
Original japanese locations (docs are included in the zip files):
GPU_001.zip (by thejam79):
http://www.avisynth.info/?plugin=att...le=GPU_001.zip
KillPulse (i think you already found this one):
http://www.avisynth.info/?plugin=att...e_20050415.zip
DePulse:
http://dv-and-movie.hp.infoseek.co.j...xx/depulse.zip
pa:
http://www.chiyoclone.net/dl/main/pa_20050322.lzh
cc:
http://www.chiyoclone.net/dl/main/cc_20040522.lzh
a60224:
http://www.chiyoclone.net/dl/main/a60224_20040315.lzh
Its:
http://members.at.infoseek.co.jp/kir...a/Its_v0_7.zip
DeDot (and old one):
http://nullinfo.s21.xrea.com/cgi/cou..._YV12_0002.zip
IT_YV12 (and old one):
http://nullinfo.s21.xrea.com/cgi/cou..._YV12_0103.zip
I guess you missed the links when browsing
http://www.avisynth.org/JapanesePlugins
Btw, do you know how to open lzh files?
edit: i added some filters. I hope you don't mind
references:
http://members.at.infoseek.co.jp/kiraru2002/
http://dv-and-movie.hp.infoseek.co.jp/tipsxxx/
http://www.avisynth.info/?%A5%A2%A1%...AB%A5%A4%A5%D6
Old 2nd June 2005, 21:33   #25  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
WinRAR or TUGZip should both be able to open LHArc (=LZH) files...
np: Luke Vibert - Flyover (Lover's Acid)
Leak is offline   Reply With Quote
Old 3rd June 2005, 01:17   #26  |  Link
Karyudo
I see that. I didn't know it could fill up! First time I've had to worry about that since joining.
I'll get to work on some translations.
Old 17th September 2005, 04:26   #27  |  Link
vcmohan
I have just posted 5 new plugins along with their documentation. A short description of them and functions included are as follows:
ColorIt :- This plugin has a collection of 14 functions which are useful in coloring a black and white image or recoloring a colored image. The functions in this plugin are:
1. GaussBlur: The input image, grey scale or color, has noise and removing it enables better mask generation. GaussBlur smoothes image by convolving image with Gaussian separable coefficients.
2. MaskMaker. Creates a white or black mask depending upon the grey scale values of the image.
3. EMarker. Creates a white or black mask using various edge detection methods.
4. Morpher. Erosion, dilation, opening, closing thinning, salt & pepper,ridges and valleys functions are included. Some troublesome parts in a mask like thin strands connecting or radiating from objects etc can be got rid off by these standard morphing techniques.
5. SharpEdge. Creates pixel wide edge masks(required for coloring) or creates gradient image (useful for watershed segmentation).
6. Shift. Shifts the grey value of all pixels in an enclosed area by an amount.
7. Stretch. Stretches all values in an enclosed area by a percentage.
8. ColorDrops. Color fills masked areas, given seed points.
9. ColorLines. Colors pixel thin lines with given color
10.ColorBrush. Color fills all white (or all black) areas in a mask along a line.
11.Inlay. Color fills all areas specified by a combination of lines and masks
12.Drawlines. Draws lines on frames for limiting colorfill and other functions.
13. Pallet. While preserving original Grey scale, the finally seen color may appear to be different to that specified. This happens as only the Chromacity values of the given color is used. To get a feel of the actual values, this pallet function is useful. Also useful for cleaning input clip for watershed or recoloring work.
14. CrossFill. Using two masks coloring is done depending upon logical AND, OR and XOR values.
AdaptiveMedian : This plugin function filters noise by finding minimum, maximum and median values of a local grid and expanding to a limiting maximum size for for getting better statistics.Useful for filtering salt and pepper noise.
DeNoise : This plugin function, using global and local variance adaptively filters the noise from image. Also useful for cleaning input clip for watershed or recoloring work.
Watershed : This plugin function treating the image values as elevation, segments the image by drawing watershed lines and individual basins.
NeuralNet : This plugin implements a 3 layer classification type Artificial Neural Network. Has been tested on an edge detection task.
mohan
Old 5th October 2005, 04:31   #28  |  Link
vcmohan
I have just posted a new plugin for Avisynth HistogramAdjust
This as the name implies adjusts the histogram of a frame by either equalization, or by matching or by duping with another histogram. For match or dupe options, histogram can be input as a table of values or extracted from a frame of any clip.
Full frame as well as windowed options are available.
The plugin works for RGB, YUY2 and Planar formats only.
mohan
Old 5th October 2005, 05:08   #29  |  Link
Your work would be more valuable to the community if you would post the source code.
Old 6th October 2005, 03:59   #30  |  Link
vcmohan
It was included.
mohan
Old 6th October 2005, 12:41   #31  |  Link
Oh, thanks. Not to be picky, but perhaps you can release code for all your filters?
Old 6th October 2005, 22:03   #32  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
DeNoise!
At last somebody dared to use this "very informative" name!
Old 7th October 2005, 03:57   #33  |  Link
vcmohan
Yes there are a few for which I did not include source code, mainly because I have a few ideas to make the functions better and it takes some time to make the changes. Meanwhile I do get ideas for a new plugin and distracted. For instance the NeuralNet at present works with Logistic activation function only. I am working to include tanh, gauss and elliot sigmoids. Once I complete that I will post it. So also for others.
mohan
Old 7th October 2005, 14:43   #34  |  Link
Thank you. Your contributions to the video community are appreciated!
Old 26th October 2005, 06:03   #35  |  Link
vcmohan
The NeuralNet plugin is revamped. It now includes NeuralNetBP and NeuralNetRP. BP is for standard back propogation and RP is for Resilient Propogation RPROP (after Reidmiller and Braun). These functions now have option for logistic, alogistic, tanh, atanh, gauss, elliot and evero sigmoids for activation. Both are for classification. The first frame output has diagnostic plots of histogram and error (or any other parameter opted) to be displayed with iteration during training.
The source files are included along with compiled dll and usage html documentation.
mohan
Old 29th October 2005, 17:40   #36  |  Link
Poutnik
Useless idea generator
Poutnik's Avatar
Originally Posted by vcmohan
AdaptiveMedian : This plugin function filters noise by finding minimum, maximum and median values of a local grid and expanding to a limiting maximum size for for getting better statistics.Useful for filtering salt and pepper noise..
It looks like similar to Removegrain, extending size behind 3x3 grid....
Vista64 Premium SP2 / C2D E4700 2.6GHz/ 6GB RAM/ Intel GMA 3100 / DTV Leadtek DONGLE GOLD USB2 /
focused to DVB-T MPEG2 PS capture -> ProjectX -> M2V/MP2 -> MeGUI/AVS -> MP4[AVC/AAC]
Poutnik is offline   Reply With Quote
Old 6th March 2006, 04:03   #37  |  Link
vcmohan
FQuiver :A new plugin isavailable for download . This plugin works in frequency domain, and has two functions FQ1Row and FQ2d.
1. FQ1Row filters data row by row of image using one dimensiona fft. It has a number of gaussian, butterworth filters which can be cascaded. In addition a filter can be custom designed.
2. FQ2d transforms whole image using 2d fft. It has Gaussian and butterworth filters.
Documentation includes some examples of application. and filters.
discussion
edit mod: fixed link
mohan
Old 11th March 2006, 10:36   #38  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
where is xStatImport plugin (by sh0dan) source code?
Old 11th March 2006, 14:17   #39  |  Link
Wilbert
Just send Sh0dan a pm. I guess i forgot to download it (before he changed from provider) and include it in the rest of the package.
Old 6th July 2006, 01:05   #40  |  Link
Kostarum Rex Persia
Banned
From where I can download mergechroma denoise filter?
Kostarum Rex Persia is offline   Reply With Quote
