14th October 2015, 16:42 | #102 | Link | |
Pig on the wing
19th June 2016, 12:19 | #103 | Link |
Hello, seeking clarification ... where am I mis-understanding ?
This http://rationalqm.us/board/viewtopic.php?f=8&t=441 and this thread here http://forum.doom9.org/showthread.ph...51#post1741851 both indicate DGdecNV will not be supported in VapourSynth. This http://forum.doom9.org/showthread.ph...53#post1741853 says use avsreader as a workaround (thanks). This http://www.animemusicvideos.org/foru...25039#p1546405 indicates non-NV DGMPGDec can be used OK in VapourSynth, eg MPEG2Source("c:\path\file.d2v",info=0,ipp=true,cpu=0) This (4 Mar 2016) http://forum.doom9.org/showthread.ph...02#post1759402 seems to indicate that DGdecNV is supported in VapourSynth because it shows how to use it (code below) and says "DGSource works fine btw". Code:
import vapoursynth as vs core = vs.get_core() core.std.LoadPlugin(r'D:\Software\Medien\DGDecNV\DGDecodeNV.dll') clip = core.dgdecodenv.DGSource(r'D:\Temp\Video\00009 temp files\00009.dgi') clip = core.vivtc.VFM(clip, 1) clip = core.vivtc.VDecimate(clip) clip.set_output() Code:
DGIndex.exe produces .d2v files and is paired with MPEG2Source like MPEG2Source("%pard2v%",info=0,ipp=true,cpu=6) # DEBLOCK and DERING DGIndexNV.exe produces .dgi files and is paired with DGsource like DGSource("%pardgi%",deinterlace=2,resize_w=%Width%,resize_h=%Height%) #deinterlace=2 means double rate deinterlacing Thanks to you. |
19th June 2016, 16:27 | #104 | Link |
Professional Code Monkey
Plain dgdecode works. I tested it myself long ago. The nv version I've never tried since I don't have a suitable graphics card but I think som people have had success with it.
Either way, if they're broken you'll most likely get an instant crash which is hard to miss. Plain dgmpgdec does have a quirk that it doesn't apply user/file specific cropping so you have to do that yourself. Or just use d2vdecode.
24th June 2016, 14:49 | #106 | Link |
@hydra3333 DGDecodeNV works fine IF you are using the release of VapourSynth and version of DGDecodeNV that supports it (R26 and rev 2051 I think; whatever stuff is in that version of StaxRip). I'm still amazed this feud is going on for this plugin. I don't see how having multiple releases of a project is bad (was easy to maintain for the ones I updated) nor do I see how performing your own frame rate normalization to be a "hack", I consider it a standard.
The most amazing part to me is that you have this plugin that requires a license but you'd rather screw yourself out of that income... Worthwhile plugin, just don't grasp the argument for a standalone/no "hack" version. Last edited by Elegant; 24th June 2016 at 18:16. |
6th November 2016, 07:01 | #108 | Link | |
Failed to evaluate the script: Python exception: No entry point found in C:\Program Files (x86)\VapourSynth\plugins64\DGDecodeNV.dll Traceback (most recent call last): File "src\cython\vapoursynth.pyx", line 1491, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:26905) File "\\FreeNAS\Users$\Shane\Desktop\Fate-Stay Night.vpy", line 9, in <module> core.std.LoadPlugin(r'C:\Program Files (x86)\VapourSynth\plugins64\DGDecodeNV.dll') File "src\cython\vapoursynth.pyx", line 1383, in vapoursynth.Function.__call__ (src\cython\vapoursynth.c:25212) vapoursynth.Error: No entry point found in C:\Program Files (x86)\VapourSynth\plugins64\DGDecodeNV.dll Last edited by Elegant; 6th November 2016 at 07:08. Reason: Found solution |
17th January 2017, 01:58 | #109 | Link | |
You mentioned re 64-bit DGDecodeNV :-
Does the latest 64bit DGDecodeNV.dll plugin work OK with the latest vapoursynth ? I'm re-looking at using it now for GPU enabled decoding/deinterlacing/resizing. eg in a windows .bat file Code:
#video = core.avs.DGSource(r'%pardgi%',deinterlace=1) # deinterlace=1 means single rate deinterlacing #video = core.avs.DGSource(r'%pardgi%',deinterlace=2) # deinterlace=2 means double rate deinterlacing, beware extra frame at 0 #video = core.avs.DGSource(r'%pardgi%',deinterlace=2,resize_w=720,resize_h=576) # deinterlace=2 means double rate deinterlacing, beware extra frame at 0 #If using double-framerate NV, fix the double-framerate bug in NV per http://forum.doom9.org/showthread.ph...56#post1391556 like this #video = core.std.Trim(video,first=1) |
