Old 27th March 2018, 08:13   #1061  |  Link
LigH
LigH's Avatar
VPx v1.7.0-217-g223f9e367
New German Gleitz board
Old 4th April 2018, 14:51   #1062  |  Link
LigH
LigH's Avatar
VPx v1.7.0-250-g933619766
Old 7th April 2018, 21:13   #1063  |  Link
mandarinka
mandarinka's Avatar
Originally Posted by mzso View Post
Is it normal for stuff that fades in to look this crappy, or is something going wrong on my end?
https://drive.google.com/open?id=1x3...goGBj1CRbFJ_JH
(It sucks with AVC too BTW: https://drive.google.com/open?id=1n-..._dj3P98PPCJ7R4)
VP9 (and I think AV1 is the same here, sadly) lacks weighted prediction, which is a special coding tool for fading. Without weighted prediction, the fade generates a lot of residual for every frame and the usual compression scheme fails to efficiently handle it, so the residual has to be quantized strongly, which means aggressive lossy compression and more artifacts.
If weighted prediction works right, the fade should look much better if the encoder tries to use it (weighted prediction is available in AVC and HEVC, but fast encoding profiles might not use it). Also if your source already has the fade ruined, you are out of luck.
mandarinka is offline   Reply With Quote
Old 7th April 2018, 22:35   #1064  |  Link
wiak
Originally Posted by LigH View Post
For AOM, a range of 5..8 was recommended to me to speed up remarkably. But VPx may either not support such levels, or it may decrease the quality too much...
i just use 0 ;P
Woah! Ninja?! http://nwgat.ninja/ (AV1 Overview)
"Not available in your region" has now been redefined as "Go Pirate, you filthy scum" Nwgat
wiak is offline   Reply With Quote
Old 7th April 2018, 23:31   #1065  |  Link
mzso
I used the preset slower as usual, which gave me this result. (which apparently resulted in this: weightb=1 / weightp=2 /)
Not sure what they mean, if anything since I never change anything other than quality and presets.
Old 8th April 2018, 16:19   #1066  |  Link
LigH
LigH's Avatar
@wiak:
Too late to discuss that. Pages ago people mentioned this CLI option possibly being abandoned.
Old 9th April 2018, 10:21   #1067  |  Link
cherishjoo
cherishjoo's Avatar
How much is it than H.264 or H.265?
cherishjoo is offline   Reply With Quote
Old 10th April 2018, 08:01   #1068  |  Link
LigH
LigH's Avatar
Originally Posted by cherishjoo View Post
How much is it »better« than H.264 or H.265?
"I accidently ... is that dangerous?"
I don't have much own practical experience, but believe that VP9 can be (depending on parameters, and comparing vpxenc with other specific encoders) better than x264, yet slower than x265, and x265 can beat it for most kinds of material at similar bitrates, I read.
Old 20th April 2018, 18:00   #1069  |  Link
LigH
LigH's Avatar
VPx 1.7.0-291-g3b460db21
Old 29th April 2018, 09:02   #1070  |  Link
LigH
LigH's Avatar
VPx 1.7.0-309-ge4408a07b
Old 29th April 2018, 12:06   #1071  |  Link
LigH
LigH's Avatar
Did you want to ask that in the AOM thread?
Old 29th April 2018, 12:30   #1072  |  Link
mzso
Yeah...
Old 11th May 2018, 15:20   #1073  |  Link
bstrobl
Looks like VP9 has been smuggled into the iOS Youtube App, allowing HDR Videos on some devices.
bstrobl is offline   Reply With Quote
Old 11th May 2018, 23:27   #1074  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
How do you know it's VP9 and not HEVC? I'd be utterly shocked if apple allows you to do VP9 via DASH on iOS! They certainly don't have a hardware decoder.
Old 12th May 2018, 00:23   #1075  |  Link
bstrobl
The iOS app has a stats for nerds option. Video codec is declared as webm VP9.2 on HDR content with AAC audio.
Edit: Furthermore Apple is part of AOM, so they most likely softened up a bit. And it’s not like they don’t do HEVC with software on devices that are much slower.
Old 12th May 2018, 18:27   #1076  |  Link
iwod
https://www.reddit.com/r/apple/comme...one_x/dyrir7l/
iwod is offline   Reply With Quote
Old 21st May 2018, 14:51   #1077  |  Link
LigH
LigH's Avatar
VPx v1.7.0-387-ge27a33177
Old 22nd May 2018, 19:52   #1078  |  Link
benwaggoner
Wow, I wonder what the battery hit is like. And VP9's lack of b-frames and weird vertical slices don't make for efficient parallelization in software decoders.
All HDR capable iOS devices have HEVC Main10 hardware decoders, so choosing a built-in software decoder would not be a technically-driven decision.
Ben Waggoner
My Compression Book
Old 23rd May 2018, 10:15   #1079  |  Link
iwod
Very very very bad. Basically kills the iPhone within 1 to 2 hours of Youtube and making it extremely hot. As mentioned in Reddit.
However it doesn't seems everyone is getting it. May be it is only on new iPhone models?
I guess Apple had to support it since Youtube is only providing with H.264 encodes for below 2K resolution and 2K+ with HDR with VP9.
Old 27th May 2018, 19:44   #1080  |  Link
IgorC
I was surprised (in a good way) after visiting Netflix tech blog.
They make strong accent on VP9 in pretty every article that includes video compression topics. Good news for VP9.
Like here https://medium.com/netflix-techblog/...g-4b9464204830
or https://medium.com/netflix-techblog/...k-e19f1e3a277f
I can speak from my own experience about Netflix and VP9 on smartphone. Long battery life and very good quality. Thumb up.
IgorC is offline   Reply With Quote
google, ngov, vp8, vp9, vpx, webm
