5th February 2016, 11:53 | #4941 | Link | |
how do I get Avisynth MT? I think that's the source of my problem, log file says ''Script error: there is no function named "SetMTMode"'' Last edited by adem940; 5th February 2016 at 12:29. |
5th February 2016, 12:42 | #4942 | Link |
At first, try to comment out the SetMTMode lines by putting a '#' in front.
Regarding AviSynth MT, see the AviSynth MT thread in this forum and the AviSynth Wiki about MT functions since v2.5.7.5. |
5th February 2016, 12:49 | #4943 | Link | |
5th February 2016, 13:24 | #4944 | Link |
MT (multi-threading) can only be disabled if it is available at all. The default installation of AviSynth has no multi-threading functions available at all, therefore the error messages notified you of their absence.
It should not affect quality, only speed. The MT version of AviSynth should be able to use several cores of your CPU to filter video frames in parallel, but that requires some quirks sometimes. At least a good bit more experience. Last edited by LigH; 5th February 2016 at 13:26. |
5th February 2016, 13:26 | #4945 | Link | |
FINAL UPDATE: I followed the avisynth MT guide you shared, now it is working with setMT lines too, thank you very much for answers LigH and Groucho2004, you guys saved my life xDD |
6th February 2016, 03:06 | #4947 | Link |
adem940: Happy Saturday! and you might find these excellent tools helpful, now or in the future, for troubleshooting and-or testing (and thanks Groucho2004 ):
AvisynthInfoTool and AVSMeter |
8th February 2016, 15:20 | #4948 | Link | |
thanks, I will check them. also I wonder if there is a fix for this error; ''Process exits with error: 0xC0000005 STATUS_ACCESS_VIOLATION (-1073741819)'' |
8th February 2016, 15:38 | #4949 | Link |
This exception tells little; at most: "Something went really wrong, and then tried to access memory not assigned to this process". But what and why? Hard to know. The reason may even be a data error in the video to be decoded when this happens later during the conversion; did you post details anywhere? At least it is rather improbable that the reason is in the MeGUI application as such.
8th February 2016, 15:42 | #4950 | Link | |
but today I encoded a video, it had no problem, then encoded another one, it gave me this error, replacing x264 didn't work, so I wanted to ask here. |
8th February 2016, 15:54 | #4951 | Link |
When you try the same video with the same encoder and the same script several times, and it crashes only sometimes, then you should possibly be suspicious of your memory or CPU and check if they may overheat. If it crashes reliably always about at the same percentage of progress inside the movie, then the source file is probably corrupt. If it crashes always alreay when loading an AviSynth script, then something with AviSynth and its plugins may be broken. If you do a 2-pass encode and it always crashes when the 2nd pass runs directly after the 1st, there may be issues with the stats file. — Do you need more different reasons? If not, please start telling us more technical details about the circumstances when the crash happens and how well it is reproducable without changing anything, or with only little changes.
8th February 2016, 16:31 | #4952 | Link | |
things I did just now; -uninstalled lav filters (cleaned residual files) -restarted my computer. -reinstalled lav filters -replaced x264 again. -changed megui updater to developer, my version was 2624, now it updated to 2627 and now it works again, it is weird |
8th February 2016, 16:44 | #4953 | Link | ||
This is so unspecific and random, I'd guess it's RAM overheating. Did you overclock? When did you clean your PC the last time? Is it a workstation PC or a laptop?
My guess: Replacement took a bit time, system was able to cool down. Quote:
Different builds may have slightly different utilizations per core or memory throughput, depending on optimizations. Well, it's guesswork. But in general, the MeGUI as such is most probably not the reason, therefore should not be blamed here in this thread. |
8th February 2016, 16:54 | #4954 | Link |
I never did overclocking, my cpu supports it but not my motherboard, it is i5 2500k cpu, motherboard is new, bought it a few months ago, graphic card is gtx 660, rams are gaming rams too, about cleaning, it has been a quite while since I cleaned inside my case, last time was when I bought the new motherboard, maybe I should clean it soon, I think it is really because of overheating.
9th February 2016, 11:34 | #4955 | Link |
adem940,
Unless you have a particularly dirty environment, a few months isn't a long time between cleaning the inside of a case. If the MB is relatively new, maybe it's a problem with the CPU heatsink being mounted correctly, or with thermal paste not being applied well. Google RealTemp or Core Temp or SpeedFan and if your MB supports it, you'll be able to check CPU temperature. It's a good idea to install more than one as if they agree, it's more likely they're getting it correct. You might want to also try Prime95. It'll probably test the CPU cooling more than x264 encoding and it's used for testing system stability. |
22nd February 2016, 17:23 | #4957 | Link |
I could be losing my mind, but.......
I'm certain in the past you could load a script into MeGUI's video section, click the "Reopen video preview" button, and the preview window would open displaying the aspect ratio at the bottom. There's a check-box for previewing the aspect ratio that still works as it should, but in the past if you changed the aspect ratio at the bottom of the preview, closed the preview and added the script to the queue for encoding, MeGUI would use the newly set aspect ratio when encoding, even over-riding any aspect ratio added to the script by the anamorphic encoding function. Does it work that way for anyone else, because currently (MeGUI 2627) I don't seem to be able to over-ride the aspect ratio at all. I can change it, but the new aspect ratio isn't used when encoding, which seems to make the ability to change it somewhat redundant. Thanks. PS Is Zathor still around and okay? I don't think he's posted for a while. |
23rd February 2016, 05:31 | #4958 | Link |
Again I thought I was losing my mind, but......
The ability to change x264 encoder preset after opening the encoder configuration no longer works. Selecting a new preset doesn't "stick" after closing the encoder configuration. For example: Select "x264 preset A" in the video section's encoder dropdown list. Click Config. When the encoder configuration opens, select "x264 preset B" from the dropdown list. Click Okay. The encoder configuration will close. The selected preset in the encoder drop down list will still be "x264 preset A". That's MeGUI 2627 and the encoder preset names in the above example are fictional. |
24th February 2016, 15:25 | #4960 | Link |
I believe that MeGUI prefers to handle video and audio with separate AviSynth scripts. But you could manually edit the generated AviSynth video script file and load this as source in the main dialog for both video and audio processing.
