Old 20th July 2008, 20:51   #1  |  Link
jonathonsunshine
TsMuxer and Blu-Ray LPCM audio
Ok, I have been using eac3to to demux the h264 and audio streams from m2ts files from Blu-Ray. In the case of 5.1 LPCM eac3to informs me that it is remapping the channels to the correct order.
I was looking around for something to get the subtitles out and stumbled upon TsMuxer. I see that it will do everything eacto has been doing so I figure I will use it instead.
When demuxing the LPCM I see that it has options for
1) Demux to Multi Channel Wav file
2) Demux to separate mono wav files
3) Demux to RAW PCM stream
Those options are all greyed out thou, I assume they are not implemented yet ? (Separate wav files is what I would most want by the way)
Anyhow, my real question is, does TsMuxer re-order the channels properly also ?
And since I see it also breaks the wav up into 4gb chunks, meaning I will be most likely unable to use ONLY TsMuxer in the majority of cases, when are those greyed out features likely to be implemented ?
jonathonsunshine is offline   Reply With Quote
blu-ray, lpcm, m2ts, tsmuxer
