5th December 2011, 19:05 | #14262 | Link |
I have an issue with the delogo filter. It won't work right up to the edge of the frame. It always leaves about 2 pixels or so visible. If I try to cover those two pixels the delogo mask vanishes completely. Example below. You can see part of the logo at the bottom left. I have tried different aspects and touching from from inside and outside etc to no avail.
http://www.imagebam.com/image/74363e162953570 |
5th December 2011, 20:06 | #14263 | Link |
QuickSync is a plugin for the regular ffdshow video decoder. It is not in any way related to the DXVA functionality of ffdshow.
MPC-HC 2.2.1 |
5th December 2011, 20:07 | #14264 | Link | |
MPC-HC 2.2.1 |
5th December 2011, 20:43 | #14265 | Link |
I'm using an nLited Windows XP Pro SP3. I'm always running as Admin, so in essence I can access everything. No hidden settings. That makes me wonder how FFDShow detects if one is running as admin or not.
It's only the Raw Video Decoder config, the other configs I can change the merits no problem.
My hobby website |
6th December 2011, 11:06 | #14266 | Link | |
In DirectShow, the down stream filter prepares buffer. There is no explicit transmission of the strides. Thus both filters have to guess stride from the dimensions. MSDN in Japanese document says that for YUV format such as YV12 stride has to be rounded to the nearest DWORD alignment. Sorry, I can't find English documentation. It look like that part was deleted/changed. vsfilter does not align the stride at all. If ffdshow does not take the bug into account, the picture is messed up. I think it is not wise to fix vsfilter now, because filters that have the workaround gets broken again. |
6th December 2011, 11:12 | #14267 | Link |
For the record, ffdshow raw also doesn't deal with any stride, it will exhibit the same problems (green bar, etc).
The best solution would be if the post-processor takes over the buffer control and then requests the stride (much like a renderer would function).
6th December 2011, 13:31 | #14268 | Link | ||
6th December 2011, 13:36 | #14269 | Link | |
ffdshow's default output color space has been YV12 for a long time. On Windows Xp, YV12 should work fine except very rare cases. OSD: I'll take a look later. |
6th December 2011, 13:51 | #14270 | Link |
もこたんインしたお!
Yeah, the stride bug was found to be in both VSFilter as well as the raw input filter, I think it's mentioned in the related CCCP thread as well...
Anyways, I was going to report these things as soon as I got off my lazy turd to make a sample of another file where -tryouts was using the wrong channel mapping with a 4ch AC3 stream if libavcodec's decoder was used (probably matched to whatever liba52 was putting out since using that one seems to output the same as VLC/LAV Audio). That sample is now available here.
[I'm human, no debug]
6th December 2011, 16:33 | #14272 | Link |
I'm using version ffdshow_rev4052_20111120_clsid and noticed that one avi video which is H.264 video component could not play in Media Player Classic, so I tried installing an older version, the ffdshow_rev3336_20100327_clsid, and with that I was able to play the video, but not wanting to keep an older version I chose to use the Haali Media Splitter, and leaving "disabled" option decoding.
I hope you can resolve this inconsistency. Thank you. |
6th December 2011, 18:30 | #14273 | Link | |||
However, even after having tested it on another computer ('normal' Windows XP using an admin-account with full access), also here the merit-slider is greyed out and inaccessible. Has anyone reading this topic access to this merit-slider at all (you can find it on the "Codecs"-tab of FFDShow's Raw Video Decoder config)?
My hobby website |
6th December 2011, 22:14 | #14274 | Link |
It is greyed out deliberately. It should be removed completely imo.
MPC-HC 2.2.1 |
7th December 2011, 17:41 | #14276 | Link |
@ clsid:
Then why hold up the "run as admin"-story at all? Rather misleading. You don't want people to use the Raw Video Decoder at all?
My hobby website |
7th December 2011, 21:20 | #14278 | Link |
Software Developer
Bug report:
This is not a new report, it's just troubling. When using the FFDShow Subtitle Renderer filter (not rendering with the video decoder) with the "Set interlaced flag in output media type" checkbox enabled in the "output" section, FFDShow crashes GraphStudio (and elsewhere) as soon as the graph is run. Here's a sample file and a grf file to test with It uses FFDShow for Audio decoder and sub renderer and LAV for the splitter and video decoder. EVR is used as the video renderer. The crash occurs whether ffdshow is used as an audio/video decoder or not. Download sample: http://www.multiupload.com/SV8IKUHXS5 The GRF file was created under "D:\X" Last edited by Blight; 7th December 2011 at 21:27. |
7th December 2011, 23:26 | #14279 | Link | |
Changing merits requires admin privileges and therefore "run as admin" can help.
MPC-HC 2.2.1 |
8th December 2011, 05:45 | #14280 | Link | |
