Old 28th December 2013, 02:50   #1  |  Link
Navarre66
MSU Logo Remover 3.0b doesn't work?
I've tried using version 3.0b several times now, but it won't create the "tmp.logopack" file. And with a blank logopack file it only outputs a blank video.
I've tried it with different names and putting it in different directories to no avail. I'm using Windows 7 64-bit, but I only used the 32-bit versions of VirtualDub 1.10.4 and 1.9.11.
I am able to use the 2.3b version without any problem.
Thanks,
Navarre66
Navarre66 is offline   Reply With Quote
Old 10th January 2014, 09:15   #2  |  Link
johnsonlam
johnsonlam's Avatar
Thanks,
Navarre66
1) Use the old version instead
2) Email the Russian developer and ask
I've use that years ago, so I forgot the details, but it should work
Hong Kong - International Joke Center (after 1997-6-30)
johnsonlam is offline   Reply With Quote
Old 11th January 2014, 00:07   #3  |  Link
Navarre66
Yup, that's what I had to do. I emailed them the same day I posted this, but so far no response. But being that they are in Russia, I'll bet my email provider is blocking any responses.
logo removal, msu, virtualdub
