#61 | Link |
Ok.
Just to add something for the 16bits, mono, 11025hz problem. It must be somethin with directsound. If i tell directsound to play it at 11026 instead of 11025 it works fine ! I see this behaviour with all sound cards. Directsound must do something special at 11025, or i have the mad cow disease ![]() |
#62 | Link |
*.wav made with virtualdub, PCM 11025Hz 16bit mono, everything plays fine.
gabest.org |
#63 | Link |
Even with this one ?
(copy in a new window to bypass geocities protection) http://www.geocities.com/reclockfilter/pcm_11k_mono.zip |
#64 | Link |
Well, this one makes a wiered noise only
gabest.org |
#65 | Link | |||
DivX plays in sync with my video hardware (in sync with my refresh rate), audio clock is corrected to match this. So fine so good. But does that guarantuee it is in sync with my tv? Is the refresh rate exact enough to produce a frame rate of the video that does not confuse my tv? I didn't get that from the readme...you say the video frame rate is always EXACTLY a multiple/fraction of my refresh rate. Makes sense to avoid jerkiness, sure, but you don't say anything about how precise the refresh rate is or should be and how that affects TV-Output...can you explain that a bit more, please? Thanx in advance! Quote:
#66 | Link | |
So now, if your PC is connected to a TV, and if your movie is played at a speed that is a exact multiple a the video card refresh rate (ie: also tv refresh rate), your movie will be fine on your TV. That's the whole purpose of reclock : good TV-OUT ![]() I made all my tests with a Geforce3 and latest TVTool. Without reclock, every 3-4 minutes, the video becomes jerky during 5-10 seconds (during a vsync "traversal"). With reclock i can play a whole movie without jerkyness (or too rare to be noticed), and i have a very picky tv-set that don't like non-smooth framerate (see me earlier post about natural motion processing). What make me happy is that reclock also works with MPC, so i can also play my DVDs fine. I also have a special video renderer to make my tests which can visually tell me how far the vsync point is from the current drawn frame ; it tells me if the clock is correctly tweaked ... |
#67 | Link |
Okay, then I understood it...I suppose it doesn't make any difference that I am using a Matrox card in DVDMax mode, which works slightly different. In case you don't know, it does not simply clone the desktop to a tv, it outputs any video overlay window that is created fullscreen to a connected TV-set (you don't have to fullscreen on monitor or can even minimize the player).
I could THINK of (not saying there definitely is one) a possible problem. The Matrox card MIGHT produce some kind of own clock/rate whatever for it's tv-output that does not directly depend on the monitor's refresh-rate (you can set the card in PAL or NTSC mode and in both cases select whatever refresh rate you want for the monitor) and then some deviation might occur...let's say, we have 99,8 Hz refresh rate on monitor -> 24,95 fps video, and the 'dvdmax clock' (if it exists) is 24,97 ![]() My point is: you're saying 'video card refresh rate (ie: also tv refresh rate)' -> this might not be true for matrox dvdmax or in other words, I simply don't know how the tv refresh rate depends on monitor refresh rate...at first glance I'd say it does not depend at all, because I can set my monitor to whatever refresh rate I want, the dvdmax output is still around 50 Hz (pal), otherwise my tv wouldn't sync at all, if I got it right. I am a bit confused ![]() I simply don't know, I am just a bit worried ![]() BTW: I don't know how tv-output on geforce cards works, they basically clone the monitor picture to the tv, is that correct (such a mode also exists on matrox but is not the preferred one for video playback)? And you can set the refresh rate of monitor picture to whatever rate you want and tv stays at 50 Hz (you can do that with matrox' clone mode)? Sorry for all this confusion, I understood it so far by now: With Reclock you get a video that is synced with your monitor refresh rate so it won't be jerky on monitor. BUT: There are different TV-Out implementations on different cards, how can we be sure, that being synced with monitor refresh rate and therefore not being jerky on monitor guarantuess perfect playback on tv? Last edited by Chibi Jasmin; 11th December 2002 at 16:05. |
#68 | Link | ||
Just to know, when you output PAL to your TV, what information does you see in the "video hardware" tab of reclock ? If you don't see 50hz, then there is a problem for sure. However, there may be some solution if DirectDraw support your second screen (the tv out) as a second video adapter. I'll search more informations on this. What exact model of card do you have ? Quote:
#69 | Link | ||
In DVDMax mode, the tv out is not a second screen, you can do this setting the card in multidisplay mode, but that's not what we wanna do for video playback on tv. You can even connect two monitors and configure them with two different resolutions and refresh rates in this mode, so chances are great, tv-clock in dvdmax mode is also independently generated... That's why I have been asking for support of disabling clock correction. I didn't have too much problems with jerkiness on tv, but reclock is the only working solution for me to do framerate conversion on dvd playback and I am not sure, if the clock correction part does any good or even bad, but the frame rate correction thing is so cool...maybe you think it over, giving an option to disable clock correction? I don't even care for jerkiness on monitor...in fact, I didn't even have jerkiness (or very little, don't know) with monitor at 85 Hz for a long time. Maybe Matrox' TV-Out doesn't need any adjustment? Quote:
#70 | Link | |
Look in the registry here : HKEY_CURRENT_USER/Software/ReClock/Config You will see some keys with the form "a"x"b"x"c"x"d". If you see more that 1 key that begin with the same "a" and "b" and "c" but have a different "d" then you have the bug. Ex: 1024x768x75x1040 ) 1024x768x75x1050 ) -> IS WRONG I'll post the next version tonight with this fix, and another one for the sound. For the clock disabling problem i don't think it is so important because when the default audio renderer is used, the reference clock is based on the sound card speed. Using this reference clock instead of the reclock one would not give you something more accurate. And disabling the clock is really hard to do for me ... Last edited by ogo; 11th December 2002 at 16:53. |
#71 | Link | |||
[HKEY_CURRENT_USER\Software\ReClock\Config] @="" [HKEY_CURRENT_USER\Software\ReClock\Config\1024x768x100x769] "Version"=dword:00000001 "Wait"="78023.400000" "WaitFactor"="1.300390" "Freq"="1191065.738860" "Ti"="-1364.310232" "Duration"=dword:000000f0 "DRCActive"=dword:00000000 "HardwareResample"=dword:00000001 [HKEY_CURRENT_USER\Software\ReClock\Config\1024x768x100x770] "Version"=dword:00000001 "Wait"="77922.060000" "WaitFactor"="1.298701" "Freq"="1191064.998550" "Ti"="-1366.473598" "Duration"=dword:0000004d "DRCActive"=dword:00000000 "HardwareResample"=dword:00000001 [HKEY_CURRENT_USER\Software\ReClock\Config\1024x768x100x771] "Version"=dword:00000001 "Wait"="1297.016861" "WaitFactor"="1.297017" "Freq"="1193182.000000" "Ti"="0.000000" "Duration"=dword:0000003c "DRCActive"=dword:00000000 [HKEY_CURRENT_USER\Software\ReClock\Config\1024x768x100x773] "Version"=dword:00000001 "Wait"="77619.660000" "WaitFactor"="1.293661" "Freq"="1191065.975042" "Ti"="-1370.357832" "Duration"=dword:000000f0 "DRCActive"=dword:00000000 [HKEY_CURRENT_USER\Software\ReClock\Config\1024x768x100x778] "Version"=dword:00000001 "Wait"="26207.000859" "WaitFactor"="1.285347" "Freq"="1191066.758166" "Ti"="-1379.022244" "Duration"=dword:00000502 "DRCActive"=dword:00000000 [HKEY_CURRENT_USER\Software\ReClock\Config\1024x768x100x784] "Version"=dword:00000001 "Wait"="0.000000" "WaitFactor"="1.000000" "Freq"="1193182.000000" "Ti"="0.000000" [HKEY_CURRENT_USER\Software\ReClock\Config\1024x768x100x792] "Version"=dword:00000001 "Wait"="1262.626263" "WaitFactor"="1.262626" "Freq"="1193182.000000" "Ti"="0.000000" "Duration"=dword:0000003c "DRCActive"=dword:00000000 "HardwareResample"=dword:00000000 [HKEY_CURRENT_USER\Software\ReClock\Config\1152x864x100x864] "Version"=dword:00000001 "Wait"="1227.893086" "WaitFactor"="1.157407" "Freq"="1192262.154714" "Ti"="-343.783374" "Duration"=dword:0000003c "DRCActive"=dword:00000000 "HardwareResample"=dword:00000000 [HKEY_CURRENT_USER\Software\ReClock\Config\1152x864x100x865] "Version"=dword:00000001 "Wait"="17539.150929" "WaitFactor"="1.156069" "Freq"="1191016.728224" "Ti"="-1570.747249" "Duration"=dword:0000003c "DRCActive"=dword:00000000 "HardwareResample"=dword:00000001 [HKEY_CURRENT_USER\Software\ReClock\Config\1152x864x100x866] "Version"=dword:00000001 "Wait"="68236.873077" "WaitFactor"="1.154734" "Freq"="1191017.645117" "Ti"="-1571.513361" "Duration"=dword:00000043 "DRCActive"=dword:00000000 "HardwareResample"=dword:00000001 [HKEY_CURRENT_USER\Software\ReClock\Config\1152x864x100x868] "Version"=dword:00000001 "Wait"="1152.073733" "WaitFactor"="1.152074" "Freq"="1193182.000000" "Ti"="0.000000" "Duration"=dword:0000003d "DRCActive"=dword:00000000 [HKEY_CURRENT_USER\Software\ReClock\Config\1152x864x100x869] "Version"=dword:00000001 "Wait"="1150.747986" "WaitFactor"="1.150748" "Freq"="1193182.000000" "Ti"="0.000000" "Duration"=dword:0000003d "DRCActive"=dword:00000000 [HKEY_CURRENT_USER\Software\ReClock\Config\1152x864x100x875] "Version"=dword:00000001 "Wait"="1142.857143" "WaitFactor"="1.142857" "Freq"="1193182.000000" "Ti"="0.000000" "Duration"=dword:00000041 "DRCActive"=dword:00000000 "HardwareResample"=dword:00000000 [HKEY_CURRENT_USER\Software\ReClock\Config\1152x864x100x887] "Version"=dword:00000001 "Wait"="1127.395716" "WaitFactor"="1.127396" "Freq"="1193182.000000" "Ti"="0.000000" "Duration"=dword:0000003c "DRCActive"=dword:00000000 [HKEY_CURRENT_USER\Software\ReClock\Config\1152x864x100x898] "Version"=dword:00000001 "Wait"="3526.756105" "WaitFactor"="1.113586" "Freq"="1190912.814438" "Ti"="-1669.858488" "Duration"=dword:00000093 "DRCActive"=dword:00000000 [HKEY_CURRENT_USER\Software\ReClock\Config\1152x864x100x904] "Version"=dword:00000001 "Wait"="1106.194690" "WaitFactor"="1.106195" "Freq"="1193182.000000" "Ti"="0.000000" "Duration"=dword:0000003f "DRCActive"=dword:00000000 [HKEY_CURRENT_USER\Software\ReClock\Config\1152x864x100x906] "Version"=dword:00000001 "Wait"="0.000000" "WaitFactor"="1.000000" "Freq"="1193182.000000" "Ti"="0.000000" [HKEY_CURRENT_USER\Software\ReClock\Config\800x600x85x602] "Version"=dword:00000001 "Wait"="2403.505698" "WaitFactor"="1.954270" "Freq"="1192699.698376" "Ti"="-189.003825" "Duration"=dword:00000059 "DRCActive"=dword:00000000 [/B][/QUOTE] Quote:
On this site: http://grafi.ii.pw.edu.pl/gbm/matrox/ there's some technical information about the matrox g400 parts, maybe you could have a look at this (especially the point called 'InDepth' explains some hardware stuff)... some quick links: http://grafi.ii.pw.edu.pl/gbm/matrox/g4intro.html http://grafi.ii.pw.edu.pl/gbm/matrox/mgaclock.html Maybe this is not all you need, but it might give some insight into the g400 architecture. Last edited by Chibi Jasmin; 11th December 2002 at 17:35. |
#72 | Link |
Wow
![]() Hope next version will fix that properly. Before installing it, please delete all entries under the "config" folder. I'll check your links for Matrox. |
#76 | Link |
Bad news, V0.96c freezes on file open (automatic graph building), player is frozen with 99% cpu usage!
Did you find something interesting about the Matrox cards? Last edited by Chibi Jasmin; 11th December 2002 at 20:00. |
#77 | Link |
It means it is not able to find your video clock frequency (this takes 100% cpu during .5 second normally but will take forever if it can't find the result).
What is the speed of your processor ? Could your try at lower resolution and with lower refresh rate ? Thanks |
#78 | Link |
Can you test with this version (i relaxed some parameters) :
(copy this link in a new IE window) http://www.geocities.com/reclockfilter/setup.zip This version will produce a log in c:\reclock_log.txt. Can you give me the results by email (for more than 1 run if possible) ? Thanks |
#79 | Link |
Anime Otaku
For what it worth, the new version works OK here. The bug with menus in DVDs remains, but you didn't say that you fixed it anyway
![]() I should also say that my refresh is 75Hz at 1024x768.
AMD FX8350 on Gigabyte GA-970A-D3 / 8192 MB DDR3-1600 SDRAM / AMD R9 285 with Catalyst 1.5.9.1/ Asus Xonar D2X / Windows 10 pro 64bit Last edited by cca; 11th December 2002 at 20:44. |
#80 | Link | |
Will try with lower resolution/refresh rate...results in a minute... UPDATE: Still crashes with 1024x768 16bit and 32 bit. 800x600 at 16 bit works! Last edited by Chibi Jasmin; 11th December 2002 at 21:14. |
