Old 15th July 2012, 13:27   #1  |  Link
semeyon
Problem while merging 2 h264/mp4 files
Hello, Every one.
I've a problem while merging 2 h264/mp4 files width the same parameters except length.
I'm mergin by "mp4box -cat ..." command. After that video players behave are strage:
if I drag time slider closer to the end of file it reset to restart the video and
some time, players are show incorect video file length.
Also there is problem with audio sync.
Input file sample parameters:
* Movie Info *
Timescale 90000 - Duration 00:15:00.214
Fragmented File no - 2 track(s)
File suitable for progressive download (moov before mdat)
File Brand mp42 - version 0
Created: GMT Thu Jun 7 23:31:52 2012
File has root IOD (9 bytes)
Scene PL 0xff - Graphics PL 0xff - OD PL 0xff
Visual PL: ISO Reserved Profile (0x7f)
Audio PL: High Quality Audio Profile @ Level 2 (0x0f)
No streams included in root OD
iTunes Info:
Encoder Software: HandBrake 0.9.6 2012022800
Track # 1 Info - TrackID 1 - TimeScale 90000 - Duration 00:14:59.858
Media Info: Language "Undetermined" - Type "vide:avc1" - 21576 samples
Visual Track layout: x=0 y=0 width=853 height=480
MPEG-4 Config: Visual Stream - ObjectTypeIndication 0x21
AVC/H264 Video - Visual Size 864 x 480
AVC Info: 1 SPS - 1 PPS - Profile Main @ Level 3
NAL Unit length bits: 32
Pixel Aspect Ratio 80:81 - Indicated track size 853 x 480
Self-synchronized
Track # 2 Info - TrackID 2 - TimeScale 44100 - Duration 00:15:00.214
Media Info: Language "English" - Type "soun:mp4a" - 38769 samples
MPEG-4 Config: Audio Stream - ObjectTypeIndication 0x40
MPEG-4 Audio MPEG-4 Audio AAC LC - 2 Channel(s) - SampleRate 44100
Synchronized on stream 1
Output:
* Movie Info *
Timescale 90000 - Duration 00:29:24.136
Fragmented File no - 3 track(s)
File Brand isom - version 1
Created: GMT Thu Jun 28 19:40:39 2012
Visual PL: AVC/H264 Profile (0x15)
Audio PL: AAC Profile @ Level 2 (0x29)
Track # 1 Info - TrackID 1 - TimeScale 90000 - Duration 00:19:36.968
Media Info: Language "Undetermined" - Type "vide:avc1" - 28219 samples
Visual Track layout: x=0 y=0 width=1024 height=576
AVC/H264 Video - Visual Size 1024 x 576
AVC Info: 1 SPS - 1 PPS - Profile Main @ Level 3.1
Pixel Aspect Ratio 1:1 - Indicated track size 1024 x 576
Self-synchronized
Track # 2 Info - TrackID 2 - TimeScale 44100 - Duration 00:29:24.136
Media Info: Language "English" - Type "soun:mp4a" - 75975 samples
Track # 3 Info - TrackID 3 - TimeScale 90000 - Duration 00:09:46.503
Media Info: Language "Undetermined" - Type "vide:avc1" - 14062 samples
Visual Track layout: x=0 y=0 width=1280 height=720
AVC/H264 Video - Visual Size 1280 x 720
Pixel Aspect Ratio 1:1 - Indicated track size 1280 x 720
And I do not understand, why in output file I have 2-vdeo tracks?
Thanks!
semeyon is offline   Reply With Quote
gpac, h264, mp4box
