12th October 2008, 14:24 | #4461 | Link |
Media Control author
Well, according to :
DTS wav would have wrong channel order (I was not aware of that), so if someone has a sample saying "Left", "Right", "Rear Left"... in order to test and fix this problem correctly.... |
12th October 2008, 15:02 | #4462 | Link |
Here you are. Exactly what you asked.
I have a question though... How do i play dts wavs with ffdshow? If i load the file in mpc, i get just noise, which means the dts is not recognized. The check for dts in wav option in ffdshow is enabled of course. |
12th October 2008, 15:29 | #4463 | Link |
I just made the test myself, (using my own sample)
there is a mapping problem with dts wav using libavcodec. I'm Having this Mapping (revision 2203): 1. Left Front Channel > 2. Right Front Speaker 2. Right Front Channel > 5. Left Surround Speaker 3. Center Channel > 1. Left Front Speaker 4. LFE Channel > 4. LFE Speaker 5. Left Surroud Channel > 6. Right Surround Speaker 6. Right Surround Channel > 3. Center Speaker Tal Aloni |
12th October 2008, 15:35 | #4464 | Link | |
also, check to see which filters are used before ffdshow, probably something tamper with the wav before it arrives to ffdshow. |
12th October 2008, 17:10 | #4466 | Link |
Ah, you might be right about 48KHz dts wav and ffdshow.
But this file was made with official DTS pro encoder, so if that encoder allows such output, i believe it is legitimate. I am creating a dts wav @ 44,1KHz this time with same content (channel positions). EDIT: Actually, i created dts wavs of all possible combinations (16 & 24 bits, 44,1 & 48 KHz and 768, 1411 & 1536 kbps bitrate). Don't know what a standalone player is supposed to play, but all these kinds are detected correctly from eac3to. Uploading... Last edited by nautilus7; 12th October 2008 at 17:53. |
12th October 2008, 18:36 | #4471 | Link |
ffdshow user
Latest build is crashing if libavcodec ac3 decoder is used.
http://rapidshare.com/files/15334633..._aac_.mkv.html and http://x264.nl/h.264.samples/force.p...05.feb.2008.ts Last edited by _xxl; 12th October 2008 at 18:50. |
12th October 2008, 18:39 | #4472 | Link | |
DTS in WAV still NOT working
Tested with WMP & MPC-HC; 32-bit & 64-bit; libdts & libav (libav just 32-bit); WAV sample with dts inside : http://www.diatonis.com/downloads_dts_ac3.html P.S. AC3Filter it's working with DTS in WAV
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 12th October 2008 at 18:44. |
12th October 2008, 19:08 | #4473 | Link |
Life's clearer in 4K UHD
The 44.1KHz DTS in WAV samples work for me, but only when the "Uncompressed" option is set to "All Supported"
12th October 2008, 19:12 | #4474 | Link | |
P.S. Some splitter missing maybe ?
Intel UHD Graphics 750; Win 10 22H2 |
12th October 2008, 20:06 | #4476 | Link |
Here is an updated build :
http://rapidshare.com/files/15336931...eta14.exe.html New features : - Bug fixes : all DTS samples should pass. Wrong channel mapping to be checked (I didn't modify anything on this part). All TrueHD samples should pass. - Codec switching : if input stream is AC3 (according to splitter) and you selected liba52 for AC3, then liba52 is used for decoding. But if on the incoming data the parser detects an EAC3 stream, then FFDShow switches the decoder to the one selected for EAC3 (libavcodec only). Same thing for TrueHD/MLP. - If SPDIF is selected for AC3 and a TrueHD/AC3 interweaved stream is detected by the internal parser, then AC3 frames are extracted (TrueHD frames are thrown) and sent directly to SPDIF. Otherwise MLP frames are decoded. |
12th October 2008, 20:09 | #4477 | Link | |
However the internal parser I added parses all the header So this is easy to fix. Please remind me this if I don't do this soon |
12th October 2008, 20:16 | #4478 | Link |
What happens if the EAC3 decoder is enabled and the AC3 decoder is set to disabled and a regular AC3 stream is detected? Will ffdshow then refuse the graph connection, allowing another filter to decode the audio?
MPC-HC 2.2.1 |
12th October 2008, 20:40 | #4479 | Link | |
As long as there won't be any media guid that identifies EAC3 against AC3. Same problem with MLP/TrueHD Today everything starts from AC3 format |
