3rd March 2004, 01:06 | #101 | Link |
fu2k and UMP
I love you guys! Well I love FairUse anyway. Too bad I can't get ya to take a donation. I use FU more than any other program and to me it is worth chargin for. fu2k you made a wonderful program, ahead of its time, rock solid. bullet proof, almost perfect. UMP you are finishing what was started in a great way. Your additions are pretty much exacty what FU needed. You do not give yourself enough credit sometimes. Many Thanks and keep up the good work! |
10th March 2004, 06:28 | #103 | Link |
tha Canadian Soldier
My 2 cents...
@UMP: FairUse is just getting better and better with its 0.40 version!
1- I was wondering if its possible to add a "Browse" button so we can decide where (on wich hard-disk) the final file will be written? 2- Would be great to be able to create a FairUse project with already unencrypted vob files on our hard-disk. 3- Are you planning to add some options for filters? (now im thinking about Convolution3d and maybe some other usefull filters...) Keep up the good work! Regards
Sly tHE RathO "Pour le meilleur ou jusqu'a temps que je m'ecoeure!" |
10th March 2004, 09:45 | #104 | Link |
1. this is not planned ATM
2. you might build an iso image and mount it with daemon-tools 3. the "original resize" mode features built-in filters, but this mode is currently about 2-3 times slower than the MMX version (without filters). |
10th March 2004, 14:44 | #106 | Link |
@UMP:
What are the filters the original resize mode is currently using? Is it that hard to add a button so the user can decide where to write the final file? Thank you for your reply. Regards
11th March 2004, 22:55 | #108 | Link | |
12th March 2004, 11:12 | #109 | Link | |
one inch man
rgds. mikegun
- free speech for the dumb - |
13th March 2004, 00:03 | #110 | Link | |
13th March 2004, 00:58 | #111 | Link |
About the destination of final written file...
Too bad, it would be a great option that would push me to use FU over my old classic method. It is hard-disk-killer to process-mux movies on a single hd IMO and i just hate that.
[no offense here] OK, let's see if the money can bring this option... i'll make a little contribution via Paypal if it gets on soon [/no offense here] Also, would be great to have more details about what exactly is the "old resize" and what is the "new one". Can you publish on your website your to-do list if possible? Keep up the good work UMP! Regards
13th March 2004, 18:17 | #112 | Link | ||
Re: About the destination of final written file...
You should only donate if you want to _donate_. Quote:
Bilinear resizing is usually considered to be better than bicubic when it comes to shrinking the picture. Regards, ump |
14th March 2004, 12:58 | #115 | Link |
Anamorphic output using FU?
Well guys, I am not sure whether what I am going to describe here belongs to this thread, but I simply don't want to start a new one with my first post in this forum...
Let's go: I have a 16:9 TV, standalone MPEG4 player and an anamorhic (16:9) DVD with a 2,35:1 film. What I want to do is to make a XVID AVI using FU, but optimized for watching on my TV set, it means it should contain anamorhic frames. Although it would be nice if I there were a SW player that can automatically handle such anamorhic AVIs on the comuter, it's not my primary concern at the moment. To do such thing with FU is at the moment not possible. Why? Because FU does not support native output of anamorhic material. I mean in the FU Wizard resolution screen, you can pick up 'Output Video Size' that are found to be suitable (using FU intern logic) either for 'TV Aspect Ratio' (equals to 59:54 PAL PAR), or not which probably defaults to computer monitor display with 1:1 PAR. For anamorhic DVDs, FU realizes that in both cases you will have to resize, what is exactly what you need when you are going to watch the film on the computer monitor. So the resolutions that one can use for an output video size are limited to those ones which have a resizing included. But for 16:9 TV sets this simply means the lost of vertical resolution and advantages that anamorhic DVDs bring with. To be (hopefully) clear, that is the exact sequence of what happens: - After first steps I cropped the horizontal black bars, and after that I have frames with 704x432 resolution. - The best output resolution offered by FU in this case is 704x320 (with 'TV Aspect Ratio' set). - When I choose this resolution, I get 'normal' frames in AVI, BUT (excuse for caps) I loose 112 lines of vertical resolution. - When I play such material on my TV, I get squieshed picture with DAR ~ 3:1. That's because my TV set in automatic mode have a 'feature' to always stretch the lines to fill in the full screen. - Well, as a 'workaround' I use a 'zoom' feature of a TV set which stretch the picture vertically so that the final DAR is as the original one (2.35:1), but I know that I have lost about 33% of vertical resolution, and that my favourite film can look much better if played without vertical streching... I think it would be great if the FU Wizard get one additional 'check box' (or radio box) which allow to set the output video size to resolutions which correspond to native anamorhic build. In practice it should equal (in at least one most ineteresting case) not to do resizing at all, which can only additionally speed up the whole process. And chances are good that the number of people using stanalones MPEG4 players and 16:9 TVs will increase in future. One more question for MPU: Afaik the black-white luminance range for watching on PCs is 0-255, while for TV it is 16-236 or so. How it is handled in FU at the moment? I mean is the output optimized for PC (analog to Avisynth filter colorYUV with 'levels' parameter set to "TV->PC")? If it is so it would be great if it can be configurable as well, so when preparing the material targeted for watching on TV the original luminance range stay the same as original... I have a strange feeling that my XVIDs when looking using standalone player are a little darker then on my PC and I think that maybe can be a reason. And finally my personal message (MPU, fu2k): you have done a great job, guys. It was a long way to go, a lot of wonderful people contributed to 'fair use' ideas considerable amount of their time (and lives), and a lot of extraorinary good and useful products are available at the moment. But with your product a ripping has become a 'no brainer' as it should be. There are a lot of us that prefer this all-in-one way, always or at least sometimes. That's a way to find time to do something else in our lives far away from computer screens... just keep on... Last edited by halbacht; 15th March 2004 at 13:00. |
16th March 2004, 06:44 | #116 | Link |
Question about resolutions
@UMP: I have a fullscreen movie, and i'm wondering why the resolution choosed by FU doesn't match the 4:3 AR.
For a 1 cd rip, i always use 512x384 res >> 4:3. (I'd go 640x480 for a 2 cd rip, wich is not the case right now...). The preferred resolutions that shows FU, 512x384 does not appear, and the preferred res are not 4:3. Is the problem related with the cropping? Should we specify to FU the source AR? >> 4:3 or 16:9? Regards
16th March 2004, 13:22 | #117 | Link | ||
I mean : an anamorphic encoding will display fine on _your_ TV set with _your_ standalone player, but there is no guarantee how the same encoding would display with another hardware (no to speak about PC monitor). I don't like the idea to implement "try and see if it works for you" features in FairUse. Quote:
@RathO: FU already knows the source AR. If you're looking only to predefined standard resolutions, you might try with no cropping at all, through this is not recommended. Regards, ump |
16th March 2004, 15:16 | #118 | Link | ||
Anamorfic output: to be or not to be?
@UMP:I respect your fear to put inside one all-in-one and easy-to-use tool one such (advanced?) feature. But think again:
It took me some time to understand what's happening and to realize that the picture I get can be much better without (almost) any development effort. At the beginning I had the feeling that something is wrong, but I didn't figured out what. There are a lot of newbies that are using ripping for the same reason as me, but are simply not aware that they easily can get much better results. I mean they are maybe happy with what they get, but they (and me) will be much happier if we get something much better... As you stated it is very easy to implement , BUT you don't give it to us . So (no offend here) this reminds me on my database admin: I know that something exist, BUT he simply don't give me the right to use it ! Na ja, I don't like him anyhow... BUT, I like you and your work and respect all what you put inside this program (I am a sw developer as well). I am just telling you:
- make this feature available only in expert mode, or - use clear statement that the feature is exclusively for 16:9 TV sets And nothing more, everybode will understand it, even newbies are not sooooo blind , believe me! Concerning luminance: Quote:
thanks for reply, regards halbacht |
16th March 2004, 16:51 | #119 | Link |
What i mean is that with AR 4:3, 512x384 should be available in the preferred res. When FU crops using AutoSet, the AR % of error should be 0%, wich is not the case right now with its ~1.xxx% AR error.
I know its no big deal, but you know... J'te remercie Regards
